Nations 3RZ-FE Turbo Swap/Build Thread MegaSquirt Install
Started by Nation, December 26, 2013, 02:56:37 PM
Nation
Quote from: MRHilux87 on February 22, 2015, 10:50:22 PM
I use mine as a power steering fluid cooler, but either way you might as well use it.
Do you think it will be able to handle the oil pressure?
zippo
The return side of the ps system is low pressure.
If you see it, its for sale.
Nation
zippo
Oh heh. Well atleast i'm still correct, just out of context. I did some reading and seems transmissions can run 200 PSI or so. So should work fine as an oil cooler.
Nation
Nation
I spoke with Jim @ 22REperformance.com about building a 3RZ that can handle 20psi.  Gonna speak again in a few days and get some details about parts and pricing.  :drooling:
Nation
MRHilux87
I've never seen that before. Good find. Might have to get one of those.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
1985CRAWLER
Quote from: Nation on February 24, 2015, 09:29:04 AM
Jim is the man! i watched him do the machine work to my motor.
Nation
Nation
#730
I need one of these asap. Behind the steering wheel. Where the turn signal and windshield wiper switches connect..  combination switch
81 shortbed
It's all part of the multi function switch.  "For all the parts your car will ever need,  rock auto"
Nation
Quote from: 81 shortbed on March 03, 2015, 11:55:26 AM
Everything other than the combination switch for my truck   :inthedark:    :smack:   False advertisement  :moon:
Nation
Ebay doesnt have anything either.. Need part number 84310-35190
81 shortbed
You are right. I just looked but I did find one under 83 pickup, electrical switch- dimmer switch. When I got mine it wasn't 100% correct and I had to splice some wires. Part #tw35
Nation
twistedtoy92
MRHilux87
I have the whole complete steering wheel column from my 87 4 runner.  Just not sure what you need off it.  Is that the top or the bottom of the column?
2013 Ninja 1000
SOLD:
81 shortbed
Quote from: MRHilux87 on March 03, 2015, 04:19:48 PM
You have to pull the steering wheel off and then the switch is held on with 4 Phillips head screws
MRHilux87
I have the whole column so just PM me Nation if you want me to ship it to you.  or txt me.  707-951-1978.
2013 Ninja 1000
SOLD:
Nation
Nation
Lets talk Dynos for a minute...
The guy at the dyno shop told me I am running very lean. afm is at 14 @ full boost on the paper print out.. MY AFR IN THE CAB SAYS 11.2 @ wot.
I am assuming my catalytic converter is throwing off their reading???
He also told me that larger intercooler piping would allow my turbo to spool quicker...  I was under the impression that it was just the opposite.. smaller piping= quicker spool because it creates pressure sooner? ... Im sure theres a rule about piping size in relation to boost numbers.
MRHilux87
What kind of AF guage do you have and where is the sensor?  Intercoolers and their pipes have a sweet spot. You don't want to be too big or too small for the volume or air moving through. I have no idea how to calculate it though. So I'm no help there.
2013 Ninja 1000
SOLD:
Nation
Innovate motorsports, located just to the left of driver side bellhousing before any other sensor or emissions unit.
twistedtoy92
Did you perform the Wideband calibration per instructions? That may cause a false readind or could be that their wideband isn't reading correctly...
Smaller intercooler piping allows for quicker spool... Takes less time to fill the pipes/intercooler but has an impact on the top end/flow. I was going to run 3'' on the Audi, but came to the conclusion that I wasn't going to push over 400hp so I went with 2.5'' piping which made it WAY easier to fit the car... You should be running 2.5'' piping in my opinion!
Nation
Yes, I performed the calibration per instructions. What is the rule of thumb for intercooler piping size vs. Boost?
twistedtoy92
If you are going to push over 450-500hp @25-30psi 3'' would be ideal, 200-450hp @10-25psi 2.5'' would be ideal, anything below that 2-2.5'' works fine...
The cat is most likely whats giving them the offset reading...
Nation
