did you top off the crawl box up through the top where the shifter mounts? sounds like it was running dry
First thing to do is get some pics of it. And post them here in your post. Good pics, not crappy ones.And then call Marlin and talk to those guys there. They can help diagnose what happened. That will be your best option at this point! Sometimes its hard to get them to reply to the forum, Brendon does try to check the forum, but it usually is on his own time.
...why buy when you can build?
did you not see the pics dam man pesistent no they had oil in them and hey maybe you are party right i had used the wrong gasget maker so some might have leaked out and that my have ben part of why this bareing failed but i think the main cause for failuer here was that this bareing just needed replaced it was bad and overused.the bareing roller race blew but from what i can tell that bareing blew firse allowing the gear to wander around and cause the needel bareing to fail but and the gear to strip. i took out a lot when i removed the cases. the main roler bareing was bad can you not see that from the pixs in the cralw box i put in was bad dident know it at the time
did you not see the pixs dam man pesistent no they had oil in them and hey maybe you are party right i had used the wrong gasget maker so some might have leaked out and that my have ben part of why this bareing failed but i think the main cause for failuer here was that this bareing just needed replaced it was bad and overused.the bareing roller race blew but from what i can tell that bareing blew firse allowing the gear to wander around and cause the needel bareing to fail but and the gear to strip. i took out a lot when i removed the cases. the main roler bareing was bad can you not see that from the pixs in the cralw box i put in was bad dident know it at the time
theres a really good reason i asked that question, because the oil will not run thru to the front bearing before it gets hotunless you dumped 1 quart of gear oil in the top of the front crawl box it didnt have enough oilwas this a second hand crawlbox??again wheres the pictures of the adapter??
yes and yes it was a second hand
Started by SeaBass44 Rigs For Sale
Started by 85yoda Toyota Pickup/4Runner Tech 1979-95
Started by Birfailed Project Research and Build-Ups
Started by ARSmay Toyota Pickup/4Runner Tech 1979-95
Started by swimmerzack « 1 2 » New Member Check-In!
