Under Construction 2 "Snohman"
Started by locktup, December 19, 2004, 10:35:20 PM
snohman
yea....looking good... :beerchug:
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
snohman
I hooked up the Warn 8000 in the rear to my new dual battery system...and
added a rear stop/running light so I dont get rear ended while nite driving..
snohman
put on my high lift jack to finish up :yesnod:  the rear...
snohman
put on my new emblems.... :eyebrow:
it's only right that it's now a 1 ton...
snohman
#154
last one......I'll finish up the interior tommorrow...
have to install the in cab roll cage and TRD seats...
and a little more wiring......bought a bunch of relays to be able to run my
lights all nite long without worrying about burning out my switches...
just a little rewire and it's all good...
KYOTA
Nice touch with the 1 ton emblems, dont scratch the paint on that perty xo  :greengrin:
Casey105
LOCKTUP FAN CLUB
http://www.locktup4x4.com
snohman
right after the rollover... :help:
snohman
today.....looking much better..... :thumbs:
thats why i need a exo... :beer:  :hammerhead:
toyhunter
All I can say is BAAAAAAAAAAAAAADD ARSE :yesnod:  :yupyup:
Everyone starts off in life crawling but lots of us grow up and still are crawling around everywhere
gotrocks
quite impressed I'd love to see it in action
Yota4life
where did you get the fog lights on the front? By the way it looks bad arse! :best:
scheid6996
ya man ur truck looks awsome, good job, gold star 4 u
Its a redneck thing
"Nobody Loves Me"
locktup
#164
Come on already let see the  :bling: :bling: Oh Yeah its on like Donkey Kong at the Hammers :beer:
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
iNfErNaL
Lookin' real good. :cool: ,very motivational too.I'll be out at JV in two weeks as well.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
FATB0Y
man that turned out awesome :thumbs:
snohman
#167
well....I've been completing the little things the last 2 weeks or so.....truck coming along nicely...
I found a very soft set of front leafs and removed my ol Rancho 44044's.....i did a little research
and found the 44044's have about a 300 lb spring rate...a little stiff for rock crawling and too much
arch....went to the new springs with a very soft 180 lb spring rate and a very near flat spring.....
should prove to work very nice....it also lowered my truck approx 3 inches in the front and should help
with a lower center of gravity and less body roll...it did however also shorten my compression on my frt
shocks to only 4 inches and i had to relocate the hoop mounts lower to increase the compression travel
back to approx 5-6" inches with 8-9" of droop....i had also been looking for more power and a better
running engine...EFI motor was a consideration but too much work to install the computer and harness
and fuel system....besides my 22r carb motor has only 15k since the rebuild and runs very strong.....
so a call to Gotpropane.com was made and a very sweet propane conversion was in order....
had a few minor problems (as all mods go)and the propane kit was installed and now runs very
sweet... :yesnod:
snohman
installed some new bump stops as well and relocated them forward 2" ...
snohman
mounted the propane in the rear basket...
snohman
rear shot of tank..
snohman
engine compartment...
FATB0Y
snohman
#173
Why propane....?....1)engine will run at any angle...even upside down...no carb...
                            2)propane has 110 octane...more power...
                            3)will auto adjust for altitude....
                            4)engine runs cooler and cleaner...no carbon.......less oil changes...tune ups..
                            5)I get propane for FREE from work....!!!!!!!!....have you seen gas prices lately..?
snohman
FATB0Y
Quote from: snohman on April 07, 2005, 10:26:27 PM
Sound like the :pokinit: TTT :thumbs:
snohman
I also put in a "OH :pokinit:" bar for my weak knee'd passengers when things get a little dicey... :scared:
FATB0Y
Quote from: snohman on April 07, 2005, 10:30:44 PM
Hey if nothing else if they piss you off you can always slam on breaks and knock out their front teeth  :gap:
FATB0Y
Oh BTW your rig is looking sweet :thumbs:
lilbuddy
Sweet rig. Its looking pretty beefy
If you dont mind me asking, how much did that conversion kit run ya? I looked on one of those websites before and you had to order a flier and then call or something.
RIP Kyota.... you are the man
GET IT!!!
