Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 54 Guests are viewing this topic.
baldwookie
:woohoo:  cool glen,  start it up yet?   got pics?  we wanna seeeeeee
1980 lwb sr5  stock
unclejpl4x4
I heard it had a MR fussion on it :shhh:
Quote from: drunckle on April 02, 2009, 06:19:33 PM
a what :headscratch:
Quote from: baldwookie on April 02, 2009, 06:16:09 PM
:yupyup: drove it up to the corner and back :woohoo:
unclejpl4x4
Quote from: unclejplx4 on April 02, 2009, 06:43:10 PM
http://bttf.wikia.com/wiki/Mr._Fusion
:rofl:   yea man  thats what i need :screwy:
but hey i could power the house and sell electricity to the power company :think:
well, the engines fine
i started installing the downey cable conversion on my elocker :headshake:
i'll post pics later i'm exhausted
needless to say i was NOT impressed :headshake:
unclejpl4x4
so lying in the dirt with a screw driver is better ?
ninja turtle
Quote from: 79coyotefrg on March 16, 2009, 09:48:17 AM
I have the downey cable as well and it really looks simple, i dont see having a problem with it
see what i mean. i could get mine to work great at my house but at as soon as i would get on the trail it was always a no-go. im switching back to electric.
Quote from: no-idea on April 05, 2009, 06:33:01 AM
i see what you mean,  i'll be talking to Jim at Downey tomorrow :headshake:
The cable conversion is very sensitive to adjustment, took a friend of mine a few trips out to get it right. Worked great once he had it adjusted right.
unclejpl4x4
ok, i got the holes drilled in the ifs housing then decided i'd install the cable on the elocker in the truck (this was later deemed a mistake) :ack:
here we go
freeze plug in the housing
made some knotches with a grinder in the shift rail so the allen head studs would have something to hang onto
now the kit didnt come with any type of gasket to keep oil from leaking between the alum block "adapter" and the housing, so i made one
using the block and a small hammer with a light touch
GJToyotabug
after installing i realized the center hole in the "adapter" wasnt bored square to the block
it worked fine when loose, but when tightened it would jam solid
i also realized the stock shock was in the way,  to remedy this i cut the upper can off the shock and mounted it upside down
i also found that sliding the block over the shift adapter then attaching it to the cable before attaching it to the shift rail worked alot easier than twisting the cable to thread it onto the thing
it wasn't difficult to fix the "not square" i just needed to find what the problem was,  I will be in touch with Jim at Downey so this problem gets fixed :thumbs:
a little work with the proper sized stone
and a little taper on this thing,
all helped to make a smooth shifting cable assembly
baldwookie
1980 lwb sr5  stock
i made this little  temporary bracket  to make it work,
well, there it is all tight and secure and WORKING :woohoo:
unclejpl4x4
wow thats a whole lots engineering  your a pretty fart smellier glen.
just got flex here now to see if the cable rubs anywhere
i'll be getting a few of those metal mounting clips and some self tapping screws :thumbs:
this cable is fairly long, i thought it would be beside the seat but the shifter will be up close to the SR5 gauges :suprised:
unclejpl4x4
Quote from: Jordan7118 on April 07, 2009, 06:29:26 PM
Keep that motor, my man. I may need it one day  :disturbed:
dont worry i will :thumbs:
baldwookie
keep that motor... sniff,sniff  what am i  gonna do :((
1980 lwb sr5  stock
Jordan7118
Quote from: baldwookie on April 07, 2009, 07:36:12 PM
I was talking about the e-locker motor. What you sniffin' for  :headscratch:
Quote from: Jordan7118 on April 08, 2009, 12:56:18 AM
:rofl:  he thought you meant his engine i built for him :haha:
dont worry wookie  its  all yours  :therethere:
V-Man
Quote from: 79coyotefrg on April 08, 2009, 07:24:37 AM
   The one wookie stole from me.... :eek:  :hahaha:
baldwookie
umm yeah i missed understood......   im on edge.. had me worried.......             hehe yep,yep    i stole it
1980 lwb sr5  stock
V-Man
Quote from: baldwookie on April 08, 2009, 11:35:54 AM
I bet he has your intake manifold on before mine....I think he likes you more.. :snare:
:cheese:
