Author Topic: question about 22re  (Read 1833 times)
booger1
  • Turtle Points: -63
  • Male Posts: 102
question about 22re
« on: May 11, 2005, 10:10:05 AM »
I just got one of those little valve cover breathers from auto zone.  my truck has a 22re.  there is a hose going to the valve cover to the efi thingy.  how do i install my valve cover breather?  do I plug the hole by the throttle body or will it work at all?
93 pickup,  sas'd, 36in tsl's, tundra front clip, taco bed, kenwood, apexi intake,  7mgte.
BLUCRUZ
  • Turtle Points: 241
  • Male Posts: 470
  • Member since Mar '04
  • CA4WD LIFE MEMBER
Re: question about 22re
« Reply #1 on: May 11, 2005, 10:51:50 AM »
Breather :dunno: Why do you want to run a breather? The efi is a closed system. You may have vaccum issues by putting a breather on a 22re
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
« Reply #2 on: May 11, 2005, 01:51:31 PM »
You do not want to run a breather at all. As said before, it's a closed system, and the MAF will not read correctly, and will cause all kinds of problems.
Erik :beerchug:
* Regardless of what happens, someone will find a way to take it too seriously.
* 2% rule: Must be 2% smarter than what your working on.
* If you make something even a fool can use, only a fool will use it.
* I've been crapping in the woods longer than lil'buddy has been alive!
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #3 on: May 11, 2005, 05:13:10 PM »
air that flows through the breather/pcv system is measured by the air flow meter.  If you install a valve cover breather, the air going into the pcv system will no longer be measured by the AFM, and will more than likely wind up with a lean condition.
Also, why add another filter that you will have to clean?
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #4 on: May 11, 2005, 06:08:13 PM »
I used to think that was a cool idea, but you would be better on building some kind of ducting to get colder air pointed in the direction of the air filter. Also try some hot water pipe insolution from Orchard Supply and wrap up your intake system to prevent the hotter ambient air under the hood from warming up your intake routing..
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #5 on: May 11, 2005, 10:37:20 PM »
I believe either summit or Jeg's sells a product called "Cool Tape".  According to an article in an old four wheeler, it works.  Instead of insulating intake pipes, the cool tape is used to reflect engine heat.  Thats what gets you, is the heat from the engine compartment.  There is not much you can do about the air flowing through the intake.  22re's from the factory have air pickups right behind or next to the LH headlamp.  Can't get much cooler than that.
While we are on the subjuect, modifying the intake tube will be worthless on a 22re, due to the fact the Air Flow Meter is the main restriction in the intake tube, and you can't change it(not only is it a small hole, but the air has to force the door open in the meter).  Hence the reason car manufacturers switched to mass air flow sensors, as they flow more air, and measure air volume better than AFM's and MAP based systems.
Last post Jul 07, 2005, 08:17:19 PM
by alwayzbroken
Last post Nov 22, 2005, 06:24:28 PM
by WHITE_TRASH
Last post Dec 12, 2005, 06:12:17 AM
by Zoomschwortz
Last post Mar 28, 2006, 04:16:19 PM
by bmxanddie
Last post Jun 07, 2006, 02:49:31 PM
by Tice
