Nations 3RZ-FE Turbo Swap/Build Thread MegaSquirt Install
Started by Nation, December 26, 2013, 02:56:37 PM
MRHilux87
i put one of those on a 400hp wrx that a friend has.  they are super fun.  Make sure to keep it coated with paint and the linkage all lubed up otherwise the elements will seize it up. And make sure to waterproof all the connections and the motor.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
Nation
anybody have an 8" yota diff with 5:29s laying around?
MRHilux87
2013 Ninja 1000
SOLD:
Nation
OK. I am ready for this diff to fail! Bring it on!
Nation
Quote from: MRHilux87 on November 20, 2014, 10:43:59 AM
Thats not bad Id run it.
Not if you felt it.. the gear oil looked like someone dumped a bottle of glitter into it. The diff was installed in August I believe..
zippo
If you see it, its for sale.
Nation
#546
Some Very Small Chunks. Mostly pasty...  I've had em pasty before... but not this pasty. Gear oil looked to be years old. It's been in there for a little over a month lol.. i changed it once since I installed it in august before MCR.  Im just saying, in my experience anyway, Thats too much material, in too short of a time :dunno: im not stressing on it though. Any way it goes ill get er done.
Nation
#548
So this is what im working with
Nation
Driveline movement THE VERY END OF THE VIDEO SHOWS THE BEST EXAMPLE
81 shortbed
In the first video it sounds like a bearing howling but I'm not sure. Isn't that a new driveshaft?
1985CRAWLER
rear driveline slip is clapped out, same goes for that u joint. should be tight.
as for the other sound cant really hear it over that background noise or is that the noise u speak of?
if u dont need the tuck to drive, pull the diff and inspect.
twistedtoy92
Nation
Quote from: 1985CRAWLER on November 21, 2014, 11:32:48 AM
I need the truck... just gotta suck it up and diff swap tonight. And yes. That's the noise I'm talkin about.
Nation
So this fun stuff got here today.. Thanks Rockcrawlintoy for the link to the bearing!   Now if I can just find that flippin C clip or retaining clip that is installed after the bearing.
Nation
and a special late night delivery....
1985CRAWLER
sweet goodies man!  that winch is gonna make your front bumper pop! and will really come in handy just u wait..
also dave and i were talking it over today and we think the reason why both diffs went toast is because your rear driveline is shot and all the vibration from the worn out u joint and slip is absorbed by the pinion bearing and pinion itself which was the point of failure in the v6 diff, i wouldnt be surprised if its the pinion in that diff u have.
i could be wrong but it would make sense as to why both diffs went out.
Nation
Quote from: 1985CRAWLER on November 23, 2014, 01:53:41 AM
My driveline angle is on point my ninja... it was only off for a week... i shimmed it... then after shim ming it... i had a local shop clock it accordingly... took the truck sown to coast driveline and they said the dl angle looks tits.. maybe it's our angle that's not allowing oil up there?  On my end though... it seems to be just my driveshaft... not to say that there wasn't a ton of metal glitter and more paste that I have seen in my life in such a short period of time.. seems to be working great I suppose haha. It's HARD To Tell Those things.. also I just shot my driveline a few weeks ago jamming through a deep mud pit in 2WD enjoying my power....
Nation
#558
I work my ass off  :usa:  I am hoping to get the truck ready well before KOH 2016..  if I have enough time to do a few runs before hand I'd like to compete..
1985CRAWLER
Nation
Gonna have a sticker on the window that says, "I DROVE HERE"
twistedtoy92
F*CKiN A Billy Ray! Thats the attitude I like to see!!! Keep it up man! You've been kickin ass! :beerchug:
Nation
#562
Quote from: twistedtoy92 on November 24, 2014, 01:16:07 PM
Thanks buddy!
Nation
Crunchy Taco
Looks like you have some awsome plans for your runner. Rite on.
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
twistedtoy92
I would SMOKE that RS5 in my A4, would have been over 100 in that amount of time :yupyup:
Nation
Yea that thing handled like crap too.. old company car..
twistedtoy92
Nation
Ok... back to it! Megasquirt is getting ordered tomorrow am! Let the tuning begin.
MRHilux87
That Audi pulls hard.  My "wifes" evo 9 pulled about the same. Not as cumfy, but alot faster in the corners.  The evo hit the limiter at about 165, Im sure the audi keeps going without the limiter.
2013 Ninja 1000
SOLD:
