Under Construction 2 "Snohman"
Started by locktup, December 19, 2004, 10:35:20 PM
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
snohman
Quote from: TONKA REINCARNATE on May 17, 2006, 09:55:35 PM
Looks great!
Now where did you get those misalignment spacers?
I got the most of the 4-link parts from Poly Performance...the SS high misalignment spacers give me an extra 12 degrees of deflection...
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
snohman
Poly performance has some nice brackets and tabs for 4-link suspensions...
the upper axle mounts are made to use any 2 5/8" wide bushing or a heim joint and 2 misalignment spacers...
a very clean and functional set up...
6.72:1
Thanks for the info, but don't let me slow you down!
[email protected]
snohman
I think the key to any 4link setup front or rear is the ability to have some adjustability...
I'll be using this upper link mount ...
locktup
Quote from: TEAM RAMROD on May 17, 2006, 09:50:39 PM
locktup when you set up links on all these trucks are you running the #s through a calculator or just going for the most triangulation and vertical seperation?  just curious they all seem to work very well
It's almost the same as the rear. But a lot different  :smack:.
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
www.LOCKTUPFABRICATION.com
6.72:1
[email protected]
snohman
I removed the tires from my Toy last nite ...I have sold the 42" Super swampers and now will be running my new 42" IROKS so it can fit in it's new Toy hauler.....
locktup
Quote from: snohman on May 17, 2006, 10:25:03 PM
That trailer looks like mine  :beerchug:.
snohman
new home for my Toy... :biggthumpup:
snohman
snohman
out with the "old"...
Ramrod
Quote from: locktup on May 17, 2006, 10:23:17 PM
ahh thanks your so helpfull
6.72:1
[email protected]
snohman
in with the "new" 42"s....IROKS....cant wait to give them a try... :yikes:
6.72:1
I hear good things from these tires.
[email protected]
snohman
#646
after reading all the info I could about 4 links,Locktup and I both agreed there is no one way to build a link suspension...there are a few basic principals I believe you  need to have to make it work..
1)links should be as flat and parrallel as possible..
2) lower link as long as possible
3)upper link 65-75% of length of lower link..
4)vertical separation should be at least 6" ...(tire size x .25 is a good place to start)
with all that said,vehicle weight,lift,tire size,center of gravity,wheelbase and many other factors all contribute to a good working suspension...both my rear and front 4 link have an adjustment on my upper links to really make it all work properly.
...I'm looking forward to ramping my Toy this weekend and see how it all works together.....
Ramrod
Quote from: snohman on May 17, 2006, 10:47:07 PM
after reading all the info about 4 links,Locktup and I both agreed there is no one way to build a link suspension...there are a few basic principals I believe you  need to make it work..
with all that said,vehicle weight,lift,tire size,center of gravity,wheelbase and many other factors all contribute to a good working suspension...both my rear and front have an adjustment on my upper links to really make it all work together...
on how the vehicle will work...
cool thanks I've been reading a ton lately and have come to the exact same conclusion and principles you just described.  Seeing as i'm moving up to rocklin or roseville soon maybe i'll swing by and check that thing out
KYOTA
Damn snohman you change your shoes more than you shorts!! :pokinit:
where ya been anyway?  :talkingn:
snohman
nice..I'm in Rocklin...stop on by sometime and check out my POS...
we can talk Toy trucks and have a few cold ones... :beer:
snohman
#650
Quote from: KYOTA on May 17, 2006, 10:54:54 PM
lol....i've been nowhere and every where in between...where else do snowmen go in the heat?
Ramrod
cool I thought you were over that way.  I just need a job and i'm there
snohman
well....after the 4-link is completed....here's my new project ...
6.72:1
[email protected]
snohman
it's a LC Engr. 22RE Stroker motor with the SDS fuel managment system.....no distributor...no funky
OEM fuel stuff to mess with...185 HP and a ton of low end torque....this motor should do the trick...
Ramrod
if you don't mind me asking how much did that run you?
6.72:1
[email protected]
locktup
Quote from: snohman on May 17, 2006, 11:02:40 PM
That had better not be the motor out of that kick A$$ 4runner in your garage  :driving:
WV4runner
Looking good snohman.
It won't fit in the trailer with 42" TSL's but will with 42" iroks?  What does each tire measure?
snohman
Quote from: WV4runner on May 18, 2006, 04:54:15 PM
it's not a height thing...but a width thing...Swampers are 15x42 and Iroks are 14x42..
most trailers are 82" width between the wheel wells...I needed the extra 2"...my front
width was about 83"..the tire change should put me right in between... :crossed:
