life and death of a clean $200 toy...................
Started by Ramrod, July 12, 2005, 11:25:45 AM
whiteman
 :yikes:         For a minut I thought I was gonna see a turbo.
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
86RockRunner
Those headers are gonna bling when they turn blue  :yesnod: I've got the same ones and love 'em
Ramrod
While reading a book from a header manufacturer lately it said not to break in a motor with a header on it because the exhaust is really hot a first and it will turn the header blue so I will run a manifold on the new motor for a hour or so
6.72:1
I believe finger prints, or rather, the oil from your fingers once heated on the header begins to turn the header blue. At least that is always the case on every chrome motorcycle header I've installed. Most motocycle aftermarket header installation booklets tell you to clean the header pipe of all fingerprints and oil before starting the engine to avoid bluing. It is probably the same for any header, but thought that would help a little. It might not matter, but could avoid bluing on your header. Good Luck! Can't wait to see it on there!
[email protected]
Ramrod
update time:
Actually there isn't much to say.  I was bored the other day so I put on the header and am pretty happy with the extra power and sound.  It might have lost a little power off the line but right in the mid range there is a definite increase.  For the motor the only thing I have done is put on a new water pump and finally got the oil pickup tube and oil pan permenantly mounted.  I took the head in to get machined for the bigger valves but it turns out that the head was completely unusabe and not worth even a core so I just ordered a brand spankin new pro-topline head from engnbldr.  I just got this email from cruzin performance that my injectors are cleaned and ready.  Here is the link to the test sheet, i am happy. http://www.cruzinperformance.com/injcleaned/index.php?action=showinjdata&id=2116&l_name=harrington&injserial=602061-602064      Hopefully I get this all in soon and am about done spending money because I need a tubing bender and tubing bad
gotrocks
can't wait to see your motor all togther, just don't let it get screwed like mine did.  I'm so depressed :rivers:.  If only mine didn't get screwed. :smack:
6.72:1
[email protected]
Ramrod
Quote from: gotrocks on February 07, 2006, 09:24:59 PM
what did you do wrong to your motor?  I saw something about an improper breakin, was there any assembly error involved?
gotrocks
we aren't sure yet, we are going to tear it back down.  my buddy who pretty much did the whole rebuild has done a few toyota motors and is a very compatent mechanic was with me when it went bad.  he doesn't quite understand what happned because I was being pretty good to it.  We think that my temp gauge was off and it gave me a false reading and so it overheated and possibly ceased the piston rings.  I just hope I don't have to re-machine the block.
CSAKing
looking for a 80-85 not built toyota pickup in tenn, nc, sc, virginia can anyone help????
lilbuddy
patty what cam is that in there? And is that a doug thorley header?
RIP Kyota.... you are the man
GET IT!!!
Ramrod
engnbldr 268 torkr and thorley header.  I'm either putting the head on today or going to the junkyard for my last few parts
lilbuddy
Awesome. I just put on my head with the cam in it and it gave me a good amount more power. Plus it sounds really cool at idle. Its the satge 2 EFI LCE cam. Its got like a 290 duration. Still dont think it has as much power as it should. I messed with the carb a bit but still dont think its all good. Once I get my EFI on I will be set.
GET IT!!!
Ramrod
this morning 8:00 am the bloodbath about to begin
couple hours
couple minutes later after taking off the tires because the hoist wouldn't get the motor high enough
why you don't want me to work in your garage
Ramrod
Well I got alot done yesterday and even more today.  Today I:
pulled the whole dash out I don't know why
put on new clutch and flywheel
cleaned painted and installed all motor excessories
put new motor in
hooked up all vacume lines
completely cleaned and degreased the whole engine compartment
painted inner frame rails
installed radiator
wired in the motor
put on valve cover after polishing it
cut out many feet of unneeded wires from all over under the hood
setup the cone air filter
Here are some pics
what I have left to do to get motor running:
header
distributer
spark plugs and wires
wire msd
fuel lines
gas tank
circut opening relay
efi main fuse
main efi relay
a couple other wires
clean up wires under the hood
put dash back together
fill with oil
fill with gas
start motor and go mash on it
lilbuddy
So I hate you :(
I need to get to work to catch up to your progress.
GET IT!!!
BLACKDOG
              -Ronald Reagan
Volcom
Nice, I'm right behind you for an EFI swap.  I'm building up my motor as we speak.  The paint details look killer!  Nice touch.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
sloyota
I'm not responsable for my own action's.
Ramrod
Thanks for the comments,  its coming along nicely.  Today will be the day of wiring, hopefully I can get it all done there isn't really that much.  I already went out and mounted the efi fuse, circut open relay, and efi relay and then plumbed all the engine bay fuel lines
Shamb
MR_DIY
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
Ramrod
heres where i'm at.  Should be running tomorrow if not it will be friday unless something really bad goes wrong.
cleaned up and finished drivers innner fender
header sitting there with the  distributer and whatnot installed
bed full of leftover crap
relay and fuse mess
computer harness about done
BLACKDOG
I see you're collecting change to pay for your next upgrade ??
Your work looks real good, Can't wait to see it finished :thumbs:
              -Ronald Reagan
whiteman
Sweet stuff, you'll have it rolling in no time, with more action pics :wink2:
Ramrod
its gonna run tomorrow  :crossed:  then it will be down to marlins shop next friday to pickup two in-cab cages and possibly a 4.7 t-case gearset
Ramrod
well I have been dicking with this thing for a while now and nothing would get it running.  I tried everything and nothing made a difference so I said screw this its time to start throwing parts at this biotch and went down to yodamans shop in Santarosa and he let me borrow: different fuel injectors one day that didn't help anything than I dicked with more crap and today I went there and got: computer, egr valve, fuel pressure regulator, tps.  I got home stuck in the com]puter and wam it started right up and idled.  I have been dicking with this for two weeks and all the problem was the whole time was the damn computer didn't work.  so heres some pics for everyone.  I doesn't look as good as befor because I tore the wiring all apart and a bunch of other crap but i'll clean it up
MR_DIY
COOL!  glad ya got it figured out.  I like the DIY windshield visor in the last pic  :disturbed:   :laugh:
whiteman
Thats great man, sometimes these Yoda EFI systems can be the biggest pain, but they pay off, thats for sure.
Nice work on wiring, cant wait to see it on the trails again. :thumbsup:
