damn! 127 seems huge to me. mine is at 110 with 40's. our trails here in the black hills are so small and tight that i wouldnt want to be much longer
are you going to cut that tube over the engine and weld flanges on each side so you can un-bolt it?
I was going to order some of those cool tube clamps to make it removable but the way I look at it, I've owned the truck 8 years this fall. The engines never been pulled once. I'll make it removable the day that engine needs to come out or needs work. I've never had to touch it so I'm just Gunna burn it in an call it good.
I have 5 dollars down that more than 5 people ask you how you get your engine out.
no idea how ill remove the engine now. im gunna have to pull all the links, move the axle out of the way and drop the engine out through the bottom of the truck. oh well, live an learn.
i like the dual shear high steer.. i wish i woulda did that
You need tenders to stop that.
Have you articulated it out yet to see if the coilovers hit your bumps.......... looks like they'll be all over them?
Looks awesome! Super nice work!!!!!
I should have gone 42's. your truck is sick.
