I made this not too long ago
needed rear caliper mounts for rear disc!
You need to start a build thread! Any more info on the rear disk setup? I've seen your posts on pirate before and always like how you did everything yourself
I have all the info you could want I did the IFS mod on the front. I used 98 rotors, 94 calipers, 88 hubs. For the rear, I used the 85 rotors, 85 calipers, and my custom brackets. Ill post detailed pictures and info in the build thread I'm going to start
Can't wait! I'm thinking about doing the ifs hub/taco brakes and rear disks with the s/a rotors and calipers too. How do you like the set up?
Did you basically do the same thing as the fror kit?
I don't know what that is...
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?products_id=136&osCsid=87f97c6a1ab4c0
nope... i didnt machine anything, or use any special parts... i built it with what i had laying around... i used 94 v6 calipers off a parts truck we had... they had the 4 big pistons inside the caliper. the solid axle calipers i used on the back have 2 big pistons and 2 small pistons in each caliper... the only tacoma parts i used were the rotors...it was super easy to do this mod... i drilled out the steering knuckle stock caliper mounts to 1/2". on the calipers, i just used a 1/2" tap to tap the holes for a 1/2" bolt. i used grade 8 hardware. ill do a detailed writeup if anyone is interested
Can't wait
I hand forged the legs, tapered the ends and did the scrolls. Made the frame, and used marble tile for the top.
Started by jimbo74 Toyota Pickup/4Runner Tech 1979-95
Started by ga-toy Engine
