The sound could be alternator or water pump or power steering or AC or any of the idler pulleys........Pull the belts off and see what happens.How's the cat? It could be the restriction.
It was probably the unburnt fuel from the #1 cylinder that burned up in the cat causing your problem......
After melting from excess fuel.....
When you have one cylinder pumping nothing but air, The 02 sensor sees lots of oxygen and less fuel. It considers this a lean mixture and in turn adds more fuel. The rich mixture at warm up has less of an effect on the cat because the cat is still cold.
Yes, I hope that does not cause a ring seating issue! From the pictures of the plugs, why they look lean and hot to you? I see a rich mixture , possibly too much timing , and perfect heat range.The base ring looks sooty, unless that is oil deposits from the rings not being fully seated, the discoloration triangle on the ground strap looks too close to the threads, it should be in the middle of the curve on the ground strap, and there is no brown ring on the tip of the porcelain. The burn marks seem to go up 2-3 threads which shows optimal heat range. Not sure if I'm seeing correctly or if it's the picture.
This is a fuel injected engine. Reading spark plugs is from the carb Days.
Completely forgot about that when replying. You can still get a good reading after 150 miles, but there is so much more to reading a spark plug than taking them out and looking at them closely, it is a deep skill that I don't have and unfortunetly one that is lost through time. Nothing better than a wideband o2 reading.
The O2 sensor won't see a rich mixture with a misfire. It will see all the O2 from the unburnt cylinder and interpret that as lean.
The mixture didn't burn in #1 cylinder. All that unburned O2 mixes with the other cylinders making the overall mixture look lean.
A misfire (chamber not firing the mixture) can be caused by several things, right?...No spark = no fireNo fuel = no fireToo much fuel = no fireNo air = no fireToo much air = no fireToo low compression = no fireIgnition timing too far off = no fireWhich one of those misfires does the O2 sensor see as a rich mixture?Gnarls.
NONE
I added a LARGE capacitor across the injector test plug so that it primes the system before starting the truck..........
Hey emsvitil,Can you please elaborate a little more on that?Am I correct in understanding that if you short the test connector, it will power the fuel pump?Thanks you.Gnarls.
UPDATE: 4-16 PMI removed and inspected the cold start injector. I did not do the spray test, but it passed the resistance test. I disconnected the battery for about 1 hour just to see if resetting the ECU and clearing any codes might help.
Started by alfio Parts For Sale
Started by dune_it86 Engine
Started by richard head Toyota Pickup/4Runner Tech 1979-95
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by 83yota Project Research and Build-Ups
