Author Topic: v6 crawl box install and v6 twin stick install questions  (Read 2914 times)
JOE 88
  • Member since Jan '09
« on: May 25, 2010, 10:18:03 PM »
i just received my twin sticks and crawl box assemblies for my 88 v6 pickup. and i am having some troubles. i found that the addapter plate that mounts the crawl box to my t-case has clearance problems. my t-case has a cover around the input shaft. that makes contact with the addapter plate. i think all i need to do make a small notch in the addapter plate. but i am wondering if anyone else has had this problem?
My second issue is that i don't know if there is anything that i need to do to my v6 t-case in order to install my twin sticks. or dose it just drop right in. im kind of disapointed that i did not get any instructions on either of these products from marlin crawler .  if anyone has any input it would be appreciated very much thanks
88 pickup marlin SAS 5in spring ARB's F/R  Dual cases 35' BFG KM2 5.29
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
The instructions are on the tech page but to get there you have to click on the store button.
87 4Runner redo
JOE 88 [OP]
i read what was on the tech page. and is says nothing about clearance problems for my t-case. and the instructions for twin stick are for 4cyl not v6 chain drive t-case.
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Not sure what's up with the clearance issue but anytime you install twin stick you have to remove the shift/guide rail so you can remove the center detent ball. Search around you should be able to find pics of this.
R.DesJardin
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Few questions for you.
If I read this right you are putting a gear drive T-case in front of your chain drive t-case?
Did you make sure the coupler is all the way in on the tranny? They are real tight and really have to be hit pretty hard. I used a block of wood and a 4 pound hammer.
Is the seal adapter seated all the way in on the adapter plate?
Did you do the grinding on the tranny as per instructions?
Last post Sep 14, 2004, 02:07:33 PM
by Tbone
Last post Jan 29, 2006, 06:17:59 AM
by rocktoy74
Last post Nov 12, 2007, 11:17:01 PM
by cruzila
Last post Nov 28, 2007, 06:42:35 PM
by 79coyotefrg
Last post Dec 30, 2008, 09:49:22 PM
by Cheesemaker
