4x4yota's 81 4x4 build
Started by 4x4yota, August 08, 2009, 06:42:35 PM
pumkin toy
I would just go with the stock replacement.  You arent running high HP or anything, and it will hold fine even with dual cases.  I ran a stock clutch in my rig for years and it was fine. Plus if you have dual cases and 4.7 gears, then you will never be riding the clutch at all while wheelin.  The best way to clean your block for painting is to have it "hot tanked" at the machine shop.  That will completely clean off all the grime and give you a clean surface for paint.
97 4runner Limited
4x4yota
and another question... is the LCE adjustable came gear worth the $100 for a stock rebuild engine... Ive been told its great ether way especially at high altitude and if the block is decked or the head milled bt if I do it I would have to use a electric fuel pump instead of a mechanical pump
Current:
Sold:
pumkin toy
I cant say whether the adjustable cam gear is worth it or not, I would be leaning towards no.   I dont see why you would ever need an electric fuel pump though, thats for sure.  I built a hybrid 22r/20r   bored twenty over, bigger valves, port and polish, header, holley intake manifold, weber carb and a few other extras. The stock mechanical pump was just fine and I am at 4500 ft.
97 4runner Limited
4x4yota
Im at 8000+ feet in CO... I have decided against it atleast til I do a cam but I do have headers and a weber but will prolly stick to the stock carb to save better on gas...
Current:
Sold:
4x4yota
so I got my new motor built and it is ready to drop in
bought the kit form engbldr.com
block bored .020 over
polished crank
also did steal timing chain guides
and the block/head didnt need decked or milled
heres the block
the crank
here are some of the build
Current:
Sold:
4x4yota
and here is my resurfaced flywheel
Current:
Sold:
CrazyYota
The engine is looking good.  :biggthumpup:
axled89
nice how's it run?   any probs.
i love oregon wheelin.
4x4yota
its not in yet... in the process of tearing out the old motor and swaping over the accessories (PS pump, ALT, distributor, motor mounts, intake/exhaust... then once I get it running Ill install my headers and then make an custom 2" exhaust also going to be swapping in my spare G52 I have since my stock tranny is only a 4 speed and with my axle gearing I need 5th for highway
Current:
Sold:
4x4yota
#189
got the motor finished in inot the truck today took all day yesterday to get the old motor out and clean up the old parts and swap them to the new motor still need to finish bolting down the motor mounts and work on the crossmember but it looks like I will be ordering my bud built crossmember sooner than planned
old motor/tranny
new motor/tranny
Current:
Sold:
4x4yota
so since Im starting over on the truck thought ID start a new build but I will continue to post here
http://www.pirate4x4.com/forum/showthread.php?t=876380
Current:
Sold:
yoter4x4
lookin awesome man, i just finished my motor swap a few months ago. better than replacing headgaskets and sh*t all the time.
Bullets don't know the difference between race, sex, or gender.. They Just Feed On Flesh!
4x4yota
the G52 blew up on me today 4th gear went out and cant use reverse unless the motor is turned off. so I drained the oil and there were decent size pieces of metal shavings on the drain plug and the oil smelt burned. the t-case is ok but some one welded the fil plug close for some reason so I couldnt refill it. after all that I installed my stock tranny back in the truck today along with my good top shift t-case...
so now my debate is taking my other tcase and buying a dual adapter and installing dual cases while Im worknig on everything else? or just hold off and sell the case? my 3rd option is to buy 1 piece at a time and do the duals later... my reason for not just doing it is because I dont go 4 wheeling enough to require dual but when I do go I do like a challenge and wish I had duals so I wouldnt ride my clutch so much and could crawl a lil slower to smooth out the ride...
what tools are needed to build the crawl box? anything special or just basic hime mechanincs tools?
Current:
Sold:
4x4yota
so I caved and ordered the dual adapter and crossmember cant wait to get it and install it the wife gave me the go ahead since ive been talking about it for years and now can go for it so I hope its everything that they are made out to be I am always needing lower gears when Im out crawling I regeared my axles last year to 4.56 V6 3rds and thought that was enough til i went to 33s and now its like stock so dual cases will help on the trail and at work
Current:
Sold:
CrazyYota
Quote from: 4x4yota on May 04, 2010, 04:55:37 PM
jealous! :gap: what transmission are you going to use?
4x4yota
Im using my factory L45 til I can get an L52...
I ordered the top shift conversion so I can use the forward shift off the G52 that blew up on me also scored some other pieces from the bone yard
Current:
Sold:
CrazyYota
its good to have spares.  :yupyup:
4x4yota
Current:
Sold:
pumkin toy
you will love the dual cases! They are deffinately all they are made out to be.  Once you get used to the dual cases, you need to drive a rig that has duals with 4.7's in the second case, you will think your stock duals suck! ha ha
97 4runner Limited
4x4yota
yeah I cant wait to try it out and crawl things lol... any idea how much longer it will add to my current drivetrain so I can get started on my spare driveshafts to cut down to the right length so its all ready to go as soon as I buld my crawl box
Current:
Sold:
zembalayan
Nice!
You are gonna love having duals for sure.  That thing will be a tank with 33s and and 4.56 gears!
pumkin toy
Quote from: 4x4yota on May 04, 2010, 11:08:08 PM
I dont remeber 100%, but I think you will have to add 8" to the front and subtract 8" from the rear. If I were you I would wait until the cases are installed to measure for driveshafts, that way you know they will come out right.
97 4runner Limited
4x4yota
so today I got more done on the truck tore down my spare t-caseand got it all ready for my dual adapter, replaced both front spring pins since one was broken and the other was none existent, and also installed high steer, so if anyone asks if it is possible to run high steer on a stock truck tell the yes. All I did was move the front axle forward 1" to keep my tire out of my fire wall and to help clear the tie rod/oil pan, and added a 1" longer shackle to replace my POS stock shackles... now just need to mount the IFS box
Current:
Sold:
4x4yota
Quote from: pumkin toy on May 05, 2010, 03:59:46 PM
I was told that a complete crawl box adds 6.5 inches so I took in my drive shafts and had 7" removed fromt the rear and 7 added to the front hope it works it would suck to have to do it again prolly should have waited but I have to have alot of it ready by this weekend since I leave for a week for work and then return to finish packing and move
Current:
Sold:
pumkin toy
yes the crawl box adds 6.5" because thats how deep it is, then you have to add the thickness of the adaptor to that. So you have another 1.5 to 2" on top of the 6.5" crawl box.  hopefully the drivelines work alright for you
97 4runner Limited
4x4yota
my crawl box only measures 4.25" so I assume the dual adapter is 2.25" to get 6.5" I could be wrong but on the trail-gear website it says an assembled unit is 6.5 and I remember reading somewhere on marlin here the same thing
Current:
Sold:
pumkin toy
yeah that could be true, I thought the crawl box was bigger than that
97 4runner Limited
4x4yota
Quote from: pumkin toy on May 06, 2010, 10:04:30 PM
so did I but when I measured it it was only 4.25"....
any ways I added high steer back on my truck cuz the stock push pull just mad me laugh at how $#!tty it was and it clears great I moved my axle forward 1" and added a 4.5" shackle and I havent hit the oil pan yet and I dont plan on prerunning the truck. also might look into the roger brown motor mount spacers to gain a lil room with out lifting the truck but at $99 for the pair I might build my own...
Current:
Sold:
pumkin toy
Quote from: 4x4yota on May 07, 2010, 11:29:35 AM
hey I have a pair of motor mount spacers i will sell you!  they are brand new, I was gonna use them on my last rig but dont need them now.  sell em to ya for 50 shipped..... I garuntee it will be a pain to make your own
97 4runner Limited
4x4yota
Current:
Sold:
