No lift high steer
Started by jrock, August 12, 2009, 01:37:40 PM
jrock
jmac
Don't get that thing hot or you may be pulling it for a gasket.  I'm very interested to see how all this goes.  I'm thinking about it also.  Please post some pics if you do it. :beerchug:
jrock
Thanks for gasket thought.  :thumbs:
studentwheeler
When is the high steer build going to commence? I'm excited to see how it is done...
jrock
TRACKER
i have very little lift  with hysteer . i also mount the box straight up with flat pitman arm pretty close to the frame
Pride - is what drive a man to do his very best even when no one is looking ..
jrock
That's about right. I think you have just a bit more lift than I but that's about it. My box ill be higher up and farther forward.
What frame brace did you use? or make?
4x4yota
here is my high steer swap... did it with stock rears +1 leaf and a flat pitman arm and sky boomerang shackles
Current:
Sold:
studentwheeler
Quote from: 4x4yota on September 13, 2009, 10:48:48 PM
That's my exact spring/shackle set up. I just bought my hi-steer so I'm glad to see that this is possible!!!
jrock
#39
4x4yota, I think you may be missing a bolt.  :cheese:
We have a winner, that looks to be about it.
4x4yota
#40
Quote from: jrock on September 14, 2009, 08:16:16 PM
4x4yota, I think you may be missing a blot.  :cheese:
yeah I had to run to get on I couldnt find the one I had
glad I could help
the only issue I have is I need longer bumpstops since Im useing the stock shock mounts  the shocks Im ussing to acomidate the travel bottom out with 3" of up travel and the spring contacts the pitman arm within the same so I need 3-4" longer bumpstops
Current:
Sold:
jrock
How do the draglink and tierod act under compression and droop? Any hitting or interference? \
And how is your steering? How bad is the angle on your steering shaft?
4x4yota
no contact or binding at all the setup I did is perfect my steering shaft is at a greater angle then before but no binding its really perfect for how it works I can get better pics... (give me a few)
Current:
Sold:
4x4yota
I only ended up with about 3" of lift total
ride height
front droop
Current:
Sold:
MiniSimp
Looks kinda high...
4x4yota
its a stock rear pack out of a 82 4x4 with the 4th leaf out of a rancho 3" front leaf pack as my 4th leaf
Current:
Sold:
studentwheeler
Quote from: 4x4yota on September 15, 2009, 06:01:39 PM
More pic of the exact box location etc would be appreciated. Your spring set up is exactly what I am running...really happy with it so far.
4x4yota
#47
ok I get box pics tomorrow
the rear lower hole is just thru the factory hole drilled out to .5" then to drill the front hole I just rolled the box as far forward til I had about .5-.75" between the frame and pitman/tierod
Current:
Sold:
4x4yota
found these pics so here you go... I did roll the box a lil more forward than this these were just at mock up
Current:
Sold:
studentwheeler
Ok thanks. That gives me a good idea. Did you have to cut anything up front to make it fit in that location?
That's a good setup you have there.  You'll still have room to drill the perches to move the axle forward later. :greengrin:
4x4yota
Quote from: studentwheeler on September 15, 2009, 10:42:17 PM
:shhh:
I had to remove my front bumper and trim about .25" from the bracket (not big deal) and had to cut the track bar bracket off to clear for my .25" plate but it was a easy full days work with the right tools... I made my own IFS bow mounting kit for $15 out of 2, 4x8" .25" steal plate and sch40 pipe
Current:
Sold:
4x4yota
#52
here is how the truck is now my final setup... I still have room to move my axle forward if I ever do a drop hanger or different springs
Current:
Sold:
Looks good.  I wouldn't get too worried about a drop hanger but a replacement for the stock spring hangers I can get behind 100%. :greengrin:
Is it just me or are the splines on your steering box twisted?..   :eek:
BUDDERS
Quote from: WHITE_TRASH on September 17, 2009, 02:16:56 PM
I spotted that too after you said something....WTF?  I've never seen that before on a steering box, but then I guess they get that way before the sector shaft breaks.
BUDDERS
Why do all the instructions say 0.5" to 0.75" clearance between the tie rod end and the frame?  I wonder if it is for oil pan clearance on the drag link for when it is flexed out?  It's not like the tie rod end of the pitman arm is gonna move any closer to the frame when the mounting brackets are welded in.
jrock
Movement of the tie-rod end when the passenger side moves up and down?
If it's needed, that's when I will notch the frame.
4x4yota
#57
my tierod/draglink dont get close to my frame or oil pan so not to worried but I notice the splines were twisted after I fulled off the old pitman arm... should I be worried?
Current:
Sold:
I'd change it out personally...  It might last 50 more years or 5 miles, ya never know with that sort of thing unfortunately...
jrock
4x4yota, check your wording again. It seems to be a bit off.
I would change the box, just to be safe. I think there is one for sale on the board right now.
http://board.marlincrawler.com/index.php?topic=40649.0
:beerchug:
