Author Topic: why wont my POS Start  (Read 2304 times)
bigman
  • Turtle Points: -10
  • Male Posts: 201
  • Member since Jan '05
  • punish all jeeps
« on: Jul 30, 2007, 01:08:17 PM »
ok 91 new battery, starter and alt and it mont start. all i got is a little click from the starter but not enough power to start i :help:t can anyone help me
MONTANA BOYS KICK A$$
IF U CANT DUCK IT F IT
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: why wont my POS Start
« Reply #1 on: Jul 30, 2007, 01:10:55 PM »
make sure yougot a  ground strap  from the block to the frame  and  body  to battery
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • SimpsonBrothers.net
« Reply #2 on: Jul 30, 2007, 01:19:31 PM »
Also try hitting the starter lightly with a wrench. Always works for me. :gap:
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #3 on: Jul 30, 2007, 01:34:06 PM »
x 2 :gap:
Quote
bigman [OP]
  • Male Posts: 201
  • punish all jeeps
« Reply #4 on: Jul 30, 2007, 02:03:50 PM »
got both of them
x 2 :gap:
that was the first thing i tried
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #5 on: Jul 30, 2007, 02:21:57 PM »
What condition are your cables?  If you got the original battery cables, get rid of them and get better heavy duty cables!  Factory cables are small and corrode very easily!  Get cables that have sealed ends.  The factory clamps are garbage too!
Make sure all the grounds are cleaned real good too!  Take some sand paper, or a small dremel tool and clean the area the ground straps go to, and buff up the connectors too!  And make sure the bolts, screws are tight!  I like to use a small bolt and nut, when I can, to fasten the grounds to the body!  You get a tighter hold.  If your not able to, use a lock washer as it will bite into the ground and contact!  Also, I use some anti-corrosion to keep the contacts clean!
Also, check your starter relay, it may be weak, and not giving 100%.
Toyota's (22re) have 3 ground points, one by the alt., the back of the block, and the ground from the negative post that goes to the block and a small wire to the fender!
Head gasket in good shape?  If not it will hydraulic a cylinder and your starter will engage, but won't turn over!
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #6 on: Jul 30, 2007, 03:43:50 PM »
Bypass the ignition wire by running a aux. light relay, run the ignition through the the relay like it is a toggle switch then run wire direct from the battery like you would with the lights, then run the other side of the of the ignition wire (starter side) like it were the lights. No more click, click. You can also use a Ford solenoid but I don't like anything that will possibly stick open if you have a low battery condition.
BULFYTR
  • Male Posts: 47
  • Member since Aug '06
« Reply #7 on: Jul 31, 2007, 01:46:06 PM »
try jumper cables from pos .on batt to starter that will tell you if you have a bad cable
build it right-wind it tight
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #8 on: Jul 31, 2007, 09:55:17 PM »
Are you totally sure the battery was fully charged when you got it?  Sure your connections are all tight and you have no bad wires?  You didn't buy the starter from vatozone or kragen did you :_oops:
Last post Jun 17, 2005, 06:18:21 PM
by Cheesemaker
Last post May 29, 2007, 12:35:55 PM
by GrenadedToy
Last post Oct 08, 2007, 11:47:38 PM
by fordh8r
Last post Oct 21, 2007, 07:29:43 PM
by Cheesemaker
Last post Oct 24, 2007, 01:39:29 PM
by y-townxj
