No lift high steer
Started by jrock, August 12, 2009, 01:37:40 PM
GotMyYotaBack
That axle is begging to move forward!  :bowdown:
Trekker Build- http://board.marlincrawler.com/index.php?topic=64943.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
So dont tell me I spelled it wrong! You knew what I ment.
SolidAxle
i know. i've got to put braided lines on the front and upgrade to an 80 series master cylinder so when I have those ready to go in i will pull the axle out and redrill the perch so i only have to bleed my brakes once. truck won't be back on the road till mid april anyways. not theres any trouble with driving it on the street how it is.
MiniSimp
Not bad, looks like you are as low as me. :thumbs:
SolidAxle
Quote from: MiniSimp on March 18, 2010, 11:20:37 AM
Thanks, I watch you build alot, i'd like to keep my truck as low as possible. when i was mounting the box i went through your build thread to see how you mounted it. TOOK FOREVER TO FIND THE PAGE lol.
4x4yota
found this on pirate
http://www.pirate4x4.com/forum/showthread.php?t=761084&highlight=lift+highsteer&page=4
and also look into these to clear teh tierod better
http://www.4crawler.com/4x4/ForSale/MotorMount.shtml#MotorMount
I myself could raise my motor about 1" with out a body lift but my tranny/tcase is another story
and these to relocate your axle I bought a pair and they work great
http://www.sky-manufacturing.com/new/detaproduct.php?id=80
Current:
Sold:
SolidAxle
Im concerned that if i move my axle forward my driveshaft wont have any extension.
have you had any troubles like that.
I really need to move it forward.
Shawn.
4x4yota
I moved mine forward 2" and just took 2 female slips and made one longer one works great
Current:
Sold:
MiniSimp
SolidAxle
Quote from: MiniSimp on June 01, 2010, 09:50:04 AM
Square.
i would like too but i dont want to go through the trouble and have to do it again when i get duals. plus it will get driven a bit with the hubs locked. I've contemplated it many times.
Quote from: 4x4yota on May 31, 2010, 08:41:49 PM
got any pictures? how did you keep it even?  i have a spare ds sitting in my bed right now. this sounds like a pretty good idea. Are you concerned about your welds breaking?
SolidAxle
F it. bought some square tube today  :greengrin:
NorCalToy
Quote from: SolidAxle on June 01, 2010, 02:29:36 PM
My square shaft is good to about 45 before the vibes get too bad to go faster. For a $25 shaft tahts not too bad.
:flamer: IFS
4x4yota
my welds are strong and not worried at all I kept it straight by putting the mail splines inside to keep it aligned
[/quote]
Current:
Sold:
SolidAxle
that does look like ut would work.
i like the idea of have i stronger shaft with more travel.
the guys at the steel yard thought i was nuts hahahaha
KDXSR5
So who are you all using for flat pitman arms? I am thinking about doing this, but the Sky arm I have been looking at has had some strange reviews concerning it being too short. Are you guys making your own frame plates/steering box mounts? Or buying them? Just curious. Thanks.
jrock
Quote from: KDXSR5 on June 14, 2010, 10:45:57 PM
TG flat pitman and frame plate.
