87 SAS build up- new rig
Started by 87hillbillyoter, November 06, 2010, 11:49:04 PM
87hillbillyoter
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
87hillbillyoter
BOOM
http://www.youtube.com/v/fiOmuNztgkM
kinda hard to tell but it sputters quite badly when you hit the gas
87hillbillyoter
and the engine is a lot quieter in person
hansi530
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
wakkjobb
......oooooooooooooOOOOOOOOOOOOooooooooooo..........   :thumbs: :thumbs:
Lookin good; do you need a metal fan shroud and that engine-trans bracket? I may know exactly where to get one in my pile-o-parts...  :eyebrow:
>>Dan
87hillbillyoter
thanks guys. wakkjob, i could use that bracket for sure, if you got an extra one layin around! thanks man!
87hillbillyoter
oh and my charge and brake light come on at higher rpms, but then go away at idle. and she sputters a bit. hopefully i can get these issues worked out :crossed:
Zs Confederate Toy
Check your alternator. I had that same problem in mine
ZACH
87 Rock Rat X
Trail Junky
LilChief87
besides sputtering and those problems sounds pretty good wish i could hear mine run already lol
87hillbillyoter
yea figured the sputtering out. lights are still on though. cleaned up all the grounds, and im gonna unplug the battery tomorrow to see if the alternator can run the engine
Sparkplug
Quote from: 87hillbillyoter on October 22, 2011, 07:43:59 PM
NO, this is horrible, it can fry the ecu, old school way of checking if the alt works, Just plug a meter into it
wakkjobb
I found some clean engine-trans braces; do you want both sides? PM me and we'll sort it out.
>>Dan
87hillbillyoter
took her to reno tonight to go see Jason Aldean which was SICK!! i was only about 5 ft away from him the whole time. however, my throttle sticks. it sticks and then comes unstuck. its really weird. any ideas? time to search
87hillbillyoter
well she made it to chico. the throttle sticking was a little rubber boot that got cross eyed and wouldnt let the cable go back. 95% sure the alternator is fine, basically ran it to chico on it. it charges the battery, but the battery only holds enough charge to start for a couple hours. im gonna go get the battery checked sometime this week.
still cant find a good place to ground the one ground wire by the intake manifold. also there are 2 ground wires near the drivers feet fusebox, and if both are grounded, they blow the big 40A fuse under the hood. this is exactly why i hate electrical  :tantrum:
87hillbillyoter
heres a pic of the ground wires. one is white (you can see the actual grounding part in the circle) and the other is the red wire in the circle.
wakkjobb
Quote from: 87hillbillyoter on October 26, 2011, 03:40:00 PM
I still can't find a good place to ground the one ground wire by the intake manifold. There are 2 ground wires near the driver's fusebox; if both are grounded they blow the big 40A fuse under the hood. This is exactly why I hate electrical.  :tantrum:
Extend the intake wire and run it to the firewall?
If that other ground wire blows a fuse, maybe it's not a ground wire or whatever it leads to has a short? My pile had a burned wire running from the fuse box straight to a ground point. Why, I have no idea... it was just another thing to fix from the previous owner. :bat: Do you have a real wiring diagram? I may have the factory service manual for an 87; I'll check this weekend... and send that engine brace out too.
>>Dan
zebracrawler
making some progress looks good  how much longer tell its all together
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
Sparkplug
#318
the cirlce one bolts right to the kick panel, driver side, right after fuse panel, you should see threaded hole. The red one, clips into its female counterpart, looks just like it. I forget where runs, I canc ehck tomorrow.
I wouldnt be driving it around with the harness not sitting on its spots on back of dash, I dunno, im just scared of vibe, and 1 hole in that thing, and could be a fire nightmare truck killer. If they break off, just zip tie it to em
JANDO11
get it done buddy my buil shoud be coming soon so ya gotta check it out
my build http://board.marlincrawler.com/index.php?topic=88876.0
COFFIN CRAWLERZ
DFD
1988 turbo xtra cab, 3RZ, links
1985 pickup, 37 mtr
1985 4runner SR5, KINGS, LINKS, BUMPS, 40s
87hillbillyoter
:talkingn: i must not have said it was all back together. the dash is together, wires are all electrical taped to those plastic things. ill check out those ground wires again.
Quote from: wakkjobb on October 27, 2011, 08:32:23 PM
>>Dan
i do have the diagram im pretty sure, ill check that out as well. thanks guys :thumbs:
87hillbillyoter
so im still having problems with this thing.
i got a new battery, mostly under warranty so it was only 15 bucks. it started up after like a day and a half, but now it has to be jumped if its been sitting for a while, again. maybe the alternator isnt charging the battery completely? if the truck has been sitting for a while and i start the truck, the charge and brake light do NOT come on. after a bit of driving they come on again. i havent seen them with the new battery yet though. what the hell ???
also, the fuel and temp gauge used to always work, now they work every once in a while. i dont get it
superyota
Quote from: 87hillbillyoter on November 01, 2011, 01:59:07 PM
i'm not sure on the charging issue, but as far as the guages go, did you use the efi guage cluster or are you reusing the carbed cluster?  Mine didn't work when I swapped from carb to efi.  as soon as i put in the efi cluster, they were working again.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
fordh8r
What's the battery voltage when it doesn't start? Have you checked?
87hillbillyoter
Quote from: superyota on November 01, 2011, 02:22:22 PM
no, carbed cluster. but they work on and off with the carbed cluster?
Quote from: fordh8r on November 01, 2011, 06:22:38 PM
havent checked, but it is completely dead. i dont even get a flicker of the brake or charge light that come on when you turn the key. just blackness haha
fordh8r
So if you jump start it things start working again? Assuming you don't have a failed connection. If so, then something is draining the battery and meaning that it is not necessarily the alt not working.
87hillbillyoter
yep, everything works. minus the heater and the clock. those havent worked yet, i still have to figure that out.
fordh8r
Sounds like you need to start disconnecting stuff while you've got a test light hooked between the battery cable and post to see what's draining your battery.
87hillbillyoter
ill see if i can get my hands on a test light. thanks man :thumbs:
fordh8r
No problem. Hope you find the bug that killin your battery.
