Under Construction 2 "Snohman"
Started by locktup, December 19, 2004, 10:35:20 PM
0 Members and 6 Guests are viewing this topic.
snohman
I'll try and get the whole frame & exo primered tomorrow... :smack:
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
locktup
Come on LAZY, lets see some paint.
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
snohman
ok...ok...ok...i'll give you some color...I got the first coat of primer on ..
snohman
got some color on my rear housing as well...
snohman
Hopefully get a second coat on and finish the sanding this weekend...then comes the real paint
locktup
6.72:1
Wow. Such excellent work. Awesome truck.
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
MUDDONKEY
72 fj 40, too bling bling to wheel
76 fj 40 rotting in my backyard(parts)
85 xtracab-bored 30 over, dual cases,arb's,5.29'S, 35 TSLS ,partial exo, onboard air, UNSTOPPABLE!
07 FJ, 4" WE/Donahoe, 33/12.50's on blk procomps
snohman
#279
The "Toy" is coming along slowly but going in the right direction.I painted the entire new section and used about a 1/2 quart of paint. :flamer:
I also finished the Currie rear end and painted the entire housing and 4-link components.I'll be reinforcing the tool box to accomadate
mounting the 10 gallon propane tank.That tank is a beast.I've ordered the  brake lines and all the new parts to make the  braking system work well.I need to install the FJ-80 master cylinder to complete the brake system.Just a bunch of small things to finish the truck.
snohman
I'll be remounting the Warn winch in the rear. :yikes:
locktup
We gotta go out before the snoh gets to deep.
snohman
#282
 :joke: are you kidding me...?...you know how it works... :screwy: NO hill too steep.....NO snow too deep...lets go... :sheerterror:  :driving:
snohman
#283
well.... :sneeze:  :yikes: got the rear driveline done today...square tube .250 wall....almost indestructable.. :yesnod:
turned down the Toyota splines for a nice fit...I used a Turbo 400  auto trans yoke for the other end..
snohman
#284
it's a very tight fit..I'll be tapping it to install some zerk fittings to keep it greased...Spicer 1350 u-joint of course..
6.72:1
Dude, that is awesome. Did you do your driveshaft like minisimp, except for the obvious change in yoke? 2.5" X 2"? If the larger is 2.5", is it just called "receiver hitch tubing" that doesn't have the weld line in it or down the middle, or does that kind of tubing have another designation? I have problems finding that type of square tubing around here. I don't know if I am asking for the incorrect type, or people from the south haven't heard of that before. lol
[email protected]
snohman
#286
Quote from: BIGTONKA on December 01, 2005, 12:58:53 AM
.....ask for seamless square tube..you'll have to find it at a steel/metal supply buisness..more expensive,but the only way to make a good square driveline..I don't however, reccomend it for street use..OFF-ROAD only.square tube will not balance out and wipe out your u-joints.much stronger than a round wimpy driveshaft and much less expensive..I'll be carrying a extra "short"square shaft so it can be used in the front or back of my Toy..
snohman
#287
you can see my front driveline is also square....the only way to go... :dunno:
BoMXtreme
Quote from: snohman on December 01, 2005, 10:07:28 PM
Thats what I was going to say.  is it possible to balance a square shaft?  I have a square front drive shaft and i have drove it in 4x4 up to 35mph and it wasn't fun.
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
There is a thread about balancing a square drive line that was posted not that long ago.
locktup
gotrocks
I've got a square driveshaft and i don't mind it to much.  Its only the front but I will have to admit it pretty much is indestructable.  Way to go guys you built a really stout truck.  How do you think those 42's will do in the snow?  I wouldn't guess they would do to hot.
Jeremy
what kind of rear coils are those looks SWEET!!!
snohman
Quote from: Hyena on December 02, 2005, 06:22:17 PM
it's possible..just not practical..
snohman
Quote from: gotrocks on December 02, 2005, 11:24:00 PM
I've got a square driveshaft and i don't mind it to much. Its only the front but I will have to admit it pretty much is indestructable. Way to go guys you built a really stout truck. How do you think those 42's will do in the snow? I wouldn't guess they would do to hot.................they'll work as good as any other mud tire..
we'll soon find out...at 3-4 psi i'm sure they should work great...there 15x42 so have a wide footprint...
they should float on top fairly well and i have modified the tread...
snohman
#295
Quote from: Jeremy on December 02, 2005, 11:50:01 PM
I got the coils from Rock Equipment...they are soft and flex very well
KYOTA
:pokinit: Lance wud that axle set you back? the bling po po wanna know  8)
snohman
#297
Quote from: KYOTA on December 03, 2005, 11:22:00 AM
shirt Lance wud that axle set you back? the bling po po wanna know 8)
....Currie extreme duty housing w/upgraded 35 spline axle package                  $1589.95
                Currie high ground clearance option & skid plate                                      $149.95
                Currie fill & inspection cap mounted                                                       $59.95
                Currie Pro 5:83 R&P w/Strange Nodular case & spool/1350 billet yoke         $1255.95
                Currie/Ford 11" SVO explorer brake kit                                                   $399.95
                going 4-wheeling and having a unbreakable  :bling:  rear end......PRICELESS!!!!!!!
locktup
You should hurry up and finish painting that thing. The paint will help hold the JB Weld together   :smack:
gotrocks
hey you got the same tire groover I have, how do you like it.  I absolutely love mine.  How'd you groove your tires.  from one of your pictures if looks like you only took out the middles in the center lugs.
