Author Topic: E Locker Install questions  (Read 1942 times)
Aaronm
  • Turtle Points: 164
  • Male Posts: 404
« on: Dec 27, 2008, 03:12:26 PM »
I am installing an E locker in the rear of my 87 4runner using the stock 8 inch axle housing. I have been using the info I got at http://www.4x4wire.com/toyota/tech/electric_locker/ and now that everything is ready to go together I need to get the pound of metal grindings out of the axle housing. I have been using a magnet and brake clean to try to wash and collect the peices of metal but it seems that I am not getting all of the metal shavings. Does anyone have a way that they have used before to get all of the metal out of an axle housing?
What you've just said is one of the most insanely idiotic things I have ever heard. At no point, in your rambling incoherent response, were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
Re: E Locker Install questions
« Reply #1 on: Dec 27, 2008, 03:52:28 PM »
i used a hi pressure water hose,  alot easier to dry the water out than get the shavings out with a rag
Aaronm [OP]
  • Male Posts: 404
« Reply #2 on: Dec 27, 2008, 09:19:32 PM »
Did you just blast the water through one of the axle sides? Was the axle in the rig or did you take it out?
hasbeen
  • Member since Nov '08
« Reply #3 on: Dec 30, 2008, 12:08:47 AM »
I stuffed rags into either side of my axle when I did all the grinding/drilling. Still though, I had shavings and such down into the axle tubes. i had the axle housing off the truck with everything out of it so lifting it on end and blowing it out wasn't a problem at all. I used a bit of brake clean down there as well. It sounds like maybe you still have your axle on the rig? If so it would probably be a pain to remove the stuff. See if you can borrow an air compressor with a long flexible nozzle.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #4 on: Dec 30, 2008, 09:49:22 PM »
Got a good shop vac?
Last post Nov 05, 2005, 05:03:28 AM
by Plowking
Last post Apr 24, 2007, 08:13:17 PM
by brainlessfool
Last post Nov 28, 2007, 06:42:35 PM
by 79coyotefrg
Last post Sep 19, 2009, 08:35:06 AM
by CJTownsend
Last post May 31, 2010, 05:53:06 PM
by OOPS
