0 Members and 33 Guests are viewing this topic.
when are they getting mounted?
I'm not sure. My brother-in-law is bringing the other 2 to me this weekend (he picked them up for in Denver). I also need to find a shop that will mount and attempt to balance a 40" tire. I'll get some pictures of them mounted and will also document the cutting
True but bead locks you should be able to mount yourself, then you could use some sort of dynamic balancer to take care of the balancing for you!
I run my 40s at around 3-5psi and havent had a hint of bead trouble with 15x8 rims
How come? I have never spent much time snow wheelin, how does rim size affect snow traction?
Did you replace your wheel bearings when you did your front houseing? The only reason I'm asking is because I'm assuming your using wheel spacers and with 2.5 b/s you will be puttting quite a load on your wheel bearings with the 40's.
are stauns the inflatable like willy mammoth runs?
Started by vatoyrunner Project Research and Build-Ups
Started by 19904runner Toyota Pickup/4Runner Tech 1979-95
Started by 4xtoy Project Research and Build-Ups
Started by Oddmar Project Research and Build-Ups
Started by pyrosnow911 Toyota Pickup/4Runner Tech 1979-95
