Author Topic: Transfer Case Oil Leak  (Read 2016 times)
mmessier2
  • Turtle Points: -2
  • Member since Mar '06
« on: Mar 06, 2008, 07:26:11 AM »
OK, quick question....  I want to make sure I didnt screw something up.  I installed a geared transfer case that I bought (85 4runner).  When it was installed I realized the flanges had the wrong bolt pattern for my driveshafts.  I had already filled the transfercase with oil.  When I took off the lower flange (front) oil started leaking out from that area at a fairly high rate of speed.
Im assuming this is because there is no gasket bewteen the flange and the splines, and I dont really have an issue, just install the new flange and refill the case with oil.  Is that correct?
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Transfer Case Oil Leak
« Reply #1 on: Mar 06, 2008, 07:32:41 AM »
Should have just re-drilled the flanges, and the reason it is leaking is because you took it off. Put the other one on and it should stop.
mmessier2 [OP]
  • Turtle Points: -2
« Reply #2 on: Mar 06, 2008, 07:41:28 AM »
I had my old tcase and the correct flanges right there, so why redrill? When I reinstalled the flange the leak stopped.  I figured it was OK, I just had to hit the thing with an impact gun for a while, so I wanted to make sure I didnt do anything unusual.  Thanks for the reply.
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Mar 06, 2008, 07:46:04 AM »
I would have redrilled it only because I hate gear oil all over the place, I don't mind sweeping up metal shavings. Plus make sure to re-notch that center nut so that it doesn't back out.
mmessier2 [OP]
  • Turtle Points: -2
« Reply #4 on: Mar 06, 2008, 07:56:19 AM »
Yah, I didn't realize I was gonna be sportin 90W cologne until it happened.
  • Momentum Man
  • Lego Enforcement
« Reply #5 on: Mar 06, 2008, 08:21:03 AM »
:doh:
Knute
  • Male Posts: 67
  • Member since Dec '07
  • 12runner
« Reply #6 on: Mar 22, 2008, 08:02:14 AM »
ya gear oil sucks
Knute
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #7 on: Mar 22, 2008, 08:52:58 AM »
hmmmm... i like the way gear oil smells
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #8 on: Mar 22, 2008, 10:15:58 AM »
Jimbo, you got to be the only person I ever  heard say that.
Last post Jan 05, 2007, 12:32:03 PM
by punkrock crawler
Last post Mar 19, 2009, 12:33:42 PM
by RABIDYOTA
Last post Jan 04, 2010, 05:56:50 PM
by 1990GT50
Last post Aug 28, 2009, 07:52:11 PM
by H8PVMNT
Last post May 13, 2016, 10:43:21 PM
by emsvitil
