Wenhar's Question Thread
Started by BigMike, May 04, 2011, 09:57:31 AM
kdub0013
How long must this thread go on  :eek:
Wenhar
Good night Turtles,
Really can some one tell me what the points deal is all about,,, I think I have entertained you enough to earn that,
See ya in the morning
86bobbedtoy
anyone can take or give
there used to be a game on finding turtles before I was around,
go to bed you need your energy for unbrainwashing us, go go sleep almighty
Quote from: Wenhar on May 10, 2011, 09:08:40 PM
Good night Turtles,
you could do a quick search for turtle points, that will yield your answer
yotaneck13
RNR FABRICATION ON THE EAST COAST!!! [email protected] (814)-516-5176 like us on facebook www.facebook.com/rnrfab
Quote from: 86bobbedtoy on May 10, 2011, 08:42:59 PM
86bobbedtoy
wtf, he has less than me taken,,....
hold on ill fix that :thumbs:
:shhh:
yotaneck13
86bobbedtoy
this thread is flamin hot
Quote from: kdub0013 on May 10, 2011, 09:08:10 PM
until we get bored
yotaneck13
its gonna be the longest thread with nothin but confusing :bull crap: ever on marlin
86bobbedtoy
Quote from: yotaneck13 on May 10, 2011, 09:23:20 PM
awesome
thanks winner!
yotaneck13
86bobbedtoy
yotaneck13
Dingman.
Quote from: Wenhar on May 10, 2011, 08:55:50 PM
Post up the dimensions of the bushing and I will go away,
Really?
As people go find brass bushing and measuring tools.   :haha:
yotaneck13
wont work ive already posted the dimensions a while ago and he did nothing but complain about them
86bobbedtoy
Quote from: Dingman. on May 10, 2011, 09:56:38 PM
Really?
hay mike what the hell you been up to?
Dingman.
Quote from: yotaneck13 on May 10, 2011, 09:57:32 PM
I saw that you posted the axle dimension and the inner axle seal dimension.  Right?
He wants the Brass bushing that presses into the spindle.
Dingman.
Quote from: 86bobbedtoy on May 10, 2011, 09:58:45 PM
Fighting a nasty flu or something for the past week.  Started to feel okay enough to go start work again yesterday.
So i see you picked up some oil and grease....
yotaneck13
Quote from: Dingman. on May 10, 2011, 10:01:09 PM
ya thats what he origionall wanted then he changed his story he was talkin bout his goop leaking back into the housing then changed it when i posted it ill measure the brass bushing in the morning and outter axel dia.
Dingman.
 :thumbs:
Lets see what point he has, can i just request that it doesn't go off about propaganda and conspiracies, and please leave the "crawlers" talk to a minimum.  Thanks.
BoG-ToY
Ok, I got to the point of scanning very fast through most of this BS.
This might be long and honestly sound like something that came out of Wenhar's mouth (or keyboard)
FIRST: Toyota sales propaganda; My truck says to change my oil every 12k miles I believe, while the oil salesman wants me to change it every six. Most people who buy a new vehicle, get it serviced at the dealer, so this would be profitable for Toyota to have you change your oil that often. My 2007 prius even with the higher speeds, leaner fuel ratio, and worse fuels recommended 5,000 miles between oil changes.
Second: for me, it sounds like KIRK was saying to TAKE IT TO SOMEONE WHO WILL FOLLOW THE FSM.
Third: I personally have worked on big rig trailers and trailer dolly hubs that use OIL in there wheel hubs, it actively draws heat and debris away from the bearing surface and provide fresh lubrication.
3.1 I believe CV joints do run a thinner joint
Four: I have seen a few axles that have knuckles FULL of soup with NO SIGN of grease anywhere.
4.1 I have also seen these same axle FULL of soup not leaking it out the wiper seals
I don't know what else to say, I actually tried to keep it short.
I have also seen factories do things different then the real world, like different grade bearings or rod journals using color codes from the factory, real world, we would correctly machine the part for the mass produced bearings available. So it wouldn't surprise me if from the factory these were filled with a product that may have been very popular in another country, or with a product that they were able to mass produce or that they ordered in bulk to originally fill these with. It also wouldn't surprise me if the first FSM that left the hand of Toyota technicians headed to the states contained info to fill these knuckles with grease, even if they were filled with something other then that from the factory, as grease would be what was available.
So, these live axles were produced for quite a while. I'm sure that a dealer has opened up one recently, maybe an fj80. What was inside the knuckle of an fj80 from the factory? Someone for some reason opened up a knuckle that only had a few thousand miles on it and knows what was inside that knuckle.
REGARDLESS of all this crap above.....
you need to take into consideration the following:
what is the cost and availability of this product, the usefulness of it, what benefits COULD it provide, regardless of what came in the axle.
I believe most people prefer grease. It stays put even when you pull apart your axle, when you break something it holds the broken pieces in place instead of allowing them to get into other areas and doing more damage. You can pull apart an axle, replace a part and only need to grease new parts or parts that were cleaned because of contamination. This stuff would have to be properly drained and most likely not be reused especially if a break occurred. I feel that 99% of the time I was in an axle was because of breakage, or even to mess with a diff or brakes. If I had a rig that was using a Toyota live axle to drive freeway miles with a heavy load didn't use 4wd much, and didn't use it for rock crawling (for some reason I feel like I am describing a SAS'ed chinook or dolphin that was used for an out door enthusiast to camp in)
BLAH this is too much, I wouldn't use it in something that you intentionally drive into harms way, plan on upgrading, modifying and junk like that.
Does it matter if this is what Toyota put in from the factory NO
What matters is if there would be a benefit TODAY to put this into your knuckle. Ive answered, for me it would not be a benefit.
Do I think that there is a use for this product MOST DEFINITALLY, but not on a crawler as he is actively trying to advertise this stuff too.
hopefully I can keep up on responses to my post now
86bobbedtoy
Quote from: BoG-ToY on May 10, 2011, 11:10:08 PM
being honest I think your right on target.
im sure its good stuff, for certain things
but this guy acts so weird its hard for me to be nice, and Im usually super cool
but this guy rubs me the wrong way.
dude delete all this,
and if your not into what this forum has to offer, get off and stay off!
you have brought nothing but negativity
ROCKO
thanks for the turtle point  :gap:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
Wenhar
Wow,
Okay, now while the Crawler and Wheelers may actually find something that works better than this factory Type semi fluid grease,
At least know that they are filled with this sort of semi fluid grease, and can have a soupy mess of goo in the axle that is not axle seal failure,
Wow, awesome post, and keep in mind, while my technique is odd it is effective
Now while I could go post on sites like "Edmunds Car Chat" I dont think they would know much about this axle design and or grease,
You guys know this axle, inside and out, is there a advantage to a fluid grease, or something close to a oil used in trailers, commercial vehicles and such as mentioned?
For sure,
Thank you Frank
BoG-ToY
I would still like to add that I really beleive that the less liquid petroleum on a truck the better, one of th arguments about our closing trails is the fluid contamination of leaks... well, a leaking knuckle OR a knuckle that must be pulled apart for a trail repair is more likely to contaminate our invironment if its of such a fluid viscosity that it drips off of everything that its touched.
yotaneck13
ght ieuwy iropw whei dkle urie r ejlr  ejiwj jew jwur  je jeiwjdkfkcnv  jfioew  dhjl  fjdkl; ej rl  fdl  fhjdsk  dhjk d hjkd dhjkd hjdkoie bcvh he wy fhjd fhewuiyhew fhkd eo ehewh djbkdf j hoe fhjdfh ei dhfd fe ewyey hdgjk hdjkghdsfyoe fdjkhds jkhds fhoiewh oieu dhjks hjksdoiwehwkhdsgjk g s ghdsjgkh jkshgjds gh g shgjkh gjywoieoieugds gjkf dsieo wh hfioewu whefjkd shgfjksoie whjg djf oiw dhjgf jyh fdhsjk fheoewf jkguoiewuf wefh  foiwej whefjk hjkfhweoihoiw jkh g fjoiweh oiwh g ds whjoihwe oih dhgsdjhguyruiey r ri utoiru oiew wi twioy thg fdjghfjks ghjkfdl ghjkl frgfjk gf ghjkfhowuoipw;upwq dh f ghfjklhglyruieytu jkbnvmnbxcvmnxzuih  troi dh gfhsgjk fhg jfhjkl fghj
   g ruit tryuw riwt oiwuyt wew uityewroy hds jvbb jkw idshg jkshduewy  hdsgjkhjkhr gjfsk hw tryuiwo thjgk ksy gwuytw tyuiyt uiwy dshfjkshuiwy uiewh ukhds ui iuwy rui
:thumbs:
superyota
Quote from: yotaneck13 on May 11, 2011, 09:05:28 AM
:thumbs:
I think what you meant to say was lskdfj fdjafslf lkf a lkdfklfsjklja;lsjdjfi fhghiaoi hdi  dshhs a ha oishdios hia ofh oai hfhisda hfi oa ifd aoih fhisdh rhuhia r 34t4rfgioh? :eyebrow:
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
yotaneck13
Quote from: superyota on May 11, 2011, 09:12:35 AM
yea sorry spell check must not be functioning properly i used some of this "goop" to lube it yesterday not it gets stuck :rofl:
superyota
lol!  my coworker just looked at my funny because I laughed out loud.  :rofl2:
ABD Motorsports
#4475
KK6QDW
