Project Pete *Wheeling Pics!!!!!!*
Started by Redbeard1, March 11, 2008, 12:10:27 PM
Redbeard1
Just a few pics from my trip home drove PETE fishing had to get some pics but no real wheeling not enough time.  :down:
My Sweetie being cute..   :drooling: :eyebrow:  :drool:
My Sweetie in her Crawler hoodie... :yesnod:
Sweetie's new TRD Scion TC... :welcome: to the family..  :burnout:
Me and my boy off to go play in the mud.. sorry no during or afte mud pics..
First Fish Caught In The USA!!! :woohoo:
My boy, Me and our American Bulldog (AKA Baby Girl)
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
Redbeard1
RIP Bobby Long
unclejpl4x4
boggerunner
with a correct 3 or 4 link, there is no need for a panhard bar, but keep it simple for now with some leafs.
Redbeard1
Added this for my reference
Quote from: redpim1 on March 09, 2009, 10:31:35 PM
Well here is my idea I have been working on. Start with a Donaldson G070019 air cleaner assembly.
Then gather you some 3" silcone inter cooler tube connectors or simular hose and band clamps.
Then have your local muffler shop bend you some custom intake and snorkel pipes and put it all together.
You will need to find or fab some sort fo air ram/weather cap for the top of your snorkle tube to keep the rain out.
Cleaner housing check at any partstore that sells Donadlson filters they can order it for you out of the catalog.
https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10087&item=16145
Constant torque clamps
https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10086&item=10594
ARB air ram $69
http://www.trsfabandoffroad.com/products/arb_snorkels.htm
http://www.streetsideauto.com/products.asp?lsbYear=2004&lsbMakes=GMC&lsbModels=SIERRA+1500&lsbSubModels=None&lsbEngTypes=V8&lsbFuelDels=Fuel+Injection&lsbASPs=Normal&lsbEngineSizes=4.8L+/+294+C.I.D.&lsbEngVins=V&ParentID=7&SubID=7&PTID=4555&brand=BKJC&Seri&partnumber=51-11061&partnumber=75-11061
RIP Bobby Long
Redbeard1
I miss Pete... :down: hope I get this job I have pending back in the States. So many plans but so far away.
RIP Bobby Long
Redbeard1
#96
OK guys tell me if you think this front suspenion idea will work. I will proberably not run the drivers side upper I just put it in there to see what it would look like. This would be set up with 12"  coil overs  up front and  in the rear I am not going to run over a 36's and I am planning to keep it as low as possible. looking for about 5" of up travel.  Drawing is with the front axle about 3.5" forward.  Give me your  :twocents:
RIP Bobby Long
Redbeard1
Without the color.
RIP Bobby Long
boggerunner
is blue the panhard?
do u need a panhard with a 4 link, or will it bind with it in there?
Redbeard1
Yes the blue is the panhard.  I may decide to only do a 3 link up front for exhaust clearance the Thornley header takes up alot of space. I am going to lift the drive train and build a bell pan to mount all of the lowers to and the tranny/t-case. botom of the cross member will be 2-2.5 inches below the frame max not a full on flat belly but at least a slick belly with the sliders boat sided. I am pretty sure on the rear suspension but may lower the frame end of the upper links. On the front I will prober ably only run a 3 link deleting the driver side upper link that I have drawn. 7" vertical separation on the axle end of both front and rear links frame end on the front would be 5" and the rear would be around 6".  I want to keep the anti-squat so that it is pretty neutral and doesn't raise or lower much on acceleration (if any thing I would rather the front raise and the rear to lower to transfer the weight to the rear for traction).  I want the roll center axis to be where it is stable for road use as I will be running this on the street and off road. I want it to be firm enough to handle curves well on the highway but soft enough to soak up the bumps well off road while still having decent flex.  I was planning this around 12" 2.0 dual rate coilovers (don't know what spring rates I should run as of yet) setting it up with 4-6 inches of up travel. I may use bushings on the frame ends of the links and .875" hemi joints on the axle ends or hemi joints on both ends. I am thinking 2" .375" wall DOM for the lowers, 1.75" .250" wall for the uppers and 1.25"-1.5" .250" wall for the panhard bars. I am also planning on 4" 2.0 air bumps on all corners. I think this will work but I may have some design flaws.  What do you guys think that have more experinece on this than me? I have only done 3 link setups and mone of them were on a Toyota platform nor on my truck. 1 Jeep (rear uper wishbone lower straight links), 1 old school Ford Bronco (front basicly a radious arm with rod ends and a panhard) and 93 Chevy (parallel set up like a 94-2002 dodge).
RIP Bobby Long
Redbeard1
RIP Bobby Long
Redbeard1
After thought with 3 link front and all links longer.
RIP Bobby Long
Redbeard1
I'm On my way home from Iraq for good!!!
:woohoo:
Pete will be on hold because I have to move to where my new job is and I will be using it as a daily driver...
RIP Bobby Long
unclejpl4x4
Quote from: redpim1 on April 24, 2009, 11:01:34 AM
:woohoo:
:woohoo:  :beerchug:  reds coming home :boobs:
Redbeard1
Got back to the States on Monday been hella busy. Got to work on Pete today, did a rear brake job, rear wheel bearings/ seals, replaced the master cylinder with a 1" bore 1992 FJ80 with a 1991 Celica resivour and changed the damaged rear 3rd member with another 4.11 unit I had damn crush sleeves.  Stripped the carpet out and removed the evil tar from the floor board I love air chizels.  All the brakes blead out good high firm pedal now. Tomorrow I'll replace all the ujoints, change all the fluids, fix the horn and head to get it inspected and have the tires mounted on my soft 8s. I am waiting for the front v6 calipers, fj vented rotors, knuckle studs, front axle service kit, wheel bearings and my new seats. I'll get some pics up later on but most of it is just normal repairs.
RIP Bobby Long
:woohoo: Congrats Red!
Glad to hear your back and getting your truck worked on.
JanMarie13
RIP Kyle, we love and miss you man.  :smooch:
Quote from: KYOTA on October 03, 2009, 10:33:31 AM
thanks for the smooch I miss you too !  :yesnod:
Slolyfe
Welcome back man!!! Cant wait to follow your build!
You'll never take me alive
*** YELLER ***
 :usa: thank you for your time and SERVICE Red..... Now stop drawing pictures and build   :disturbed:
:usa: :beerwhack:
except BACON
unclejpl4x4
Redbeard1
Well I am back to work on Pete..
Brakes about done..
Off with the paint.... I love air craft stripper..
Build Crew....
Back on with the paint...
Little bit of bed liner on the sides...
RIP Bobby Long
unclejpl4x4
O O O i like it  thats really neat
Slolyfe
How did you get your axles out of the drum/bearing assembly? Do you have a press? It took us a long time to get them out in a full shop. Finally had to make a tool to pull them with the press. But always looking for an easy way esp on the trail.
Redbeard1
used my press and a couple of 2"x8" under the backing plates.  I have also done it by pulling the axles and brake assembly out removing the snap ring and put the assembly back in and grab the axle flange with a slide hammer and give it a few hits and it comes right out.
RIP Bobby Long
Redbeard1
I got my flat bed almost finished today I'll get some pics up tomorrow.
RIP Bobby Long
BUDDERS
Quote from: redpim1 on May 12, 2009, 08:00:51 PM
I like the slide hammer in the axle housing idea.  I worked in a Toyota shop for years and never saw anyone do it that way.
P.S.  I like the axle housing tool you made for your press.  We had one just like it at my dealership but the flange was all bent to hell.
Redbeard1
Yeah the slide hammer is a throw back to ford 9" axles that is about the only way I have found to get them out that dosent tearany thing up.
RIP Bobby Long
Duffil
remove the snap ring, hold the backing plate and slam! the shaft down on concrete or on a 2x4. Give it about 3 whacks and it comes right off.
