Author Topic: Transfer case leak  (Read 1336 times)
Big Daddy Ty Ty
  • Member since Jan '07
Transfer case leak
« on: Jan 05, 2007, 11:59:15 AM »
 :yikes: My transfer case keeps leaing fluid, it spits it all over the bottom of my truck when im driving down the road. I have changed the seal in the output of my transfercase, but it still spitting it out, not as bad but its still doing it. Does any one have an idea of what could be causing this to happen. :gap:
punkrock crawler
  • Male Posts: 117
Re: Transfer case leak
« Reply #1 on: Jan 05, 2007, 12:32:03 PM »
I had the same problem it started with the rear flange leaking and then moved to the front as well. I also replaced my seals which slowed the leak but didn't stop it. My problem ended up being blown out bearings inside the transfer case. Try removing your driveshafts and grabbing the flange I bet it will move a little. Its probably time for a rebuild or a new unit. FYI...... Get a new unit its way easier and you can get the lower gear ratios that you want. Send yours to Marlin for the core charge.
Dying to live and living to die!
1983 Hilux
3" suspension lift, Marlin L52 transmission, Marlin ultimatecase 4.70, Marlin 1200 Clutch, 30" tires, Spraypaint exterior, Webber carb.
2006 Tacoma 4x4
Last post Mar 22, 2008, 10:15:58 AM
by *ROKTOY*
Last post Mar 19, 2009, 12:33:42 PM
by RABIDYOTA
Last post Jan 04, 2010, 05:56:50 PM
by 1990GT50
Last post Aug 28, 2009, 07:52:11 PM
by H8PVMNT
Last post May 13, 2016, 10:43:21 PM
by emsvitil
