Project Snoopy: 85 4Runna - Rebuild 1.0
Started by Jordan7118, December 11, 2007, 06:05:40 AM
Jordan7118
 :love:
Sorry for the lack of updates. I don't have internet access like I used to. I now have to travel to get online.
I've been working on the welding cart. I don't have pics on this computer to show you, but it's coming along nicely. I took the tires off a small ATV cart. They're pneumatic and roll nicely. I've made two hoops for the cart out of .5" sch. 40 pipe (about 1" OD). It's been a steep learning curve, but I'm making progress.
The welder is quite nice. I don't like the flux core, so I'm looking forward to getting a tank and solid wire soon.
No real progress on Snoop. I'm waiting to get the cart done before I tie into him again. I'm really anxious to drive him BUT I know that won't happen without work on my part.  :outtahere:
Keep on keepin' on, Crawler Kids!!!  :beerchug:
Jordan7118
Dang, it's almost been a month since an update... well, not really.
I finally completed the welding cart, and it looks nice in my opinion. I'll post picks when I'm on my comp.
I'm almost done with mounting the t-cases. It's gonna be tight. I painted the front crossmember to ward off rust, and also the steering box. Next will be driveshafts, and I have something sweet planned.
I'm really diggin' the welder. I'm glad I jumped to 220. I also got a bottle so I could do solid wire. Flux sucks... I plan to get some stuff done this weekend. I'll post more when I get time. Holla!
Gittinit
Quote from: Jordan7118 on July 04, 2008, 12:25:32 AM
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Jordan7118
Haha! Read it all, Glen!  :talkingn:
Sorry I haven't posted up progress... again... I have pictures uploaded now, and I'll put a few on here for those who don't want to retrieve them. However, feel free to look at the rest that are on my photobucket.
Coming together
Painted
Complete minus bottle
The welding cart is DONE and it works flawlessly. I bought a bottle and got some solid wire. Flux just wasn't cutting it, and I'm really happy with the gas welding. I'm really glad I got the HH 187, too. I've used up to the 5 setting on amperage out of 7. It did great on burning in 1/4" plate to 1/2" plate for the t-case mount.
Progress: I'm almost completely done with the crossmember and t-case mount. I just have to weld in the mounts for the bushings, and I'm really pleased with how it turned out. The lowest point on the drivetrain is the second t-case oil drain plug, and it's still about 1/4" above the bottom of the frame rails.  :thumbs:
I've found what I plan to use for the front driveshaft. I went to the local Ag. Co-op and bought a PTO shaft adapter tube that receives a 1 1/8" solid square rod and mounts to a round tube. I think I'll run the slip at the t-case mount so that I don't mangle the square shaft on the rocks. I'll put a shock boot or something over it to keep it from hydro-locking. Thoughts?
I painted the steering box and finished up the brace for the box. I'm glad I went with the flat pitman, as it clears the bottom of the framerail by about 1/4" to the top of the TRE. Now I need to mount up the hydro-assist.
I need to cut the rear fenders for the larger tires, and I have a couple thoughts on this. I think, first, I need to move the axle back into center of the wheelwell. This would make it look better. Then I'm thinking about buying the wheeltubs from Summit that fit 40" tires, are 24" wide or so, and just butt them up against the current sheetmetal. This would give a huge wheelwell, but maybe that's just a little too much opening for what I'm doing.  http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG7920&N=700+%2D105357+115&autoview=sku
I'm so close yet so far from being done.  :down:  I just have to keep chugging along.
DTB
You're supposed to be working on the truck! not building other crap! Git er done boy! :whip:
Jordan7118
Quote from: DIRTOYBOY on July 14, 2008, 05:27:35 AM
:smack:
Sometimes I forget the order of importance...
... But it does look nice, right  :eyebrow: And man is it a breeze to move around  :horseride:
dude  you should have used solid tires,  yea they dont move as easy but when a  red hot cherry rolls  over  and under those rubber tires and you here that hiss, its gonna suck
Jordan7118
Quote from: 79coyotefrg on July 14, 2008, 08:01:14 PM
I've got a spare and I know how to plug  :thumbs:
Jordan7118
#281
I'm still working, I promise...
Cut out the fuel inlet and vent from the Toyota tank and put them into the Ford tank. I tried soldering it in there, but that turned out like poop, so then I tried welding it in there. That turned out better. After several hours of trying to get it to seal with a mixture of solder and welding (and several blow-throughs  :shake: ) I gave up and JB-Welded all around it. I capped off the Ford inlet and called it good.
I was able to cut off my front perches for my rear springs and salvage the mounts. I plan to put the mounts 3 inches or so forward to put the axle slightly forward of the center of the wheelwells. I should've done that in the first place, but I was blinded by the shackle angle  :inthedark: I'll have to move my rear shackle hangers forward, but YotaJosh was able to save them and make it work so I should be okay.
I'm really not sure where I left off on updates... Oops...
I'll be able to make the Agri spline work in the front. This isn't the typical "triangle"-looking shaft. It's a 1 1/8 " square slip going into an adapter with aroun a 1.9" ID tube. I can make this work and keep the round tube round and the square shaft square by putting the slip at the transfer case end. T
This will keep the square out of the rocks. I'll post measurements sometime, but the IFS front shaft has a larger diameter machined part on the slip yoke, so that's what I'll be using with an 85 CV on the t-case side.
I know everyone likes pictures, so I'll try harder to take more. I just get so dirty and work alone: makes it difficult to stop, clean my hands and take pics.
I'm on the smaller stuff now, I think. I've been working almost every evening, so just be patient.  I have to tell myself to just keep chugging along  :gap: I'll update when I can.
Gittinit
You have a deadline here ya know! Sept 19 it must be ready to wheel, so try to have it done, and a shakedown run before that would be a good idea. You don't have to tell yourself to stay at it, we can do it for you.......Get to work slacker!
my favorite places:
YotaJosh
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Doable
Come on man lets see some sexy pictures of the 4Runner even if it is still on the ... :greengrin:
Have been following the updates , if ya'll have a run in September you are running out of time my friend. O.K. lets see some  :snapshot:
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
John Doe
I am really looking forward to your opinion of the Ford tank.
Keep up the progress.
Gittinit
Quote from: Doable on August 03, 2008, 09:24:38 PM
Your gonna make it to right Doable?  :yesnod:
my favorite places:
Doable
Would LOVE to wheel Superlift park again!   Do you know how much the cost for the weekend up there? We work a 5 man department here at work and 3 quit this week for a better job. If they get some people in here maybe by then they will be trained up I can use some vacation time. ...
BSLCA.com
Gittinit
#288
I think some others were trying to figure cost for the weekend's event, and came up with a $75 figure including wheeling, camping, the big bbq meal, and a t shirt
my favorite places:
Doable
#289
Yea cost  $$$ is a concern I usually burn four tanks round trip so that adds up to about $300 (+) the fee for the weekend and the eating on the road up there and back. Still I will look into it, sorry Jordan highack of thread over  :sly:
EDIT: looked at the finances last night with my wife  and to find $400.00 extra in two months to make the trip just does not look like it will happen. Sorry looks like I will have to be a webwheeler on this one.
BSLCA.com
Jordan7118
#290
Hey Albert!!!   :wave:
Hey to the regulars - Josh and Michael!!!  :thumbs:
Yea, it's a $75 fee for the weekend that covers the three days, meal, and a year membership to the park... I think...
I just got back from Lowe's. I'm almost finished with mounting the tank. It sits right behind the axle and hangs down about an inch in the rear and 3" in the front (cab side). I'm really pleased with how it has turned out.
Albert, you're right. I really have to start moving if this is gonna make it. It's back on jackstands in the rear to put the rear axle forward. Just got off the phone with Datin Fab, and they're out of stock on the spring hangers with a 9/16" hole until the 11th, so I guess I'm gonna make my own. No biggie. I'll post pics when I'm on my own computer. I know that's why I look at people's buildups, so I'm sorry I've been slacking. I'll go back and add pics later. Now I've got to get back to work  :whip:
YotaJosh
Quote from: Jordan7118 on August 06, 2008, 09:49:39 AM
Just buy the 18mm ones, and drill out the Ford bushings with a hole saw, and use new Toy bushings. That's what I did for my shackles. It's a perfect factory fit.
Jordan7118
#292
Quote from: YotaJosh on August 06, 2008, 11:02:40 AM
I ended up cutting out some "washers" with a 9/16" hole from 1/4" plate and welded them around the spring hangers. Worked out great!
I got the rear gas tank hung, put the suspension back in. I moved the front spring hangers in the rear forward 11.5" eye to eye. This puts it much more center than it was at 8.5". I moved the rear hangers forward a little. I can't remember how much.
Tried to fill up the radiator to get closer to starting it up, but found a giant crack in the bottom. I tried to solder it, but it didn't take. I plan to take it to a radiator shop to see what they can do. If nothing else I'll just put the stock radiator back in.
Next on the agenda is to fab up the tranny tunnel so I can put the t-cases back up for good. That'll be a big relief.
I'm going, guys. I've been putting in 8 to 12 hour days lately on it. I work slow, and I promise I'll get pics up soon. PROMISE!
good news is the heat has broken :woohoo:
:whip:  get to work slacker  :whip:
Jordan7118
Quote from: 79coyotefrg on August 10, 2008, 09:06:00 PM
Who you callin' slacker, Glen?
Where's my money?  :bat:
Quote from: Jordan7118 on August 14, 2008, 02:34:05 PM
??  :headscratch:  i still owe you for ...................................................
:smack:  the  ebrake  :smack:
how much do i owe you??  i havent gotten my settlement yet but i hope your not worried,  just dont let me forget, like i apparently just did :ask:
i better make another "do i owe you anything" thread again :headscratch:
Doable
Jordan,  get your @ss in gear. I just signed up for ya'll trail ride. $$ will be tight but I think i can pull it all together. Will you have it finished in time?
I'm running stock axles shafts in the front so i'm not going to push my luck on running the truck hard , but I'm looking forward to wheeling with you guys!
BSLCA.com
Jordan7118
Quote from: Doable on August 14, 2008, 07:44:29 PM
WOOOOOOO  HOOOOOOOO!!!!! :clap: :banana: :woohoo:
I'm gonna work my ace off to get it to work for that weekend. I'll be there regardless, but I'll hang my head if I'm not in my own ride... :spankbutt:
Quote from: 79coyotefrg on August 14, 2008, 07:16:18 PM
Yea, I'm not worried about it. It will come in due time. Just had to put the ball back in your court  :thumbs:
BIG ANNOUNCEMENT:
Snoop's ready to roll! Granted I don't have everything done, but he's done enough to move. The only problem is that now he won't start  :smack:
I had to rethread a spark plug hole because it was all jacked up. I recut the hole, and so maybe that's what's up. I checked the gas tank, and it works. The pump pumps wonderfully. What's the deal??? I was SOOOOOO excited to get it to start, but now that's over....
I'm back in Fayetteville, but I'll be back in Hot Springs in a couple weekends to finish up.
Need to:
-mount shocks front and rear (towers front)
-wire up e-locker rear - have ORS harness
-plumb ARB up front - have compressor, need axle fittings
-make tranny tunnel -pain in the bum...
- d-shafts, front and rear - rear easy, front needs some lathe attention
- brake lines - front only - need extensions
I'm sure there's more. I'll post pics (I PROMISE) when I have time and my own computer. Help me out on the starting issue!
for a quick fix extention you can use a rear brake line up front,the rear threaded onto one end  of the front line
Gittinit
does it try to stsrt? what does it do? Are you getting spark, and fuel, and air?
my favorite places:
