Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 41 Guests are viewing this topic.
Quote from: V-Man on April 09, 2009, 07:21:07 PM
I bet he has your intake manifold on before mine....I think he likes you more.. :snare:
:cheese:
:bumpinbutts:
project cable locker is almost finished  :woohoo:
mudmaster
Time to go wheelin!
hilux-1983
Quote from: 79coyotefrg on September 26, 2004, 05:34:46 PM
Marlin has springs?? :dunno:
This is funny reading it now a days. How time flys huh?
Quote from: mudmaster on April 11, 2009, 05:50:51 PM
:worthless:
i had to flip the drivers side shock to be able to mount it
if i had bilsteins it would be better
mudmaster
Took some time to get that pic  :greengrin:
Time to go wheelin!
baldwookie
looks good bro...  have u tried it out yet?
1980 lwb sr5  stock
well, the other day i was coming back from Bismark, (20 miles away)  10 miles on a 2 lane, then 5 miles on the interstate, after the first 3 miles i start up a hill thats fairly long,  about 3/4 the way up the hill (75 mph) i feel the slight bogging of the engine, then i see blueish smoke in the rear view :nerv:  as soon as i backed off the throttle the smoke quit,  i get back into the throttle and no smoke,  i mash to the floor no smoke.  when i get home (about 6 miles later)  i stop the truck and check everything over,  nothing out of the ordinary
so  your thoughts??
GJToyotabug
hmm your oil breather ??? dunno
Quote from: GJToyotabug on July 28, 2009, 08:25:14 PM
oil breather vents to the air cleaner similiar to stock
i did find a bad drivers front wheel bearing :down:
GJToyotabug
Quote from: 79coyotefrg on July 28, 2009, 08:31:57 PM
yeah like oil went up into the air cleaner it got into a cyl and burned in the cyl causing blue smoke
Quote from: GJToyotabug on July 28, 2009, 08:42:03 PM
i would GREATLY prefer that over  a bad ring or something :sheerterror:
My 4Runner did something like that once, we were on a trail and a group ahead of us was having some issues. I walked up to see what was going on (leaving my truck running) and when I walked back it was smoking. Scared the hell out of me, I ran over and shut it off, checked it out and found nothing. Fired it back up and it never smoked since. Couldn't find what caused it to do that.
BUBBA
You were turning so many rpms up the long hill that it pumped excess oil into the valve area faster than it could drain back to the pan until it reached the pcv and got sucked into the intake :yupyup: ize is smart like thatd
My budget beater
Quote from: BUBBA on July 30, 2009, 10:56:00 AM
but only about 4100 rpms :dunno:
more suggestions??
ive gotta go replace left front wheel bearing,  glad i have a shop, stupid :rain:
hilux-1983
Quote from: 79coyotefrg on July 30, 2009, 11:50:14 AM
more suggestions??
speaking of rpm's, what is safely the limit when powering up a hill as coyote was, or towing trailer
a 22R can easily stand 4500
my old engine was a 20/22R hybrid,  OMG  i loved that engine,  but dropped an exhaust valve at 7200 rpm :down:
Quote from: hilux-1983 on July 30, 2009, 01:02:07 PM
might i add i was in 4th gear at just under 80 mph when this happened
GJToyotabug
note to self dont rev over 7000RPM
yea  the valves float at about 6800  :down:
but DAMN  the 20/22 hybrid will pull out to 7000 in a heart beat, well at least with the cam i run it did
if this motor goes down i'll build another hybrid
GJToyotabug
yeah stock cam on mine is flat lining at 5600 totally disapointing
Dr.Maxwe001
[img]http://bo
Jordan7118
4000 RPM  :yikes:
7000 RPM  double  :yikes:  :yikes:
Easy on that peddle, buddy. You're driving an old truck  :ack:
Quote from: GJToyotabug on July 30, 2009, 07:53:16 PM
drop the LC .440 cam in there Josh :thumbs:
GJToyotabug
i'm a thinkin i just dont have money. and if i do that i'll put higher compression pistons stronger rods and larger valves. SHOOT maybe i'll just run a 3RZ in it :greengrin:
Quote from: GJToyotabug on August 02, 2009, 06:03:12 PM
NO NO NO,  are plenty strong, higher cr pistons are NOT needed, nor are larger valves, you just need to keep them open longer
V-Man
Quote from: 79coyotefrg on August 02, 2009, 06:00:20 PM
  Yes the .440 is nice if the/my motor is running.... :mad:.... :cheese: :love: ya Glen..
