Kiyul4130s rig
Started by kiyul4130, October 09, 2005, 09:09:33 PM
yota4x4sc
do u drive this on the street ever?
kiyul4130
Quote from: 91 ex-cab on February 27, 2011, 09:55:40 PM
Are you gonna put the bumper back on, or build a new one? It looks pretty badass without one...
ya. im gunna build the same exact one again but with 1 3/4" tube this time. the 1 1/2" was just a little small for my taste.
Quote from: yota_krawler on February 27, 2011, 10:53:20 PM
No I mean what is he going to do with it. I need to build one, if he wasnt going to re-use it I'd buy it
you can come get it for free if i dont have to get you a hood?
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
#2102
Quote from: UnderConstructionProject 85 on February 27, 2011, 11:22:05 PM
Kiyul4130 Ive been wanting to tell you that about 2008 your truck inspired me to build mine I just remembered why I was building mine lol I saw that 1st picture of your truck all flexed out and I was like yup I know what I'm gonna be dumping money into sweet truck :thumbup:
hey, thank you.
Quote from: yota4x4sc on February 28, 2011, 07:23:30 AM
i use to drive it on the road and do miss it every now and then but its more of a pain in the ass than anything. its really long and with the welded rear im over trying to cruise it cause it wont turn worth a :pokinit: anywhere. hopefully ill be picking up a tow rig very soon.
-kiyul-
ECV 7-11
KYOTA FOREVER
yota_krawler
Quote from: kiyul4130 on February 28, 2011, 05:52:57 PM
Deal, I text'd you. I'm in Chico till 8pm I can get it today or whenever
kiyul4130
so i believe the life of my rear shaft is now over. i think when the suspension compresses it pushes the rubber forward in the carrier bearing. i know its bent but ive also hit the slip as well.
i blew out the carrier bearing at KOH. i got this one which looked brand new from someone online and it blew it out a 100 yards from the trailer when i went up to the snow 3 weeks ago.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
just went up to H.A.D. to pick up this piece for the rear. i should have my new driveline/carrier bearing/flange all in next weekend when i get all the parts back.
-kiyul-
ECV 7-11
KYOTA FOREVER
ToYocRawleR
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
yota_krawler
Swap your hood yet?
rockwalker
where are you going wheelin this coming weekend
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
Dingman.
We have a stainless steel bearing at work that you would have good luck.
kiyul4130
Quote from: yota_krawler on May 22, 2011, 01:52:05 AM
Swap your hood yet?
nope. soooon.
Quote from: rockwalker on May 22, 2011, 02:06:29 PM
you have my number. hit me up. probably going no where now.
Quote from: Dingman. on May 22, 2011, 02:44:43 PM
what??
-kiyul-
ECV 7-11
KYOTA FOREVER
Dingman.
kiyul4130
whipped this out over the weekend. its nothing special. its exactly like my old bumper only 1 3/4 tube.
-kiyul-
ECV 7-11
KYOTA FOREVER
91 ex-cab
Looks good. Are you gonna brace it off more, or is it pretty strong as is?
kiyul4130
ill get another picture of it after the weekend. im going to tie it into my shock hoops. for some reason that picture makes the stinger look taller than it really is. its taller a pinch, but not much more than my old bumper.
-kiyul-
ECV 7-11
KYOTA FOREVER
91 ex-cab
Tie threw the hood right above the grill? Are you going to cap those stubs coming off the frame?
ToYocRawleR
Rigs:
kiyul4130
Quote from: 91 ex-cab on June 29, 2011, 10:12:36 PM
i should have capped them. there completely smashed from going through the box over the weekend. i wont go above the grill it will be some where on the inside/under the headlights straight back to the shock hoops, just like before.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
this was before i let some pressure out of the bumps. i was only going about 25mph or so.
http://www.youtube.com/watch?v=kELy1RHUlkE
-kiyul-
ECV 7-11
KYOTA FOREVER
Loud PS Pump, sweet video though
kiyul4130
Quote from: THK on July 06, 2011, 08:32:47 PM
ya i just had gotten done with a whole rebuild on the front end. i even did all new lines on the steering. i was steering it back and forth to try an get some air out of it that i think was trapped when i bled it back at home.
-kiyul-
ECV 7-11
KYOTA FOREVER
yeah they are a pain. im have trouble with mine, the VAPS Valve is bad on mine and is allowing the ATF to drain into the engien via the vac lines. so it drains the system really fast and makes my engine smoke bad. cant buy a new one without buying a whole new toyota pump from the factory at $400 bucks. they dont come on aftermarket ones and cant buy em separate. sucks! so i got to find a used valve or plug it with a M14x1.5 bolt. having a hell of a time finding one. i tried capping the vac ports and it just blows the plugs off. anyways.. the trucks lookin nice man.
kiyul4130
why not just get an aftermarket pump. it will be better than stock and you can find a way to plug those lines up.
-kiyul-
ECV 7-11
KYOTA FOREVER
Quote from: kiyul4130 on July 08, 2011, 09:20:06 AM
i have an aftermarket on it, i replaced it just after i bought the 4runner. but the aftermarkets dont come with a VAPS valve so i swapped the valve from the old pump not knowing that was the problem part. right now i have the pump off completely and the vac ports plugged on the engine
kiyul4130
#2124
heres some recent pictures from the other weekend.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
SOMEONE GET ME A HEADLIGHT BUCKET(s)!!!!
-kiyul-
ECV 7-11
KYOTA FOREVER
zembalayan
Awesome pics!  Looks like your set up is really working well.
sloyota
whats up Kyle...
you going up the Marlin Roundup this year?
me and Cody are going to trailer my truck up there this year.
my truck is the same,just has a flatbed on it now.
I'm not responsable for my own action's.
kiyul4130
Quote from: sloyota on July 15, 2011, 08:00:48 AM
whats up Kyle...
alright, i really hope you make it. we try and do this every year and fortunately see each other but dont wheel. so.......im moving to nashville in october so that will be one of my last trips out wheeling and i dont know when ill be on the trail again. it will be atleast for a couple years. the truck will be parked and staying back here in cali. so when its within a week or so of the round-up hit me up and we can try and meet each other there around the same time? were all going wheeling in 2 weeks to fordyce if your available?
-kiyul-
ECV 7-11
KYOTA FOREVER
sloyota
I was just up at Cisco Grove campground for the Axial West Coast Championship's for there RC scaler event.I got third in the 2.2 scale class.scroll down to the fourth photo.You'll see me on the left
http://axialracing.com/wordpress/2011/06/28/awcc-2011-winners/
And we did some 1:1 wheeling on the trail.i got some photo's i'll post up when i can downsize them.
I'll be back up at cisco grove campground's again on the 30th of this month for another RC comp..
I'll hit you up before the roundup,and we'll have to meet up somewhere on the trail even if it's at the springs..
Cheers..Wes
