Transfer case leak
Started by Big Daddy Ty Ty, January 05, 2007, 11:59:15 AM
Big Daddy Ty Ty
 :yikes: My transfer case keeps leaing fluid, it spits it all over the bottom of my truck when im driving down the road. I have changed the seal in the output of my transfercase, but it still spitting it out, not as bad but its still doing it. Does any one have an idea of what could be causing this to happen. :gap:
punkrock crawler
I had the same problem it started with the rear flange leaking and then moved to the front as well. I also replaced my seals which slowed the leak but didn't stop it. My problem ended up being blown out bearings inside the transfer case. Try removing your driveshafts and grabbing the flange I bet it will move a little. Its probably time for a rebuild or a new unit. FYI...... Get a new unit its way easier and you can get the lower gear ratios that you want. Send yours to Marlin for the core charge.
Dying to live and living to die!
1983 Hilux
3" suspension lift, Marlin L52 transmission, Marlin ultimatecase 4.70, Marlin 1200 Clutch, 30" tires, Spraypaint exterior, Webber carb.
2006 Tacoma 4x4
