Author Topic: 32/36 carb install questions  (Read 3927 times)
79yoda
  • Male Posts: 55
  • Member since Apr '06
« on: Nov 20, 2007, 01:09:14 PM »
I have just installed my weber 32/36 and it starts fine but after about a minute of running it dies and it takes awhile to get it started again.  I disconnected the fuel line and it is getting fuel.  And it is getting spark.  I disconnected all the smog stuff and capped all the lines.  The only line that is hooked up is the vacuum advance.   :inthedark:I am definitely in the dark and need help.  Thanks
I KNOW ABOUT THE JEEP THING, THATS WHY I DRIVE A TOYOTA
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 32/36 carb install questions
« Reply #1 on: Nov 20, 2007, 02:19:05 PM »
have you  screwed the mixture screw in till it stopped  then backed it out one full turn??
is this a California weber??
79yoda [OP]
  • Male Posts: 55
« Reply #2 on: Nov 20, 2007, 02:28:22 PM »
It is not a california weber on the instructions it said to turn the mixture screw till it stops and then count the turns out till it stops again the go in the middle.  My truck is a 79 20r and it was a california truck with all the smog stuff taken off.
« Reply #3 on: Nov 20, 2007, 02:40:46 PM »
no,  screw it in all the way  then back it out  1 maybe 2 full turns,  then  see how it does,  the idea is to have it IN  as far as it can go and still run
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« Reply #4 on: Nov 20, 2007, 03:57:01 PM »
2x above...  i think mine is approx 1 turn out from all the way in. dose your carb have an idle solenoid valve on the side? . . do you know what your primary idle jet size is? mine came with a .45 and would not idle or adjust. it has a .65 now and is right on for the motor I'm running now.
79yoda [OP]
  • Male Posts: 55
« Reply #5 on: Nov 21, 2007, 08:51:01 AM »
I screwed it all the way in and then backed it out 1 turn.  It started and sounded alot better but still died after less then a minute.  It is like it just stop's getting fuel?  I also changed the fuel filter.
« Reply #6 on: Nov 21, 2007, 09:08:00 AM »
ok,  sounds like you electric  fuel pump  is  either clogged  or  going bad,   drain the gas tank  and  lower it down,  pull the  unit  on the top of the tank  that the fuel line  comes out of,  you can get a  replacement  fuel pump from most autoparts stores
« Reply #7 on: Nov 21, 2007, 09:08:37 AM »
only 79's had this,   personally  i LOVE  my 79 e pump
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #8 on: Nov 21, 2007, 06:51:14 PM »
I liked my pump on my 80 being above the framerail right by the tank, but after having to change it out on the side of the road in the dark I moved it to the engine bay.  I like it much better there now :grin:
« Reply #9 on: Nov 21, 2007, 06:59:22 PM »
what pressure  does it put out Nate??
  • Male Posts: 9,757
« Reply #10 on: Nov 21, 2007, 09:45:27 PM »
:dunno: I think it's like 3-6.  I don't run a regulator and haven't had an issue with them.  I get them off our little 1600cc generators at work which run a single barrel weber.  I've yet to have an issue with pressure or running out of fuel on top, but I do plan on switching over to a holley red and running a regulator.  These little red units are diaphram units and don't last long, but the holley is a rotary vain unit and is rebuildable.
RN37DD
  • Male Posts: 742
« Reply #11 on: Nov 22, 2007, 04:56:09 PM »
I'm running a frame mount electric pump. 4-6 psi. the old frame mount was running low on psi at high RPM with only 1/4 tank. took the tank apart and found out the old pump was left in, and the relief valve above the stock pump was letting it suck air when the tank was low.
79yoda [OP]
  • Male Posts: 55
« Reply #12 on: Nov 27, 2007, 01:04:57 PM »
I know things go bad but I just changed the fuel pump about 6 months ago.  It has been sitting outside since then.  Also when you turn your keys to on without cranking it over is your e pump supposed to turn on or is it only on after it is started.
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
  • Member since Feb '05
« Reply #13 on: Nov 27, 2007, 01:39:59 PM »
Should be on with key in the start and run positions.
Time to go wheelin!
79yoda [OP]
  • Male Posts: 55
« Reply #14 on: Nov 27, 2007, 01:57:30 PM »
It's not on with it in run.  I removed the fuel line I turned it to run without it cranking and there was no fuel comming out.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
« Reply #15 on: Nov 27, 2007, 02:02:00 PM »
that pump needs to be back by the fuel tank so its pushing fuel not pulling first off thats why your burning up fuel pump i also run a filter between the tank and pump then another one up at the weber... i run my mixture screw @ 1 1/2 turns out from bottomed out...just a few little pointers i have had many many webers now and they are a pain in my ass....good luck man
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
RN37DD
  • Male Posts: 742
« Reply #16 on: Nov 27, 2007, 03:20:02 PM »
the only reason i had a fuel pump problem was that the old pump was left in the tank when a frame mount pump was installed years ago. this is mine now, but i like the way Nate has his in the engine compartment. think I'll try that. the weber i'm using was easy to tune.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #17 on: Nov 27, 2007, 03:23:57 PM »
the pump is designed to push fuel not pull..... therefore the engine compartment idea while it may be easy to service it will wear the pump out in half the time.... i would not suggest that myself but hey its all up to you...that is the same fuel pump i have too and it works great....
www.choptechfab.com
CHECK THE BUILD
« Reply #18 on: Nov 27, 2007, 03:25:26 PM »
theres a vacuum  switch  that requires vacuum,  if i remember right,  to make the fuel pump run  with the key  on the run,  i think
but  yea  sounds like your pump is bad
pump is in the tank
lal357
  • Turtle Points: -22
  • Member since Nov '03
  • are we there yet are we there yet
« Reply #19 on: Nov 28, 2007, 05:41:14 PM »
hate to hijack but its on the same line .
i just got my new motor running and there right 1-1.5 turns out . mine runs fine like that on the fuel pump my truck is a 80 and i thought they only had the pump on the engine . is the epump in the tank on the 80's also ? i ask this beciase when i did my semi flatbed i didnt see a feul pump back there .
80yota 22r 32/36 weber,header,custom bed,4.88 spooled rear Aussie front ,63" chevies,cage,yada,yada
« Reply #20 on: Nov 28, 2007, 06:42:35 PM »
only on the 79's
Last post Sep 14, 2004, 02:07:33 PM
by Tbone
Last post Dec 30, 2008, 09:49:22 PM
by Cheesemaker
Last post May 31, 2010, 05:53:06 PM
by OOPS
Last post Sep 30, 2010, 08:16:47 AM
by 307rockdog
Last post Sep 01, 2016, 10:37:26 PM
by Chinook/fj55
