Under Construction 2 "Snohman"
Started by locktup, December 19, 2004, 10:35:20 PM
locktup
This is another truck im working on. Before.  :rivers:
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
locktup
#1
During  :flamer:
locktup
1
TrackVino
Wow, thats some cool tubbing. What type of bender do you have? Im interested in getting one for my own stuff :biggthumpup:  :biggthumpup:
locktup
snohman
#5
 :flamer: well......I got the beast home and started the "clean up" portion.....cutting,grinding & sanding.....
Lockd'up does some fine bending....I'll post up when I get some more done.....thanks again J.......snohman :beer:  :thumbs:  :drooling:  :bowdown:
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
snohman
 :shocking: here's what it was after the roll.......ouch.... :smack:
snohman
yes...those are 42" swampers.... :reg:
TrackVino
Isnt EZ Bend software, or do they also make a tube bender? Do you have a web link?
To The Floor
what is all the red stuff around the welds and what purpose does it serve.
dirtbag
Quote from: TTF Fabrication on December 21, 2004, 12:14:56 PM
looks like primer, so it doesn't rust
Mike D
On reply on pic 4 is the bucket your seat  :gap:
snohman
the red stuff is glazing putty....fills small holes & cracks.....works great....easy to sand...
fills voids and small holes around welds...
snohman
snohman
Quote from: Mike D on December 21, 2004, 06:56:08 PM
yea.......had to sit on something to get it on the trailer....thinking about bolting it down permenately....
dirtyskivies
Quote from: snohman on December 21, 2004, 07:09:35 PM
WTF????
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
Casey105
HEY SNOHMAN,,,NICE REPLY ON THE SEAT........TELL YOUR PASS TO USE HIS SEATBELT NEXT TIME!!!!!!!!!
LOCKTUP FAN CLUB
http://www.locktup4x4.com
Casey105
I THOUGHT THIS WOULD HELP  :haha:   :haha:   :haha:   :haha:
LOCKTUP FAN CLUB
To The Floor
I've never heard of anyone using spot/glazing puddy around welds. being in a body shop at school i've used the stuff, but never on welds.  if you've got holes in the welds you usally want to grind em down and burn some new ones don't you?
brainlessfool
I've used it on small pit holes on welding to. don't use it on a hole that needs to be fill, butt just so the paint goes on smooth!  :yupyup:
MOOSEKNUCKLE
IT LOOKS LIKE HE IS ONLY USING IT WERE THE TUBE WAS CUT/SLEEVED/WELDED/GRINDER BACK TOGETHER! ALL IT IS DOING IS SMOOTHING OUT THE DISTORTION/PIN HOLES FROM THE GRINDING, SO IT WILL BE :bling:
ME LIKEY (.)(.)
locktup
#21
Its just for filling pin holes and dings in the tubing, once its sanded down you wont even be able to see it. It just makes the finished work look nicer. For some reason I was having a hell of a time bending the right side of the truck so I sleeved it.
Casey105
LOCKTUP FAN CLUB
snohman
#23
 :santa: hope you all had a merry christmas....Santa was very,very good to me.....lots of bling bling parts for the Toy...
actually got some work done on the truck today....sanded and painted most of the interior..nice to see some color on the
inside...the donor cab(back half) was from a 82 Toy(it was blue)
snohman
 :yesnod: I also cleaned up the rear removing brackets and tabs....looks much cleaner...
snohman
 8)  :hammerhead: also bent up some 3/16" checker plate and made up a box for mounting my 2 optima's below
my tool box...tack welded it in and should work well.....
snohman
#26
 :shocking: now i'll wire up the Wrangler relay and I should have both battery's charging and ready to go....
time to call it a day...... : :sleeping:
snohman
accomplished a few more things today...finally got some paint on the exo...... :help:
snohman
more color.... :beerchug:
SWAMPER
