Project BoostedRunner, SOLD
Started by pumkin toy, January 12, 2009, 09:37:34 PM
0 Members and 18 Guests are viewing this topic.
pumkin toy
Quote from: Uncle Ben on April 12, 2011, 06:33:04 AM
I'm so jealous! Mine is so close and I'm just slammed right now.  Obviously, my latest morph went to0 long.  Honey-do list is building pretty fast too.  If I only didn't have to work.....
wwell dont get too jealous bud,  i am faaar from ready to wheel!  still have the rear 4 link to build, setup the fuel cell, dove the rear, build a rear bumper......... it goes on
97 4runner Limited
Uncle Ben
Quote from: pumkin toy on April 12, 2011, 05:16:05 PM
I guess I'm just jealous that you getting some shop time!  I tinkered a little last weekend and finished building my fuel cell but I REALLY need to burn some hours and get some smoke curls flowing!  It's getting to be perfect wheeling weather with melting snow and warm weather plus the yard projects are screaming to get underway....and my crawler sits silent....... :-(
Kevin Ehrlick
"I pledge allegiance to Marlin...." :)
'64 FJ-40 crawler (Wild Rice)
'97 FZJ-80 mall rated (Rice Cake)
"Chrome wont getcha home!"
pumkin toy
ok i finally got a bunch of pics for you guys.  I uploaded them all to photobucket cuz its a pain in the ass to resize them all for this site.   the three link is almost completely setup.  I got more done tonight aside from the pics i have now.  i am working on the panhard bracket at the axle end right now and hopefully it will almost be done tomorrow.  the pics of the suspension flexed was just a temporary setup of the panhard so i could see how everything works.
I ended up finding a pretty good solution to the dredded 80 series LC steering.  i removed both lower steering arms and modified them.  the pass side arm is originally one big arm that goes to the front of the knuckle for the drag link to attach to, and to the rear of the knuckle for the tie rod to attach to.   i cut the rear half off because my tie rod is no longer in the rear of the axle..... so that was easy.   then i took the driver side arm (which normally faces the rear to connect to the tie rod) and i cut it off so i could weld it on the front.   It actually worked out really well.  i tacked it all in place and made a 1/4" plate gusset to run all the way up the arm.  Then i warmed it all up with the torch and burned it in.  I took both arms to work and stuck em in the mill and drilled out the tapered TRE holes to a 3/4" straight through hole so i can run 3/4"x 3/4" hiems instead of TRE's.  So that solves moving the tie rod to the front of the axle.  Now i am going to build a complete custom upper steering arm for each side that will bolt on via the two upper knuckle bolts and the ABS hole.  This will give me a double sheer steering setup which i think will be plenty strong!  Also i have decided to go with full hydro steering using a single ended ram, so i dont have to worry about drag link and panhard interference.
Here is a link to my photobucket folder   http://s784.photobucket.com/albums/yy127/BoostedRunner87/3%20link%20build%20for%20the%20BoostedRunner/#
97 4runner Limited
Peterbuilt84
Work looks awesome as usual  :beerchug: Looks like it's on its way  :biggthumpup:
pumkin toy
Quote from: Peterbuilt84 on April 13, 2011, 09:44:21 PM
thanks dude!  i appreciate it,  im hoping by the end of this weekend the front will be completely done except for the hydro ram.  I should be able to get my shock hoops bent and the shocks installed this weekend
97 4runner Limited
Peterbuilt84
No problem, you're putting some hard work into that runner and in shows  :cool:
I really want to see how you like those 80 series axles and how they hold up to the 4dees. The front looks pretty beef except for the r&p and the rear should hold up well also. I've been keeping my eye out to see if a deal on a front comes up, but no luck yet.
Jordan7118
This may be a really dumb question...
Looks like the bolt pattern is symmetrical. Why couldn't you just turn the driver's side steering arm 180*?
Looks killer!
19864runner
Looking good man you sure know what you doing keep up the good work. Just got my new wheels on my 4runner havent been working on it to much trying to get my boosted civic fixed i just put a hondata s300 in it need to tune it know, then i can start working on my 4runner again.
pumkin toy
Quote from: Peterbuilt84 on April 13, 2011, 10:17:53 PM
i think i will like them.  The birfields are way bigger and since the ring and pinion is a high pinion, it is also stronger than a standard 8".   I know i wont have any problems with the rear axle... Its stright beef!  way bigger than a mini truck rear axle
Quote from: Jordan7118 on April 13, 2011, 10:32:04 PM
Looks killer!
thats a valid question!  It would have been nice to be able to do that.  The pattern is symetrical.  The problem is that the steering arm is built to come off the knuckle at an angle in order to get the proper Ackerman angle for the stearing.  So when you flip the arm 180 degrees, then it hits the brake rotor because it is now pointing the wrong direction.  also that arm isnt quite as tall as the passenger side one and it is also longer!  So i had to cut it, shorten it, and point it up at a steeper angle in orderto match the pass side.
Quote from: 19864runner on April 14, 2011, 05:25:01 AM
thanks dude!  boosted civics are fun..... what year do you have?
97 4runner Limited
19864runner
its a 96 hatchback put the whole front has been converted to a 99 it has a fully built gsr motor you name it its got it.
pumkin toy
Quote from: 19864runner on April 14, 2011, 11:05:29 AM
sounds like a fun car!  i had a 91 integra with a gsr swap.  also had a 91 crx si with a b16 swap, and also had an 01 s2000!  I miss the S the most thats for sure
97 4runner Limited
pumkin toy
got some more pics for ya guys.  last night I notched the frame on the passenger side so i could mount the panhard up higher on the axle.  It now sits at a negative angle to the tie rod at ride height.  With it setup that way, at full droop the panhard only pulls the axle over towards the driver side 5/8".  I'm really happy with that.  my panhard bracket on the axle is pretty tall and i have alot of plate gusseting to do on that side so the panhard is nice and sturdy.  the frame bracket for the panhard turned out good and i also have a nice cover plate for it with a couple speedholes (it will look like the cover plate on the diff end of the upper link).  This weekend i plan on getting everything burned in solid and gusseted up.  Then i will bend my shock hoops and get the shocks installed.
Link to pics   http://s784.photobucket.com/albums/yy127/BoostedRunner87/3%20link%20update%20%204-15-11/
97 4runner Limited
John Doe
Looks really Good. Are you waiting on the new knuckles that are coming out?
pumkin toy
Quote from: John Doe on April 14, 2011, 09:38:45 PM
thanks,  No i modified the lower steering arms so the tie rod is in front now. Then i am going to build my own upper steering arms that will bolt onto the knuckle to create a double sheer setup
97 4runner Limited
19864runner
ya it gets up and goes a made 405whp on low boost on old turbo manifold and now i have a full race manifold in it should be more horsepower now specially with the hondata s300 ecu. Hows the rear axle coming along?
John Doe
Quote from: pumkin toy on April 15, 2011, 05:38:37 AM
Sounds like it will be fairly strong. If you need another set of stock knuckles and arms by chance, let me know.
pumkin toy
Quote from: 19864runner on April 15, 2011, 06:34:01 AM
I havnt done anyting to the rear yet except clean off all the brackets
Quote from: John Doe on April 15, 2011, 12:27:24 PM
thanks man,  i will let you know if i need anything
97 4runner Limited
Jaysen
hey pumkin you got a closer pic of the steering arm?
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
twistedtoy92
oh man this thing is lookin good!!!! Motivation right there! I finally rolled mine into the shop after work yesterday. Boss bought a Cutmaster plasma torch so I got rid of my old sliders, front bumps and moved my steering box 4 3/4'' forward. :beerchug:
pumkin toy
Quote from: sou95SAS on April 15, 2011, 06:17:54 PM
a pic of it on the axle?  the only pics i have of it off are the ones in my photobucket account
Quote from: twistedtoy92 on April 15, 2011, 06:30:31 PM
Thanks dude! I'm pretty motivated right now, gonna work on it all weekend.  that will be a nice plasma to have!  i have been using the plasma at work alot lately to cut all my brackets.  We actually have a 6'x6' cnc plasma table at work now.  i'm sure they wont let me use it to cut out sweet brackets though :down:
97 4runner Limited
Jaysen
I want a closer look at the arm on the axle! just want to see how you are running the high steer.
pumkin toy
Quote from: sou95SAS on April 15, 2011, 11:21:16 PM
ok i will try to get a better pic later today
97 4runner Limited
twistedtoy92
yeah i love plasma compared to oxy/acetylene, much cleaner cut! I'm workin on mine all weekend as well, going to get the 63'' chevies switched over, daystar bushings, 18mm marlin shackle bolts, build frenched hangers, and weld rear johnny joint shackle mounts up :yupyup: Then next weekend its moving the front axle 3'' further forward, brace up the frame and finish the steering box mount and relocate the shock hoops.
19864runner
Whats i could not to expensive brand in plasma cutters?
yoter4x4
yo caleb, first time i've been on here in like 3 or 4 months.... this thing is Fu***n tits in person, i feel honered to be the guy that put the jackstands under the axle :)
Bullets don't know the difference between race, sex, or gender.. They Just Feed On Flesh!
pumkin toy
Quote from: yoter4x4 on April 18, 2011, 08:08:58 PM
haha  you're funny man!  thanks though.  the front is pretty much done.  gonna start building my custom upper steering arms and i am going to start on the rear dove real soon.  It would be nice if the rear dove was pretty much done by the end of this weekend, we will see how that goes though
97 4runner Limited
Uncle Ben
Quote from: pumkin toy on April 18, 2011, 09:38:19 PM
You go man!
Kevin Ehrlick
pumkin toy
Quote from: Uncle Ben on April 19, 2011, 06:53:04 AM
You go man!
i'm trying!  I got the 1 3/4" OD x 1/2" wall DOM for my front lower links today.  Gotta get one end tapped for the 1 1/4" jimmy joints.  Then I ill have to cope the other end and weld on my Currie Johnny Joints.  Once that is done, all my links, panhard bar, and tie rod will be done in the front!
97 4runner Limited
Uncle Ben
1/2" wall = nice!  I'm running 3/8" wall lowers and it's amazing how much abuse they can live with.
Kevin Ehrlick
Uncle Ben
Kevin Ehrlick
