Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 79 Guests are viewing this topic.
:ack: they dont fit :ack:
well not yet :disturbed:  i'll "make" them fit :bolt:
ok, maybe tomorrow since its my bedtime :yawn:
Duffil
the holes in my bumper need to be about 1/8 inch taller
i'll mod the bumper not the lights
did you send them Rex i was trying to remember who sent them today, went to look at the box and no return addy  :down:
Duffil
Quote from: 79coyotefrg on September 11, 2008, 08:26:21 PM
no I think you got them from Homefries. I was just curious.
OH  :headscratch:
yea  i think about 30 seconds with a grinder on the bumper will get them to fit
Homefries
Glad to hear you finally got them, but it sucks that they don't screw right in.  :thumbdown:  But I am sure you will make them fit nicely.  :thumbs:  I was in a hurry to send them to you so I didn't put a return add on them.
thanks Homefries :smooch:  yea  they 'll fit fine after  a  touch of the grinding wheel :disturbed:
made a new front shaft
first try was about a inch too long
tacks
grinding excess off so its not too far out of balance
finished :drool:
Jordan7118
Stock slip? You have problems with that bottoming out or pulling out?  :dunno:
I think it needs more grease there Glen.
Quote from: Jordan7118 on September 15, 2008, 06:51:39 PM
ive measured carefully  to work it so  that it doesnt bottom out, if it pulls out  well  :down:  as long as it doesnt bottom out,  i cant afford a long slip kit right now  but you can see in the last pic i have one ready for a long slip as soon as i can afford it
Quote from: Rocksurfer on September 15, 2008, 06:51:48 PM
i didnt have the motivation to disassemble the cv  to properly clean it
i busted the ring gear in my rear axle :down:
i guess i'll have to install the 5.29's Marlin sent me :bolt:
unclejpl4x4
i was just gonna ask how the truck  did
YotaJosh
Sorry about your gears. I've got a set of 4.37's if you want to stay higher geared. They are still in good shape as they came out of the front. Maybe the 5.29's will motivate you to get some bigger rubber.  :yupyup:
Your truck looked good this weekend, and flexed up pretty nice.  :thumbs:
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Duffil
Quote from: 79coyotefrg on September 21, 2008, 06:40:05 PM
Glen WTF!! what did you do to her? :down:
thanks Josh,  i'll let ya know
Rex,   i was on a  near 45 degree angle  and thought i was in first  to start easing downhill, but  for whatever reason i was in reverse, i let it rolled forward slightly then slipped my foot off the clutch to start  the engine,  needless to say it didnt move :snare: when i started the engine and went to drive forward i heard this crunching sound :nerv:
it would go forward a few feet then the drivers side back tire would lock up and drag, this happened i think maybe 4 times then i got it in 2wd  and  made it on down to camp :down:
later  drove it home 45 miles  at 40 mph nearing home it sounded like i was stiring rocks in a barrel  with a big stick  :headshake:
unclejpl4x4
 :nerv:      just like when u 4got 2 put it in 4wd going down that hill............  I think glens geting senile
or maybe the first time i drove it after  i got it back together and forgot to put lube oil in the diff :yikes:
it must have gotten hot enough to take the temper out of the gears :down:  i'll know when i get it apart :down:
V-Man
Quote from: 79coyotefrg on September 22, 2008, 09:05:22 AM
:yesnod: I am thinking the oil missing may have something to do with weaking the gears. :ack:
yea  im thinking that HAD to  be the problem  :down:
IT WENT OUT OF THE DRIVEWAY!
46&2
That is a good picture right there.
mudmaster
Time to go wheelin!
no  but i got the rear third out today, they seemed to be binding together, i couldnt turn the pinion at all by hand,  i removed the carrier  and i STILL couldnt turn the pinion
removed the pinion nut  and it fell out,  i inspected the gears and it looked like it had gotten hot, ring gears appeared to be  blue in places,  pinion teeth  had  "spots"  i found a place on the carrier where something significant had been smashed between it and the pinion but  what could it have been?? :dunno:
the blueing is probably from running with no oil :down:
