Sorry, Guess I was a little vague on some points here.1984 22r with a 32/36 webber. All emsions equipment removed.Everyone has mentioned the timing, my vacume advance right now is just one vacumeline teed off the go onto both ports on the distributor.Going to buy a timing light and check it out when I get home.P.S. if my setup is wrong with the vacume let me know so I can fix it.
best thing you can do is swap your 22R distributor for a 20R distributor, gives a slightly longer spark,
I have had the impeller come loose on the shaft on a brand new water pump in the past. Will not work well when that happens
Started by traveler727 Engine
Started by Phazertwo « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by 8Snaces Toyota Pickup/4Runner Tech 1979-95
Started by Plekto Engine
Started by kauaikid Toyota Pickup/4Runner Tech 1979-95
