79yota build(wheeling pics)
Started by boggerunner, May 25, 2006, 10:44:44 AM
yotadork83
hate to give them credit for any thing but i still like them gussets better myself.
yotas 4 life homie!
boggerunner
so tonight i got most of the tranny crossmember done, used some 90 4runner bottom links and welded them to the crossmember, and used some channel on the frame sides.  Just my luck i ran out of wire when i was half way done welding. so tomorrow im goin to pick up some more wire, and finish welding so i can get back to the front axle
boggerunner
and the finished product where the triples will rest for good
Yota87Truck
THe interior on the 2wd is sweet, how long did it take?  Your 1st gen looks like it is coming along pretty well!
boggerunner
i did all the interior in a couple of hrs, just primered everything, then painted it with some cheap paint, and i hope to have my 79 done in the next month or so
topar
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
boggerunner
today i added some braces to the crossmember and painted it, here are some pics
Yota87Truck
Wow, that crossmember looks really good for a home job.
boggerunner
thanks, i didnt get anything done today, went snow wheeling instead
topar
Birfailed
See this rig all the time and wheel with him, crazy driver and crazier rig!  Can't wait to see it when he;s done with the new mods!
Go 1-Ton from the start
Birfailed
He's doin his 3 link, I'm doin 4 link with 1/4 ellips and Toy Tank is gonna run F-150 Buggy leafs...we try to all run together
toytank
:pokinit: im falling behind again  hey phil if you get a chance look at the johnson valley trip all pro put togethewr  they have a few pics it looks like a badass trail its in trail reports
old and sqeaky but she goes
boggerunner
got the trussed housing up front and painted, and here is a pic of the old pathetic 79 axle
boggerunner
no pics tonight, ive been cleaning up the knuckles and spindels, man these things are greasy, im gonna take them to work tomorrow and use the parts cleaner, then i can assemble the front axle and crossover steering, and i will get to test out my new lincold 140c welder tomorrow night too  :flamer:
boggerunner
anyone interested in a 79 or 85 front axle housing?
my garage is gettin too cluttered
toytank
let me clean mine up i may need it that birf messed some stuff up pretty bad
boggerunner
got the new welder setup, but no time to play with it, gotta go out drinkin or sumthing, and i gotta work tomorrow
boggerunner
got to finally use my new welder today to fix the muffler on the 4runner, the inlet tube fell out of the dam thing(just my luck)  cleaned up my knuckles, and worked on running ifs calipers and brakes, and i made a huge breakthrough, i have a set of aluminum 3/4" wheel spacers that i drilled out to put between the hub ass and brake disc, and the brakes fit perfectly. dam i got lucky on that one. sounds like the $200 kit from sky isnt worth it if u arent lazy and know how to operate a drill press. here are some pics of my progress
Birfailed
Hell yeah, that was a damn good idea.  Can ya amke me a set while it's still fresh in your mind :bowdown:
boggerunner
yep, if u buy some 3/4" wheel spacers, i will get right on it, but its gonna cost u a taco bell dinner
toytank
so much for my wheel spacers eh. looks good if buys you dinner will you make me some to?
boggerunner
i dont know how much the spacers are, i got them from chris, and i dont have a clue where he got them from, but try some tire shops tomorrow
Birfailed
Can you make mine from Cryo'ed 4340?
toytank
boggerunner
if u buy the material
Quote from: Birfailed on January 22, 2007, 07:32:33 PM
and what? have u been drinkin jack again?
Quote from: toytank on January 22, 2007, 07:35:02 PM
mama mama need help
Birfailed
toytank
i need some ideas for coil spring mounts  dont want to use the round tube with a plate it already sit a little high?
Birfailed
If I was in your situation I'd find some coil spring buckets, cut out the bottom of em so they straddle your axle tube nice and snug, weld up some guessets and then move on to the top bucket.  Or you could heat the springs up with a torch to get them to drop. With your steering behind the axle you could maybe mount buckets to the front of the housing, nice and low too...But I bet you'd end up knocking a spring out hitting rocks.
