What is wrong with my motor ?(UPDATE FOUND THE PROBLEM!!)
Started by Phazertwo, April 27, 2006, 12:05:40 PM
Phazertwo
should I replace the oil pump?  or just reuse it?  oil pressure was still good last time i drove it...
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
Volcom
Quote from: Phazertwo on June 21, 2006, 12:31:50 PM
Is it fairly new?  If not, they are cheap and I'd get a new one.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Phazertwo
I have decied to keep it.  It has ~550 miles on it...
make sure that dang balancer  shield is on all the way, and make sure the oil pump drive gear on the crank and timing gear are the right ones,
Willy Mammoth
Also, is the shield bent? Why is it rubbing? Make sure the crank does not move in and out or this could be why it was rubbing.
If it does, you know the thrust washers are bad.
ZUK
Quote from: Phazertwo on April 27, 2006, 12:05:40 PM
...................... and the only place I can hear it is when  the end of the scope is on the timing marks on the oil pump housing.  weird I know.  ................
TIA
PZ
So the stethoscope was pointing right to the problem area but no one thought of the balancer.....  Next time. :therethere:
           www.gearinstalls.com
2001 White Xtracab Taco 3.4L Auto TRD
88 Runner/V6/auto/31"/5.29gear
Phazertwo
Quote from: 79Coyotefrg on June 21, 2006, 05:23:05 PM
From what I can tell it is on all the way.  I was wondering if there is supost to be a spacer, but didn't see one in the FSM.  I belive all of the parts are the right ones...
Quote from: Willy Mammoth on June 22, 2006, 04:09:50 AM
The crank has no endplay that I can tell with my 1ft pry bar.  I read that its supost to have like .003-.007 end play.  There was NO metal in the oil this time, and from what I can tell with the oil pan off, the thrust washers are fine.
Quote from: ZUK on June 23, 2006, 10:14:22 AM
yep, I am an idot!
PZ
Phazertwo
FINISHED!
Just taped the dust cover on more with a rubber hamer (moved about 1/16th) and I am good to go.  I know now that I didn't need to change my timing kit, but I am glad that I did because this DOA kit is really nice!
Thanks for all the help!
PZ
Duffil
Before you put it back on, you might want to replace the bolts in the balancer with some of the correct length.  If you look at the pics above, it appears that is what pushed the shield back(notice the 4 8mm indentations). :twocents:
BoG-ToY
also....RECHECK your endplay just for kicks....now your dust cover isnt working as one of your thrust bearings....you might have done this already
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
Quote from: Phazertwo on June 21, 2006, 12:27:30 PM
I FIGURED THIS POS OUT!!!!  only its to late to save the $300 i just spent on it, and now its gunna be more!
The dust shield on the harmonic balancer was rubbing on the oil pump!
Freekin SOB!  If I would have just pulled the balancer off and looked at it.  Oh well, the new timing kit is WAY nicer than the old one.  However I broke my timing cover, so now I have to take it back off and replace it!
PZ
ah yes,  the powersteering pully bolts  are too long
