***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
brockbuilt85
Quote from: fordh8r on July 19, 2009, 09:52:45 PM
Sounds like the battery is low or the timing is too far advanced.  :dunno:
i have not messed with the timing yet. but your the second person to mention it. ill mess with it next chance i get tho and see what happens. the battery is new, and i had a jump box hooked up to it.
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
fordh8r
brockbuilt85
Quote from: fordh8r on July 19, 2009, 10:09:38 PM
Good place to start.  :thumbs:
would it not even pop if the timing was off? i mean, its turning over, but not even tryin to start, i got fuel(pretty sure) and spark(definatly)
Turd Box Build:
fordh8r
It could, but if it's advanced enough to still contain the fire during the compression stroke, it with just resist the upstroke as you crank causing it to crank rather slowly and somewhat erratic as it sounds in that video.  :yesnod:
brockbuilt85
Quote from: fordh8r on July 19, 2009, 10:14:48 PM
good to know. i might be motivated enough to work on it again tomorrow
Turd Box Build:
fordh8r
*** YELLER ***
Quote from: fordh8r on July 19, 2009, 10:18:44 PM
Keep us posted on what you find.  :biggthumpup: :beer:
tryed timing but still sounds the same  :headscratch: :dunno:
:usa: :beerwhack:
except BACON
*** YELLER ***
except BACON
fordh8r
Sounds like it's cranking faster. What about fuel? Try using a qick spritz of carb cleaner into the throttle body and see what happens.  :dunno:
Carlos asked if you got the rag outa the intake?  :yupyup: :gap: :haha: :ha_ha:
*** YELLER ***
except BACON
brockbuilt85
Turd Box Build:
brockbuilt85
thanks 86turboypta and minisimp for your input today! without you it would still be a pile of poo, now its a running pile of poo. and the passenger window now seems to work, sweet.
need to:
adjust valves
fill radiator up all the way
get power steering lines working right
put hood on
change windshield
install cases (thanks duffil)
get d-lines
check brakes
clean out
install passenger seat
cage
sliders
bumpers
register
stereo/CB
Turd Box Build:
fordh8r
Duffil
:beerchug: so much for the water wagon. :beerchug:
thanks dave.
brockbuilt85
Quote from: fordh8r on July 20, 2009, 09:49:50 PM
So what was wrong?  :headscratch: :dunno:
bad ground and basically a vacuum leak. all is well now
Turd Box Build:
brockbuilt85
Quote from: Duffil on July 20, 2009, 10:26:49 PM
thanks dave.
hey, thank you. when ever your in my neck of the woods, ill buy you a beer
Turd Box Build:
fordh8r
Quote from: brockbuilt85 on July 21, 2009, 07:19:22 AM
At least it was simple.  :thumbs:
brockbuilt85
#257
Quote from: fordh8r on July 21, 2009, 07:28:48 AM
oh yea, we knew it was. we just didnt think we would figure it out.
cause we are ninjas, we did
Turd Box Build:
subbrat
So you have any ideas for your front and rear bumpers. Bender is all tuned up. I'm starting to collect pipe and hinges for my tube doors.
brockbuilt85
Quote from: subbrat on July 22, 2009, 05:58:21 PM
no clue, i have that one thing for the front, as for the back :dunno: im more concentrated on getting the cases in and getting it running well.
update: passenger window now works fine, thanks carlos!
Turd Box Build:
brockbuilt85
insert twin sticks right about here:
update, got the motor running a lil better, and the check engine light wen away, but it seems to be smoking alot from the exahust side (see video) im thinking its burning crap off, plus i still need to adjust the valves, gonna wait till it gets a lil less smokey outside, got a head ache just from being out there as little as i was.
http://www.youtube.com/watch?v=m9Iw3GFdsWM
HEY SUBRAT! think you could take a trip up here and give this pig the once over one more time, just to make sure im still go for launch? ill take you and amy out to the peppery :thumbs:
Turd Box Build:
subbrat
The next two week ends are full I have to go get the willys and re smog the camaro for the trade. After that looks good.
unclejpl4x4
i think you should use the hole for a inboard :toilet:
brockbuilt85
Quote from: subbrat on July 29, 2009, 05:22:37 PM
oh sweet you found one!
ok, well, let me know when you wanna come up, ill keep workin on it, this weekend the weatehr is supposed to be cooler so ill prolly get a bit done.
Quote from: ÜncleĴ on July 29, 2009, 05:33:00 PM
geesh
Turd Box Build:
brockbuilt85
#264
cases almost in, had a coolant problem, didnt hook up ne of the hoses, adjusted the valves today too. still runs a lil rough. just taking a break before i fnish the case mounting.
Turd Box Build:
brockbuilt85
cant get the cases in by myself, gonna get some help tomorrow. and then once i get them in, shifter and cross member. im gonna need some drivelines. soon.
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
sorry for the cell phon pics, its all i had at the time, dave took all his cameras and i forgot mine
Turd Box Build:
Tallchevy
87 4Runner redo
brockbuilt85
took my drivelines to Marty Built today. also got drain plugs, and bolts for the shifters, oil for the trans/transfercases. still runs a lil rough, but i need to put some plugs in it, see what that does, and put the real exhaust i have on it. wish i knew how to weld worth a :pokinit: so i could get some of that started, i feel like im behind the 8 ball as far as the roundup goes. geesh!
Turd Box Build:
