Under Construction 2 "Snohman"
Started by locktup, December 19, 2004, 10:35:20 PM
snohman
#720
 :eyebrow:Locktup made up a few very trick brackets to make the upper bridge unbreakable...
welded a bracket to the top of my diff cover to reinforce the bridge..a lot of very nice fab work
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
gotrocks
WOW awesome work again locktup.  What coils did you guys use I forgot if you already posted that or not.
snohman
#722
i'm using a 4" lift Jeep TJ front spring.. :smack:
snohman
gotrocks
gotrocks
oh and just out of curiousity are those clamps for the ram made out of aluminum?
snohman
steel clamps on the ram... :o
gotrocks
I was hoping that they were but they just looked so shiny.  I didn't sey why or how aluminum would ever be used on a setter part especially something holds the ram
6.72:1
I mean, really, after looking at the photographs this time...GOOOOHHHHHH!!!! - Billy Madison.
Wow, just wow.
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
locktup
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
Loosekannon
F'n A.. Cotton.....F'n A..
That looks damn good Snohman, good work Locktup. Wish I lived closer to you guys to get some of that work done to my truck. Just have to do it myself :smack: Looks real good, can't wait to wheel with you guys again :driving: :thumbs:
snohman
now that the 4 link front is nearly completed,i'm going to need some serious horsepower..I started to pull all the parts and pieces off my old motor...
snohman
pulled out the radiator,headers,propane system and everything else that's gotta be removed
snohman
not much left but the long block
snohman
planning on removing the engine next week....the engine and propane are for sale if you know anyone that is looking..
motor has about 15k on rebuild..30lb flywheel,header,complete propane system,runs very well....off road only,it has no smog..1983 22r..$1500 complete..
yotadork83
i will buy sigh me up what do you want to save it
yotas 4 life homie!
yotadork83
sorry about that i cant type when i am excited i realy want that setup i can give you money friday until i can pick it up
yotas 4 life homie!
snohman
it's yours if you want it....i'll hold it until you show up with the bling :twocents:...consider the motor and propane set up yours... :yesnod:
yotadork83
do you still have that 20r head and intake, or are you going to use it on your new motor
yotas 4 life homie!
snohman
Quote from: yotadork83 on June 08, 2006, 09:04:33 AM
I still have the 20r head as well.....i'll make you a deal for the whole package if your interested...
let me know..
josho
snohman
well.....spent the last three days in Capitola(near Santa Cruz)partying,eating and drinking :yikes:.not sure at this point in what order all things were done.lets just say I spent alot of coin and had a great time with Mrs.Snohman and some good friends.....weather was perfect and the girls all so beautiful.. :yesnod:
looking forward to a good week of putting the track back together and getting some things done... :help:
Willy Mammoth
Cool, makes me want to do mine next.  4 link and coils that is. I guess I was a page behind  :slap:
6.72:1
[email protected]
speedemon
#744
Quote from: snohman on May 24, 2005, 11:30:00 PM
had to upgrade the rear suspension as well....whats a 9" without coilovers..?
still will be running a 4 linked rear but will be using the sway away 14" coilovers..
hope to have it all done by july....... :beerchug:
just curious, why didn't you end up using the swayaways.  that is what i was gonna run.  i am in the beginning stages of my buildup http://board.marlincrawler.com/index.php?topic=24190.0.  BTW badass truck man.
2002 Tacoma sold
'84 pickup SOLD!!
'83 pickup will rise again
'86 sas runner DD
'89 runner project (for sale)
F-Toy build in progress
snohman
Quote from: speedemon55 on June 13, 2006, 05:27:41 PM
I ended up trading the coil overs for the full hydro steering...good move on my part as the steering is the best thing I have done to my Toy...coil overs can be a nitemare to adjust,are expensive and tend to "unload " on sidehills...I really like the way the rear coils have worked and so i decided to do the front the same way ...hopefully with the same performance...
snohman
well....removed the front tires,lowered the truck down to the ground and took out the "old" stock motor... :thumbs:
snohman
engine compartment is empty :yesnod:
Casey105 and myself had the old motor out and the "new" one installed in about 3 hours... :yupyup:
snohman
I found a used "turbo" flywheel and installed it with a new clutch and pressure plate on the new stroker motor......the clutch is a little bigger on the turbo .. :yikes:
snohman
installation of the new flywheel and clutch assembly was done by "Mr. Clutch" himself..Casey105 :bowdown:
