ImmortalYota80's First Gen Build
Started by ImmortalYota80, July 02, 2013, 10:22:46 PM
ImmortalYota80
Look what I did today  :eyebrow:
Marlin HD Clutch
And the evil scientist at work  :inthedark:
Should have it fired up tomorrow stay tuned for some more pics and maybe a video!  :cheese:
1980 4x4 Pickup, 22RE Swap, Marlin Built G54 Trans, 35/12.50 Cooper STT's, 4" Alcan Front springs/F150 rears, Open 5.29 front, 5.29 E-Locker Rear, Rebuilt Axles, High Steer
Build:
http://board.marlincrawler.com/index.php?topic=94416.new#new
Wainiha
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
ImmortalYota80
Drumroll please...........................................................................
IT RUNS FINALLY!!!
Yes it is outta time a little but i still need to fine tune it and all that fun stuff but my god it runs!
Build:
1985CRAWLER
you did it man! looks good, :thumbs: :clap2:
yea i was gonna say it sounds a little rough but so did mine at first especially with the cam and over sized valves.
break in the cam and check for leaks and try and get all the air out of the cooling system best u can and ur set!
oh also stay away from the synthetic oil for awhile, putney always told me to run the dino stuff for the life of the motor.
i love my engnbldr/22reperformance motor.
ImmortalYota80
Quote from: 1985CRAWLER on July 06, 2014, 08:43:13 PM
Thanks man ya once the cams broken in and its timed life will be good. And im running some high quality castrol 10w-30 oil and change my oil religiously. Cant wait to get my dash back together and drive it!
Build:
cbeers
Congrats man, I am sure you are stoked!
AND just in time for the swap meet  :beerchug:
CB
twistedtoy92
Very nice work! Now you'll get to enjoy all the time you put into the swap! :beerchug:
ImmortalYota80
I currently have everything in my truck done and wired except for my stock gauges. I for the life of me cannot figure out how to get my stock gauges to work. I have the blinkers working and my check engine light done but i cant get my fuel level, engine temp, and tach to work. Ive researched for hours and cant find any good info does anyone know how i can get these things to work????  :help:
Build:
1985CRAWLER
ImmortalYota80
Quote from: 1985CRAWLER on July 09, 2014, 09:20:49 PM
http://www.pirate4x4.com/forum/toyota-truck-4runner/780051-efi-swap-1st-gen-truck.html
this might help. not sure
Not really alot of info in there for the gauge wiring but i did pm crash to see if he had any info for me so hopefully he can get me on the right track.
Build:
ImmortalYota80
Im completely stumped on how to get my stock gauges to work still. So much to where im just completely burnt out of working on this truck. Its not gonna be done by saturday like i hoped and i dont want to drive the truck without properly working gauges.
Build:
megaphoneman
Quote from: ImmortalYota80 on July 10, 2014, 08:28:56 AM
I have my gauge cluster out.. I might be able to get pin numbers for you with the use of a ohm meter and some time.. Is that what your having an issue with?
Blaaaahhhhhhhh
ImmortalYota80
Quote from: megaphoneman on July 10, 2014, 10:09:11 AM
Blaaaahhhhhhhh
You know man I've had my uncle that's an electrician look at it and we couldn't figure it out. I'll bring my old gauges tomorrow and a multimeter and maybe we could get something figured out lol.
Build:
toyodaaddict
I might be able to help, Ive  got an 80 with a 91 22re sitting in my yard and all my stock gauges work including the tach. what I dont understand is it seems like the gauges where more or less plug an play?
OCD
If you truly hit a brick wall on this  :wall:, I will donate a day to the cause... I'm sure it's something minor, there's really not much to the electrical on these rigs. I have 20+ years in automotive electrical, building manufacturers demo cars for SEMA & CES. Can you trailer it to my shop in Campbell? Where is the rig? Depending how far away you are I might even be willing to come to you...
ImmortalYota80
Quote from: toyodaaddict on July 11, 2014, 09:41:24 AM
Did you do a harness swap? I took the complete harness from the donor 87 4runner and put it in my truck
Build:
toyodaaddict
Quote from: ImmortalYota80 on July 11, 2014, 10:32:11 AM
oh, so your issue is the new harness wont plug into your cluster right? I spliced the re engine harness into my existing harness so maybe I cant be of any help.
ImmortalYota80
Well i drove it to the gas station and put some gas in it and made it home just fine! God i love my truck  :love:
Build:
Toyota Addiction
Looks good. I am getting ready to start my re swap in my 81. Looking through your build is giving me some motivation.
ImmortalYota80
Quote from: 1980 ToyotaPU on July 11, 2014, 09:27:54 PM
Well that's why I post here! The re swap has for the most part been pretty simple and the added reliability and fuel savings of the 22re makes it worth it. Plus it's pretty cheap to get ahold of a 22re and build it. If I were to guess I probably have about 2000-2500 in this engine swap which isn't that bad considering I completely rebuilt the engine and gave it some performance goodies. I was looking at doing a 3rz swap but it just ended up costing way too much when everything got added up. I'm very happy with the 22re swap. If you have any questions along the way of your swap I'm more than willing to help you out. Good luck and have fun!
Build:
megaphoneman
OCD i have a gauge cluster out of my truck right now.. If you want to come up to my shop in belmont we could probably figure out my cluster so we can tell him what he needs to hook up the RE harness to the 22r gauge cluster.. If i remember correctly the cluster has what looks like a board and all the connectors route through.. Like an old scool main electrical board.. Too lazy to go look right now but pretty sure we could get it to go right..
Blaaaahhhhhhhh
OCD
Quote from: megaphoneman on July 12, 2014, 10:39:22 PM
Blaaaahhhhhhhh
Can prob swing by next weekend... I have the FSM w/ electrical schematics for both early and late 22re, anyone got the schematic for a first gen 22r? Can prob figure this out at lunch...
ImmortalYota80
Quote from: OCD on July 11, 2014, 10:28:55 AM
Blaaaahhhhhhhh
Quote from: OCD on July 14, 2014, 07:37:48 AM
Tht would be awesome guys. I live in Petaluma and I'm actually driving the truck right now with the stock 4runner gauges I could probably swing by the South Bay some day. Let me know
Build:
megaphoneman
I took the gauge cluster apart.. You should be able to figure out. I sent those videos to you via IG let memknow
Blaaaahhhhhhhh
ImmortalYota80
Ok heres a little wiring tech for all you guys that are thinking about doing this 22re swap. Basically if you are using the donor truck dash harness all you have to wire in are you ignition, gauges, and the headlight,blinker switches. Now heres what you do for the ignition switch
Here is what a stock Carbed ign switch looks like
Notice how theres 5 wires on it now heres what a efi ign switch looks like
Now this has 7 wires going to it. Now what you gotta do is splice some wires together to make it work. Now what wires do you splice together? Well thats easy.
Toyota was kind enough the keep the wire colors the same throughout the years so its easy to see what wires match up and get spliced together but what about the two extra wires? Well if you look closely at the pics of the ign switches above you will see that each wire is labeled ign, acc, st1, am etc... Well the efi switch has 2 ig wires and 2 am wires basically all you have to do is splice both of those wires to the single ig and am wires on the carbed ign switch and your done! Yes its that easy. And everything works perfect.
Now just wrap them up with some tape and wrap the whole bundle together and your done!
Now onto the headlight switch, horn, blinkers
This is also easy. I did not take any pics but there are no differences between the years as far as wire colors and functions go. Basically all you have to do is cut and splice together your old wires to the new harness wires by simply matching the wire colors and your done!
And now the gauges. Now this was a pain in the ass. Trying to get the stock gauges to work is pretty hard if you do not have alot of wiring experience and the factory service manuals for both the year of your truck and the year of the donor vehicle. I spent a weekend trying to figure it out with no luck so im taking my truck into yodaman my local toyota offroad specialist and hes gonna wire in my stock gauges for $200 way worth it if you ask me
Questions???? :gap:
Build:
megaphoneman
Dude come awn.. Delcity.com and 20 bucks of heat shrink...
Blaaaahhhhhhhh
1985CRAWLER
nice write up man! looks good.
if u have yodaman wire the cluster up, have him take pics for you so that way u can post it up for reference for other future 22r to 22re swappers.
:thumbs:
ImmortalYota80
Quote from: 1985CRAWLER on July 15, 2014, 02:33:13 PM
:thumbs:
I'm going to take everything apart after he wires everything and post some pics up for everyone
Build:
ImmortalYota80
Quote from: megaphoneman on July 15, 2014, 02:28:48 PM
Blaaaahhhhhhhh
Tapes easier to take off than shrink wrap  :disturbed:
Build:
