Author Topic: 22re question  (Read 2903 times)
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
22re question
« on: Feb 03, 2008, 12:06:26 PM »
i have a 22re with the high compression head and it is bored .040 over with high compression flat top pistons, is it still a 2.4 liter, or did boreing it over make it a 2.5 liter?
colo.toy
  • Turtle Points: -2
  • Member since Dec '07
Re: 22re question
« Reply #1 on: Feb 03, 2008, 02:24:38 PM »
the 2.4 is a measure of displacement.  To measure the displacement, find the area of the cylinder at Bottom Dead Center ( BDC), where the piston is lowest in the block, then find the area of the cylinder at Top Dead Center (TDC), where the piston is highest in the block.  Subtract the area at TDC from the area at BDC to find the area displaced by the full movement of the piston, hence displacement.  Finally, multiply the displacement of that cylinder by the number of cylinders in the block.
area of a cylinder = 3.14 * Radius^2 * Height
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: 22re question
« Reply #2 on: Feb 03, 2008, 04:24:39 PM »
  :talkingn:  yep.. what he said.
boggerunner [OP]
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: 22re question
« Reply #3 on: Feb 03, 2008, 05:08:50 PM »
no help at all, i was wondering what the displacement was, not some mathmatical figure, does anyone know what the disp. is on a bored .040 over 22re is?
84Yota
  • Turtle Points: 10
  • Male Posts: 173
  • Member since Aug '06
Re: 22re question
« Reply #4 on: Feb 03, 2008, 05:59:18 PM »
Well let's see:
-Stock 22r/re bore and stroke: 92mmx89mm
-Bored .040 22r/re bore and stroke is 93.016mmx89mm (.040in is 1.016mm)
Plugging these numbers into this calculator: http://www.race-cars.net/calculators/displacement_calculator.html , we get:
-Stock 22re 92x89 bore/stroke: 144cu, 2.37L (Toyota says it's 2.4, but it seems manufacturers round their numbers frequently. Ex: the 302cu Ford they call a 5L, and the 304cu Jeep is also called a 5L. Not a huge difference in cubes, but I doubt either of these engines are exactly 5 Liters)
-Bored 22re 93.016x89 bore/stroke: 148cu, 2.42L
So it looks like you gained about 4 cubes, but it's still a 2.4L. These numbers may not be dead on, but it gives a good approximation, obviously.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: 22re question
« Reply #5 on: Feb 03, 2008, 06:02:35 PM »
the ford 4.9/300ci six is really a 5 liter and is the chevy 305 v8
84Yota
  • Turtle Points: 10
  • Male Posts: 173
Re: 22re question
« Reply #6 on: Feb 03, 2008, 06:03:59 PM »
Yup, another perfect example.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 22re question
« Reply #7 on: Feb 03, 2008, 06:32:57 PM »
i have a 2.5  but it is bored .060 over  and stroked to 91mm
boggerunner [OP]
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: 22re question
« Reply #8 on: Feb 03, 2008, 06:55:06 PM »
well thanx for the help, and how did u stroke yours? diff rods, and crank
? or a strocker kit?
Re: 22re question
« Reply #9 on: Feb 03, 2008, 07:33:45 PM »
$1200  in custom machine work :thud:
Last post May 11, 2005, 10:37:20 PM
by Uncle Jesse
Last post Jun 07, 2006, 02:49:31 PM
by Tice
Last post Jun 22, 2008, 09:11:38 PM
by NorCalToy
Last post Jun 21, 2014, 03:57:03 PM
by Erick561
Last post Mar 25, 2016, 05:40:32 PM
by shudson
