The Official 3RZ Knowledge and Database Thread
Started by BigMike, January 03, 2006, 08:44:17 AM
1Bad4Runner
Perfect... Now I just have to get the money to do the swap. Probobly gonna cost me around $2000 I would assume.
89' 4Runner || Everythings Gone!! for now.
97' 4Runner, 2.7, Auto - Daily Driver
jr9162
The 05 Tacoma has a 2.7L inline four (2TR-FE) coupled to a R155F gearbox.
I wonder:
1) What is the input shaft length of the R155F gearbox?
2) Will the 2TR-FE bellhousing bolt onto a 3RZ-FE block?
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
toyotaj
I am considering a 2rz swap. I found a very cheap low milage 2rz.. the problem is that it is from a yard and they are selling w/o alot of the accessories I need. Bellhousing, starter, computer etc. Are there any parts from my 22re that will work on the 2rz (motor mounts, alternator, etc.)? How interchangeble are the 2rz and 3rzs? My understanding is that they are nearly identical. 3rz is just a stroked version of the 2rz.
-J
TacoRunner
My recomendation to you is to find something more complete. you will spend less money in the long run if you buy something fully dressed. And it will an easier swap that way.
www.4WHEELUNDERGROUND.com
[email protected]
hopper
About how much would I expect to pay for a decent 3RZ?  How much does the swap usually run?  I have a '85 Toy pick-up w/ a 22R.  I have dumped a decent amount of money into the 22R recently and it still wants more. :shake_head:   I re-did the timing chain, water pump, head gasket, and clutch.  I now think that my rings are going so I want to see if the cost for a engine swap would cover the power increase.  Thanks.
vikingsven
Quote from: jr9162 on February 18, 2006, 06:58:04 PM
I wonder:
That is a good question and to add to it:
3) Will the 2TR-FE Bellhousing bolt to the R150F or R151F Tranny?
That's what's holding my up from seriously looking into this swap since I don't want to swap my turbo tranny out for a 'lesser' tranny.
TacoRunner
Well I did a bit more than most of the guys here, I also swapped out the dash and everything behind it. All entire wireing harness from head light to tail light is tacoma. Same with everything under the hood. And I got lucky cause I didn't pay a thing for the Tacoma I used to swap everything out of.
[email protected]
LCOwner
This is :offtopic: a little but lets segway a little shall we?  It seems that the TRD supercharger is a little hard to come by at a reasonable price.  If another brand could be used what would it be.  I see that Whipple makes a unit for a PT Cruiser :reg: I wonder if that would be a possible alternative but I have no idea what the cost is.
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
jr9162
Quote from: vikingsven on March 13, 2006, 04:54:53 PM
Since the R155F gearbox is a 'R' series item, it should bolt to the R151F/R150F with no problem. The real issue is twofold: 1) does the R155F have a 160 mm input shaft like the other two? 2) will the 2TR-FE bellhousing fit the 3RZ? If the answer is yes to both questions, we have a bellhousing to mate the R151F to a 3RZ. Simple as that!
4RnrRick
Heres some good info to know about what should be level when positioning the motor. Its NOT the upper plenum like I was told. What you should level to is the PS cap / reservior.
Heres some pictures of a stock tacoma in relation to motor placement / rotation. Crossmember and PS cap / reservior is level, Upper Plenum is ~ 3 1/2 degrees rotated down to the passenger side.
4RnrRick
Then for my application 3RZ, W59 bell housing, W56 tranny, gear T-case I found that the PS pump cap needs to be rotated down at 1 degree to the passenger side to make the T-case level to the frame. you can also see that my mis alignment from the PS cap to the plenum is only 2 degrees  and not the 3 1/2 degrees like the pictures I posted above and I have no explaination of that.
TacoRunner
Hey Mike I getting lonley over here. I need pic's man.
[email protected]
4RnrRick
Just wanted to add that I was having some major problems getting teh factory tach to work with a twin-coil 2000 3rz. what I ended up doing was using a 10K Ohm 1/4 watt resistor mod that most of the 5vz-fe swap guys have to do to get their tachs to work. Anywys it worked like a champ for the 3rz!!!
Heres the location on a late model second gen tach. (my v6 tach looked like this)
Heres the location on my 2wd 85 22RTE second gen tach.
And here is the post talking about it in all its glory.....
http://board.marlincrawler.com/index.php?topic=23540.0
4RnrRick
So here it is - as promised!!!! The 3RZ wiring notes.
Wiring Harness: 2000 Tacoma 4wd Automatic 3RZ-FE
ECU: 2000 Tacoma 4wd Manual Tranny 3RZ-FE
D7 - OBDII Data link
Pin#, Color, Description
1, None
2, None
3, None
4, W/B, Ground
5, Br., Ground
6, None
7, W.., ECU SIL to E5 Plug pin #19
8, None
9, None
10, None
11, None
12, None
13, None
14, None
15, None
16, V.., OBD Fuse 10A from Battery
E5 - Plugs into ECU
1, None
2, B/Y, Batt, EFI Fuse 20A from Battery
3, V.., A/T Oil Temp (Remove)
4, V/R, Check Engine Light
5, L/O, A/T OD Lamp (Remove)
6, L/B, AC Amplifier (Remove)
7, L/Y, AC Amplifier (Remove)
8, G/O, SP1 to speed sensor in cluster
9, None
10, R/W, 4WD T-case Position (Remove)
11, B/W, STA, 7.5A STA Fuse from Battery
12, W/R, B+ EFI Relay #3
13, R/G, TFN, (T-case neurtal) (Remove)
14, G.., A/T Normal or Power (Remove)
15, V/W, A/T Low (Remove)
16, P.., A/T 2nd (Remove)
17, R/B, A/T Reverse (Remove)
18, R/Y, A/T OD Cruise (Remove)
19, W.., ECU SIL to D7 Plug pin #7
20, None
21, G/W, Stop Light Switch (Remove)
22, B/R, NSW, Neutral Switch, 7.5A STA Fuse
E6 - Plugs into ECU
E7 - Plugs into ECU
E8 - Plug into ECU
1K2 - Junction plug from Motor to Dash Harness
1, G.., A/T OD Switch (Remove)
2, Br., Taco Water Temp Gauge Ground (Remove)
3, Y/R, Water Temp
4, Y/L, Oil Pressure
5, G/Y, COR #4
6, Br., Ground to D7 Plug pin #7
7, B.., Tach
8, B/R, IGN #2
9, W/B, T-case Neutral Shift (Remove)
10, G/R, IDL Cruise (Remove)
11, P/B, Air Bag {LA} (Remove)
12, Y/B, Cruise {TC} (Remove)
13, None
14, R-W, 4wd (Remove)
15, None
16, W/R, COR #2
17, B/W, ST Relay #1 (Remove)
18, B/O, 10A Gauge Fuse, Backup Light Switch Power
19, R/B, To Backup Light or Relay
20, B/R, Ac Clutch or York, OBA
21, None
22, None
23, G/B, ADD (Remove)
24, B/O, A/T Speed Sensor (Remove)
25, L.., A/T Speed Sensor (Remove)
26, G/R, A/T Speed Sensor (Remove)
1K3 - Junction plug from Motor to Dash Harness
1, LG., Cruise (Remove)
2, V/Y, NEW 4WD Indicator Light (was A/T Park)
3, B-W, A/T Park/Neurtal Cruise (Remove)
4, P.., A/T 2nd (Remove)
6, None
7, G/R, A/T Park Light (Remove)
8, B-R, Park/Neutral Switch (Remove)
9, R/G, T-case Neutral (Remove)
10, None
P1 - Use to plug into Taco Auto Tranny
1, Do nothing
2, Do nothing
3, Do nothing
4, R.., Batt power to Tranny Backup switch
5, Do nothing
6, Do nothing
7, V.., T-case 4wd Switch
8, R/B, From Tranny Backup Swicth to Lights or Relay
9, Do nothing
10, Do nothing
Since the donor vehicle in my conversion is for a truck that orignally had a 22RTE (turbo motor), the wiring harness and cluster is different than the standard and very common 22R or 22RE motors, I decided not to list the vehicle connections I made on my vehicle because I'm sure it would cause more confusion than good. Plus since I don't have an actual wiring diagram for the donor truck, I can't label the plugs correctly which would just double the confusion. And please don't email me in the future asking me where I connect such and such a wire - because I'm sure in a month I won't remember...
4RnrRick
First I identifed the wire plug designation call-outs that were on the ECU (E5, E6, E7 & E8) and the end of the motor harness (1K2 & 1K3).
4RnrRick
#45
Then I figured out where they plugged into the taco dash harness (E5, 1K2 & 1K3). and I found the OBD2 Data link port which is (D7).
4RnrRick
Now for the book work....I first made a list of each wire color per location of the plug. Then using the GRAY Toyota Wiring Schematics Book I figured out what each wire did. and I listed whether I needed it or not. Then I removed each wire that I didn't need from each plug and spooled up that wire. Lastly I chased each wire for each plug and cut that wire trying to keep as much of the orignal wire length as possible which made hooking them up to the vehicle much easier. you can also see that I used a label maker to label each wire just like I did on my previous 7M swap..
So heres the D7 plug done.... (4 wires left)
4RnrRick
And the E7 plug.... (7 wires left)
4RnrRick
1K2 plug done.....(10 wires left)
4RnrRick
1K3 - I removed all the wires from this plug so I didn't even bother to take a picture of it. (0 wires left)
Edit - I ended up putting (1) wire back into this plug for the 4wd indicator switch
{img} no picture {img}
4RnrRick
Heres whats left over that I don't need to use from the orignal wiring.
4RnrRick
So heres basically whats left of the harness that I'm using.
4RnrRick
#52
So heres how mine turned out with all the wiring loomed up and finished....
4RnrRick
And as promised here is the video of the very first test drive, burn'n rubber and all!!  Well kinda - since there is no traction bar installed yet, it spun the rear tires while hopping down the road until it got enough traction and shot off like a rocket....you will see. and surprisenly it left about 7-10 feet of dual rubber stripes in the road even though it doesn't look like it in the video.
3.37 MB - 51 seconds, Download here::
http://www.rcpics.net/view_single.php?medid=77277
Video Mirror Sites: Right click save as please....
http://www.simpson-photography.com/Videos/testdrive.wmv
http://www.crazypetersons.com/videos/testdrive.wmv
BTW - I live on a dead end street and it was clear of traffic and people, So I felt this was safe....
If you guys are curious about the whole install along with a complete build up of my latest rig - check out:
http://www.pirate4x4.com/forum/showthread.php?t=447914
4RnrRick
Well heres my driving impressions so far of the 3rz-fe swap into a 85 extra cab....
I took the truck to the dunes Saturday and all I can say is WOW! I have a permanent grin on my face. This motor has really nice low end torque and it will rev right up to redline easily. I did almost all my dune running in 1st gear high range! (I couldn't do that even with the 7m -  it didn't have the low end grunt and would stall out very easily.) The 7M has more top end power for say high speed (45+ mph) drifting but the 3rz equals or betters that on everything else! I had no problem climbing some of the bigger dunes where you would be hard pressed to get a 22R/RE up them. and if the motor started to lug down you could downshift and the vehicle would lift up and keep right on going. Highway driving is also nice - where Pete (project_blu) and Tyler (yellow first gen) would have to down shift on the hills I could just stay in 5th and they would just keep up with me. if I downshifted I could pull away fairly easily.
I really don't know what else to say other than if you get a chance to test drive a 3rz swap - do it! but your wallet might hurt afterwards.
I also suspect why the 3rz swap is so nice in the first and second gen trucks is because Taco's are quite a bit heavier so the motor feels more powerfull than if it was in a heavier Taco.
On my drive over to the coast (approx 90 miles), I got 18.5 mpg with a 55-60mph average. Can't complain about that.
So my finaly option is that teh 3rz is WAY better for a trail rig swap than a 7M. teh &M is just too high strung where the 3rz has tons of grunt with a great midrange power!
Nothingface5384
#55
hey bigmike didnt you mention somewhere that marlin will be working on a 2.7 kit?
since i have a 92 auto can i just swap out the bellhouseing from the newer auto tranny?
and to make this clear since i'm using the autotrans i'll have to swap in the ecu from a 5spd?
thanks
btw good job on the swap and wireing notes!
Quote from: 86rustbucket on August 05, 2009, 05:16:04 PM
i love your sig your down to a half of a maverick
73 Maverick(jointly owned w/ lil bro)
64 LeSabre(sold)
82 RX7 (scrapped)
92 Toyota p/u 4x4 (dead) resurrecting underway
72 Skylark (dead) resurrecting underway
87 Grand AM (junked)
79 Regal (sold)
90 Geo Prizm (R.I.P)
Nothingface5384,
Yes, we are working on a couple of products for the 3RZ right now, but at the moment, nothing to aid in an engine swap.
We have already have an engine mount jig prepared, but we are still waiting for some other things to get finished before we take a step forward on the 3RZ swap product listing.
Regards,
malodin
well im starting my own 3rz conversion into a 92 pickup 4x4 ifs so, this is a link to the new post http://board.marlincrawler.com/index.php?topic=26050.msg278285#msg278285
TacoRunner
[email protected]
Danmit, I will be doing some updates to Bevin and my project threads, so I will put up your pics
Don't be such a slacker hahaha :rofl:
