79yota build(wheeling pics)
Started by boggerunner, May 25, 2006, 10:44:44 AM
boggerunner
last night i ordered my high steer and crossmember for my triples, should be arriving monday or tuesday, then if i can get some time off work i might be able to make some progress
rednk1980
boggerunner
#62
no progress tonight, just got a new truck, 84 2wd toyota and i have a chevy 283 v8 for it, but imma see whats wrong with the 22r in it first
boggerunner
got started on my new truck this weekend, the 22r was siezed up so i gutted it and cut out the inner fenders.  makin some room for the v8 also got a weiland high rise intake manifold and holly carb with some hedman headers
boggerunner
more progress
boggerunner
the rest of the days work :sleeping:
boggerunner
so im side tracked on my 4x4 till i get parts so here is what i got done on my 2wd, installed 4wd fenders, v6 grille, 4wd bumper.  Also got the weiland stealth intake manifold and holly carb installed
Twisted Minis
Both trucks look pretty good. That small block will be sweet in the 2WD. What are your plans with the 2wd?
2002 Dodge 2500 Cummins
boggerunner
made some progress on both trucks today, got the crossmember bolted to the back of the t-case, and ready to stard building the sides, and on my 2wd i got the motor and tranny assembled and set in place under the hood, tomorrow i will start building motor and tranny mounts for it and get some pics.  I also got my crossover steering in, time to start building a new front axle, i need axle gussets, top gusset and chromolw birfs and some new seals, ohh and some diff armor
boggerunner
so i got the motor and tranny stuffed in it last night, and i got some of it primered white today, here are some pics
boggerunner
Quote from: Twisted Minis on October 30, 2006, 11:41:16 PM
im gonna put in some bucket seats, toy 85 4wd rear housing with v6 3rd with 4.10's, and i am goin to check if anyone in town can narrow it so i can fit some 31X 12.5 street slicks, 4 link to come, and i want to convert the front suspension to coils, its already missing the bolts for the torsion bars, so its layed out and it has 4" aluminum blocks in the rear that are gonna be replaced by some leaves , and a kiker to help with axlewrap.
im also gonna mount the radiator and fuel tank in the bed, i will try to find a 16 gallon fuel cell for it. i want a roll pan and a frenched liscence plate box for the rear, and im gonne paint that ugly brown dash, and plans for adding an interior cage. more to come
boggerunner
thought u guys might get a kik outta this,  :willynilly: my first toyota was an 84 2wd dropped with a 22re conversion, 4wd fenders and bed, with a sunroof from an 87 mr2, i still regret gettin rid of that truck :(
Twisted Minis
#72
You should bag it. If you're going to 4-link it, you might as well. Lol.
boggerunner
Quote from: Twisted Minis on November 02, 2006, 10:43:11 PM
no bags for this one, im tryin to keep it under a grand, im at $450 so far, i did find  a set of 17" mustang wheels and tires for $350
boggerunner
so today i got the engine mounts built and tranny crossmember done, and the tranny dipstick bent to fit, im goin to pick up some bucket seats today, and a rear drive shaft, and some headers for a chevy v8 into a cj7 conversion.
6.72:1
Wow, you have a lot going on there sir!
How difficult is it to put a V8 in a little Toyota?
Also, are you planning on running an American transmission as well? (700R4, Turbo 350 or 400)?
I was thinking about going American with a Toyota at one point and time, but the wiring of the thing scared me away!
I had a friend tell me he had 4 wires running his 350 in his Toyota. Is this possible?
Anyway, I apologize barging in like this!
Look like you are getting a lot of work done there!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
boggerunner
it fit pretty good considering im runnin the radiator in the bed, and i put a turbo 350 behind it.  Im gonna run the 2wd rearend till it explodes, then i have an 85 4wd  with a v6 4.10 third.
wiring is gonna be cake, 2 wires for the dist. 2 for the starter,  the tach wire, and a temp sensor wire.  the wiring is the least of my probs, the headers i need to buy are gonna cost my ass, so im gonna take the blazer headers i got for $50 and cut and rebuild them so the exhaust comes down under the cab on the outside of the frame with cherry bombers and exiting right before the rear tires.  Gonna be a busy week, bringin my driveshafts to the shop tomorrow.
6.72:1
Looks like someone will be having fun here in the next week!
[email protected]
boggerunner
hopefully, driveshaft will be done tomorrow, rear suspension is dropped to match the front and the blocks are gone, still need to build some headers, not lookin forward to that
gonepostal
both of your projects are looking good. :thumbs:  how hard was it to bolt the '92 dash and swap the motor?  I'm doing a similar project and was wondering about these things.  I have a '80 yota and a '92 and want to swap the drivetrain, harness and dash to simplify the swap with '92 stuff into the '80.  any help and things to look out for would be greatly appreciated.
thanks
boggerunner
the hardest part is cuttin the back off the dash on the top to fit against the bottom of the windshield, and wiring was easy ecept for the heater wiring, i never got that far, but everything else fit pretty good, i used the 79 dash mountin points, and bent L bracets and zip screwed them to the dash, and they have held up for 2 yrs of hard wheelin
boggerunner
started building my own headers tonight, hopefully i will get alot done tomorrow and get some pics on here
boggerunner
well the headers are takin longer than expected, and not lookin like headers anymore, but here are some pics of what i did to the dash
6.72:1
[email protected]
boggerunner
im not a huge fan of the turd brown toyota used, but im off to work on the headers, lates
6.72:1
[email protected]
toytank
wow you even oversprayed the carpet( hows the header progress
old and sqeaky but she goes
boggerunner
headers are comin along, halfway done, got some 17' mustang wheels on it, grant gt steering wheel, and all the parts i need to finish it, now i just need to get after it  :flamer:
6.72:1
[email protected]
DTB
those mustang wheels and blue dash are hideous but everything else looks all good! :disturbed:
