Author Topic: Dual T-Case Leak  (Read 2722 times)
Jay D
  • Male Posts: 19
  • Member since Dec '07
  • [img width=800 height=600]http://i268.photobucket.
Dual T-Case Leak
« on: Apr 06, 2009, 01:23:12 PM »
So my duals leak when the engine is shut off and it is hot. The crawl box is fine and between the crawl box and the complete transfer case is good but it leaks pretty bad from the back looks like it is high up but I cant really tell. I cant figure out why it leaks worse when I stop and let everything cool down. Any Ideas. I was thinking about some leak stop or cleaning the whole thing off and spreading some silicone on the seams.  :think:
Blingn
  • Turtle Points: 155
  • Male Posts: 2,356
  • Member since May '06
Re: Dual T-Case Leak
« Reply #1 on: Apr 06, 2009, 01:26:30 PM »
I will be checking this one too.  I got the same prob
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #2 on: Apr 06, 2009, 02:11:51 PM »
Check the shifter, if its top shift, mine leaked from there a little untill i put a little silicone on the gasket :dunno:
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #3 on: Apr 06, 2009, 02:22:05 PM »
Are you running the FROR xmember?
Does it look like it's getting slung out around the output flange?
Marlin sells a new transfer case output seal I'll be trying next.  Also discovered it doesn't leak so much when it's not as full.  :O
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #4 on: Apr 06, 2009, 10:11:12 PM »
When you are looking for a leak, I always start at the top.
Check the shifter base and rear seal.
The new Heavy Duty output seal that I invented does work, and has stopped all the rear output flange leaks.
Always check the gear oil lever at the rear fill plug. I see a lot of transmission output seals letting gear oil leak into the Marlin box and then get pumped out the rear shifter. This is the main reason that I invented a seal with an outer flange so the seal cannot be installed backwards or crooked.
Remember to check the transmission oil as well.
Marlin
Jay D [OP]
  • Male Posts: 19
« Reply #5 on: Apr 08, 2009, 03:59:11 PM »
Ok I will check the t-case and trans level, the output looks fine it is defenently higher up. I used silicone on the shifter base but that very well might be the probelm still. Thanks Guys.
Blingn
  • Male Posts: 2,356
« Reply #6 on: Apr 09, 2009, 06:24:53 AM »
The way I filled my trans up was pulled the top plug and filled thru the top shifter till it flowed out the top plug correct?
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #7 on: Apr 09, 2009, 10:59:05 AM »
 :thumbs:
Great job as always Bling
Marlin
GotMyYotaBack
  • Male Posts: 201
  • Member since Apr '09
  • "I like Turtles" Google it
« Reply #8 on: Apr 12, 2009, 09:10:09 PM »
I have a terrible habit of overfilling center case, it leaks through the top at the stick, just after driving (cause the sling is more then designed, I suppose) :smack:
Trekker Build- http://board.marlincrawler.com/index.php?topic=64943.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
So dont tell me I spelled it wrong! You knew what I ment.
Jay D [OP]
  • Male Posts: 19
« Reply #9 on: Apr 28, 2009, 05:39:03 PM »
So I finally got around to checking this out and I pulled the fill plug on the t-case and got about 2 and a half maybee more extra quarts out. :hammerhead: I checked the trans and it seemed to be right where it should be where I could feel it with my finger in the fill hole. SO I am thinking I must have over filled the t-case. I filled it through the shifter but I put the plug in as soon as it came out the fill hole i guess I should have let it level out for a minute first especially since it was pointed down hill. So hopefully I found my problem. Thanks Marlin.   :bowdown: :turtle:
GotMyYotaBack
  • Male Posts: 201
« Reply #10 on: Jul 08, 2009, 04:22:01 PM »
Hey I got one right, your  :welcome:
Last post Jan 05, 2007, 12:32:03 PM
by punkrock crawler
Last post Nov 28, 2007, 08:45:08 PM
by lucky7
Last post Mar 22, 2008, 10:15:58 AM
by *ROKTOY*
Last post Mar 19, 2009, 12:33:42 PM
by RABIDYOTA
Last post Jan 04, 2010, 05:56:50 PM
by 1990GT50
