Sounds like a good place to make a thread to hold all the stuff you want to sell, want to buy, want to trade locally here in Colorado.I've got an 85 W56 5-speed transmission from a 4Runner that I'd like to get out of my garage for $150. I've never installed it nor driven it so I can't tell you it's history. It was pulled from a parts truck I had 3 years ago.
i have a 89 ifs rear axle for $100 the 4.10 3rd has a bad bearing
im not sure but could i just swap my third over to the ifs axle or do i got to get a new third build if i can sway i may take you up on that but im a little short on funds right now
i might want that trans from you is it a forward shift or top shift also if anyone had a ifs rear axle they want off there hands let me know
your 3rd will bolt right in
85 W56's had top-shifts behind them. i will take the trans too but same problem
IronClad: If I wanted to hold hands and be nice I'd become a hippie.
Wanted:-R150F and T-case-Clutch pedal assembly-clutch master cylinder, slave cylinder, and hardline-3.0 3vze radiator-and any line someone has on a 3.4 5vz-fe motorI got a new toy
Oooh.... what'cha get? Did you sell your red truck? There's some 3.0 radiators at the yard if you need; I can pull one if you can't find one elsewhere. Might be some 3.4s also; I'm going tomorrow so I'll check.
Started by hossjs Rigs For Sale
Started by 86turboyota Rigs For Sale
Started by Birfailed Rigs For Sale
Started by hilux-1983 Rigs For Sale
Started by bkn Rigs Wanted!
