79yota build(wheeling pics)
Started by boggerunner, May 25, 2006, 10:44:44 AM
boggerunner
i still havent gotten a chance to work on it, ive been stuck in utah for the last 3 days woring on a drilling rig, utah sucks, u gotta buy a membership to the bar, and they all suck.
ohh well gettin paid for 16 hr days and only havin to work 6 is really nice when it comes payday
boggerunner
i got most of the top 3 link done, here are some pics, i used schedule 40 1" pipe
yotadork83
i woulden't expect that scedule 40 pipe to last long at all. diffently wouldent drive it on the street.
yotas 4 life homie!
boggerunner
my bad, i think it is schedule 80 pipe, here is a pic
boggerunner
got my 2nd tcase adaptor ordered on tuesday night, here comes triples! just need to finish trusing the rear axle and weld up all my 3 link bars, and spring perches, and new driveshafts, and new tcase crossmember and cut out the bottom of my cab for a flat belly setup, man i got alot of work left
blackdiamond
Quote from: boggerunner on October 11, 2006, 07:15:27 PM
What is the price difference between an adapter and a set of 4.70 gears?  In the end, your gearing options are about the same.
:headscratch:
boggerunner
adaptor is 350, gears are 400,    and i had a spare tcase layin around so i thought what the heck,   i'll try it,  plus i want to be unique, and later on down the road im gonna get a set of gears for one of my t-cases
blackdiamond
Quote from: boggerunner on October 11, 2006, 08:17:08 PM
Let's see 2.28 x 2.28 x 4.70 = 24.43 assuming 4.10 r&p and 3.93 1st = 393.64 crawl (if my math didn't fail me).
Where are you planning to go?
rednk1980
Quote from: blackdiamond on October 11, 2006, 08:27:56 PM
about ten feet at that speed.  :thumbs:
boggerunner
im gonna get 37 mtr's and i have 4.37 r & p, but im goin 4.88's
Shamb
i'd gusset the crap out of that 3 link, if not your going to bend it on the first trip out.
My links are 1 1/2" dom thats 1/2" thick and i've already bent mine.
Yota87Truck
Lookin good, post some more pics when you have a chance
boggerunner
got a bunch done today, finished my top 3 link bar and got my axle trussed, here are some pics
boggerunner
some more :willynilly:
rednk1980
CTENG in KS
Is it just me, or is the axle truss crooked?
boggerunner
yep its a bit off, but i cant fix it now, so i will work woth it, its not a show truck or anything
boggerunner
got some new parts today, and started assembling my 2nd crawler box, and here is a pic of my 3rd t-case
boggerunner
here is my new fuel cell, and a pic of the duals comin out, and my crossmember
toytank
damb look at those welds!!! you should let me cut that off and make it level show rig or not (hey found 5:38s for the 44s
old and sqeaky but she goes
Yota87Truck
Wow!! Coming along pretty good.  Keep up the good work!
boggerunner
i almost got my triples done when i remembered that my case i built 2 yrs ago needed some work like the keystock for the shifter and cut the shift fork down, should finish them up tomorrow
Sluice Box Hero
would have been less work and $$ to just put in a 4.7 gear set, i gave get a set installed now in 3hours, how long does it take to put in another adapter?
Callen
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
boggerunner
the adaptor is cheaper, and my drivelines are gonna be the same length so i will only have to carry one spare
boggerunner
started installing my triples tonight and one of the input shafts was different so i had to grind some excess splines off it and it fit perfectly.
Yes i know i need to clean them, but that will come later when i can get the truck to a pressure washer, here are some pics of my triples and the beginning of my flatbelly
boggerunner
more pics
boggerunner
and the rest, yep im gonna have to build a new crossmember
boggerunner
#58
im also goin to cut up the back of the cab for driveshaft clearence
