Author Topic: 529 Install  (Read 3224 times)
cronic 4x4
  • Turtle Points: -1
  • Member since Jan '07
529 Install
« on: Dec 29, 2010, 12:22:57 PM »
I am wondering if you guys would recommend trying to setup my 529'e myself I am not a mechanic but do all the work on my yota myself with good results thus far. I have read so many forums on installing gears in yota 3rd's and it seems easy enough but it also seems that there is no room for error. Is setting the backlash an easy or pain in the ass job. How many hours per 3rd is the average to do this job with the 3rds on the bench ready to go? If I was to pay someone to do this for me what do you guys feel is a fair price to pay per 3rd to have this done? Thanks in advance for your comments...
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: 529 Install
« Reply #1 on: Dec 29, 2010, 01:19:00 PM »
Do you have a press? Backlash is easy, pinion depth is a pain.
cronic 4x4 [OP]
  • Turtle Points: -1
Re: 529 Install
« Reply #2 on: Dec 29, 2010, 01:25:46 PM »
I have access to a press and dial indicator yes
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
Re: 529 Install
« Reply #3 on: Dec 29, 2010, 01:26:41 PM »
Best advice, read ZUK's site:   http://www.gearinstalls.com.  He even has a page dedicated to showing off the tools required/useful, http://www.gearinstalls.com/gearinstalltools.htm
Also, look for his 'cheatsheet' of common shims to use with certain setups as a starting point.  http://www.gearinstalls.com/cheatsheet.htm
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
If you see it, its for sale.
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
Re: 529 Install
« Reply #6 on: Dec 29, 2010, 02:36:15 PM »
X2, that is one of the best one i have seen!!!  Good detail!
Re: 529 Install
« Reply #7 on: Dec 29, 2010, 02:36:17 PM »
setting pinion depth is CRITICAL  your shim thickness must be within a few thousandth. and backlash also must be very close.   It takes a LOT of time.   figure yourself 3-4 hours for each 3rd.
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
Re: 529 Install
« Reply #8 on: Dec 29, 2010, 04:38:06 PM »
I set up my first third a few months ago. It wasn't too difficult if you have the right tools and know what your are doing. The more you do it the faster/ easier it gets.
As far as tools go, do you also have a in/lb beam style torque wrench? Those are really important.
I would say go for it. There is plenty of help out there if you need it and you will be able to say you did it yourself.
cronic 4x4 [OP]
  • Turtle Points: -1
Re: 529 Install
« Reply #9 on: Dec 29, 2010, 04:51:21 PM »
    I dont have the proper torque wrench you are talking about but I can buy one !!! Thanks for all the positive comments you guys got me leaning torwards trying it myself.......
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
Re: 529 Install
« Reply #10 on: Dec 29, 2010, 05:34:17 PM »
Did you look at this link? http://www.gearinstalls.com/gearinstalltools.htm
He has everything you need and links to where you can buy everything :thumbs:
Edit: What I'm talking about is the park tw-1
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
Re: 529 Install
« Reply #11 on: Dec 29, 2010, 07:49:08 PM »
i have done tons of thirds. I have all the tools i need, including the best of all, a pinion bearing that is wallered out so i dont have to press it on and off to set pinion depth.
even before i had all the "special" tools i set up alot for myself, never had a problem except for some loud gear sets....
Those are some huge welds!
Tillamook, OR
Re: 529 Install
« Reply #12 on: Dec 29, 2010, 08:14:28 PM »
a loud gear means its not set up right
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
Re: 529 Install
« Reply #13 on: Dec 29, 2010, 10:13:37 PM »
X2
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
Re: 529 Install
« Reply #14 on: Dec 30, 2010, 12:10:50 AM »
true, true, 99% of the time, there are some just plain bad gear sets out there that are loud too... but as i said it was before i had the "needed" tools and just went off tooth pattern and feel....  hell the same gears are still alive in the rear of my runner, loud and all.... and by loud i just mean a slight audible humm at highway speeds....
im not saying to do it yourself if your not sure, but im saying before i knew better, i successfully set up gears that are still on the road, and i spent that extra money elsewhere.....
Tillamook, OR
Dr Phat
  • Turtle Points: 305
  • Member since Oct '09
Re: 529 Install
« Reply #15 on: Dec 30, 2010, 09:01:14 AM »
...well if its a "bad" gear set then you correct and compensate it by setting the correct pinion depth and backlash...then its no longer noisy. Haha.
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
Re: 529 Install
« Reply #16 on: Dec 30, 2010, 09:36:13 AM »
I've probably set up about 20 8" gear sets over the past few years...  Every once and a while I've had a gear set that just won't come in with a nice quiet pattern.   We usually just put these in the front where they are the least anoying. This seems more common with the cheaper gear sets.  They still last and wear well though.
Last post Nov 21, 2004, 06:14:21 PM
by UNBREAKABLE
Last post Nov 16, 2004, 12:05:09 PM
by Roc Doc
Last post Nov 30, 2004, 08:31:36 PM
by tkrrox
4.3 install
Last post Feb 10, 2005, 12:37:20 PM
by Jase
Last post May 31, 2010, 05:53:06 PM
by OOPS
