And you used RUFs. How much distance is there between the tie-rod and the drag-link? If they where both level.
Andy, I dont "Pull Out" Tyler is living proof of that.
Look here. http://board.marlincrawler.com/index.php?topic=68014.0http://board.marlincrawler.com/index.php?topic=67568.0My last trip.http://board.marlincrawler.com/index.php?topic=67001.0
yes, it has the stock shackles. I may get longer ones depending on how much I hit the oil pan. it looks like on articulation it will clear fine but strait up travel could be a problem untill I put bumpstops or get a bit more room up front.I either plan to redrill my spring perches or running stock rear main leaves in the front.
Started by Phazertwo Toyota Pickup/4Runner Tech 1979-95
Started by hiltu Toyota Pickup/4Runner Tech 1979-95
Started by R.DesJardin Toyota Pickup/4Runner Tech 1979-95
Started by anarchy joe Engine
Started by jmac80 Suspension
