Gnarly4X's 22RE Rebuild
Started by Gnarly4X, July 01, 2016, 07:07:57 PM
0 Members and 10 Guests are viewing this topic.
Gillesdetrail
#630
http://www.offroadforum.cz/toyota/aarc.epnet.com/application/8578/8578R02_FIRING_ORDER.html
at the second diagram.
I'm trying to remember if when my block was at tdc if the dot between the bright links was at 11:30 or 12:30, but I can't remember. Do you have a timing light?
edit: it was 11:30, and this might be useful:
https://www.yotatech.com/f116/installing-timing-chain-cant-line-up-marks-216514/#post51505200
H8PVMNT
OK you were starting to scare me :).
– Steve McQueen
OVRAROK
Quote from: Gnarly4X on March 29, 2017, 08:52:04 AM
I know what the firing order is.  I can't find it in my 1986 FSM!!  It must be there somewhere, right?  :gap:
Gnarls. :inthedark:
In my 88 FSM. If you go to section A2 in service specification, it in maintenance "engine"
OVRAROK
Sent from my HTC One_M8 using Tapatalk
emsvitil
Once it starts, pull the wire off the cold start injector........
If for some reason the cold start injector is staying on, it may be only causing #1 to be too rich.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
Have you moved the injectors and/or the injector harness around?
I believe the ECU 'grounds' the injector so it fires.     A shorted wire may be keeping injector on.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
Quote from: emsvitil on March 29, 2017, 12:40:00 PM
Hmmmm... OK, I can try that.
Thanks,
Gnarls.
Gnarly4X
#637
Quote from: emsvitil on March 29, 2017, 12:43:54 PM
I have only moved the harness while removing the engine and re-installing it.
Since installing the injectors while it was still on the engine stand, I have not moved the injectors.
Gnarls.
Gnarly4X
Quote from: ovrarok on March 29, 2017, 10:59:28 AM
Geezz.... I looked for that firing order for 20 minutes and could NOT find it in my FSM!!!!
Thanks,
Gnarls.
Gnarly4X
Quote from: H8PVMNT on March 29, 2017, 10:11:56 AM
I am scaring MYSELF!!
Gnarls.
Gnarly4X
#640
UPDATE 3-29-17 PM
Surprisingly, even only firing on 3 cylinders, the engine started right up and idled immediately. :thumbs:
Well... my gut feeling is correct...  I checked the spark.  All 4 spark plugs are getting spark.  :yesnod:
So, if the cylinder is getting spark, and it won't fire the charge, then it seems logical it's a fuel issue – too much or too little.  If not that, then it would seem to be lack of sufficient compression to fire the AF charge? If the compression is very low in #1 cylinder, I cannot see how it could be the piston and rings.  The only other cause would be the valves are not fully seating during the compression stroke?  Since the valve lash is per cam spec, what could it be?... missing valve stem seals?  :-\   :dunno:
What else would keep the chamber from firing?  :dunno:
Can it be an ignition timing issue?... I don't think so.   :dunno:
Tomorrow morning I will do a compression check.  Then, I assume my next step is to get into the wire harness and the injector connectors and injectors.  :tantrum:
I did finally find the page in my FSM where they hide the firing order! ... back of the book under Service Specifications Maintenance page A-2 in the Engine section.  So why the heck isn't it in the distributor and ignition sections or ANY other place in the diagnose sections!!  :thumbdown:
Gnarls. :inthedark:
OVRAROK
Have you tried swapping plug wire
Gnarly4X
Quote from: ovrarok on March 29, 2017, 10:56:50 AM
Yep... that's where it is!!
I missed it.... I need to have my eyes checked and new prescription for increased magnification!  :cheese:
Thanks,
Gnarls.
Gnarly4X
Quote from: ovrarok on March 29, 2017, 07:56:05 PM
Do you mean swapping as in try a new set?  Yes.  But... they are getting spark to the spark plugs.
Gnarls.
Gnarly4X
Gnarly4X
I had time to do more research. It looks like there is likely a problem in my wire harness and I will need to open it up and see what it looks like at the injector wire ground wires.
I will see if I can buy a noid light for these injectors.  Anyone have a source?
Chasing electrical ghosts in a 31 year old wire harness is almost as much fun as an enema.  :disturbed:
Gnarls.
Gnarly4X
Not to be negative or take a crapity attitude about my 22RE, but to simply share my thoughts and experience as I go through this rebuild project...  after doing more research into the wire harness issues in these early 22RE engines, hopefully I will not see myself struggling with continuing problems with the wire harness and connectors.
Even if my problem is not harness, wires, or connector related, my research has raised questions and concerns about this engine and its reliability after a quality rebuild.
So, far I have not found a source for anything but used harnesses, and those are for specific year and model of the vehicle.
Before I started this rebuild, if I had known of the potential, and apparently not uncommon, failure issues with 20 to 30 year old wire harnesses, I would have seriously considered converting this engine to a carb'd 22R engine.
Its "Toyota-quality-like" to see a 1986 Toyota 4X4 with a 22RE engine go 30 years with no problems with the engine wiring.  BUT... the problems seem to rear their ugly heads when the harness is disturbed while doing a rebuild, parts replacement, testing, or just basic maintenance.
Even if a brand new wire harness was available and for a price that wouldn't cause a TIA, the idea of removing and replacing that harness would be a nightmare for me.
That's just my opinion – it may be worthless.
Gnarls.
H8PVMNT
– Steve McQueen
Cheesemaker
The FSM and a volt ohm meter will be your friend.
Gnarly4X
UPDATE 3-30 AM
I have isolated the mis-fire to cylinder #1.  Using my engine stethoscope, each injector sounds the same, so I assume all 4 are at least firing.
With the engine idling, when pulled each plug wire off the spark plug, #1 had no affect, on numbers 2, 3, and 4 the engine idle dropped immediately.  Number 2, 3, and cylinders are firing.  So... it appears that number one cylinder is getting plenty of spark and some fuel.
Why else would it not fire?
I'm going to do a compression check now.
I'm getting more bummed out about this mystery.  :smack:
Gnarls.
Gnarly4X
#650
UPDATE  3-30 10am
Compression check showed between 149 and 150 lbs on my gauge for each cylinder.
So, its not a compression issue causing the #1 cylinder NOT to fire.
I have to believe its the injector or injector wiring or injector connector.
The stethoscope probe sound was the same for each injector?
As you can see on the spark plugs – 4, 3, 2, and 1 in that order, from left to right, #1 cylinder is not igniting the mixture – whatever it is or is NOT.
Does anyone have any ideas  for what else I might look at or test?
I can start opening up the wire harness and look at the wires and any solder connections for the #1 injector?
Thanks,
Gnarls.
DAWGTOY
whats the gap setting on the #1 plug?  i know you are getting spark at the sparkplug wire.
screw in another plug and plug the wire on the plug in question--ground it out and see if the
plug actually has a spark. you say it has a gas smell on the plug and is kinda wet looking
so i'm not sure how it's getting gas into the chamber if the injector is not firing.
i hope you get it figured out--- it's past time to have that thing on the trail.
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
blackdiamond
Quote from: DAWGTOY on March 30, 2017, 11:13:24 AM
What are the odd of getting a nonfunctional spark plug?
OVRAROK
Regardless of odds, only takes 3 min to eliminate the plug being bad.  :eyebrow:
blackdiamond
Quote from: ovrarok on March 30, 2017, 12:07:30 PM
I fully agree. Has anybody ever had a plug not work?  It has to have happened before...
Gnarly4X
Hey Dawtoy,
Yeah... the first thing I did was check spark.
The gap on all the plugs are .030".  I had the new platinums at .032".
I don't know if the #1 spark plug is firing "inside" the cylinder, but it sure has plenty of spark outside.
I appreciate all input on what this "no fire" may be caused from.
Gnarls.
Gnarly4X
#656
Quote from: blackdiamond on March 30, 2017, 12:59:33 PM
In all my years I have never experienced a bad spark plug out the box.  And I have never had one fail... only "worn out" due to the electrodes were burned from mileage.  I have had spark plug wires go bad... the ones that are NOT wire core.
For this mis-fire, I tried two sets of different cap & rotor and different spark plugs, and different spark plug wires.
It's gett'n SPARK!
Gnarls.
Gnarly4X
Yes, and since I put in a brand new set before attempting to fire the engine for the first time, I immediately put on another different set.
Gnarls.
OVRAROK
OVRAROK
Question, did you purchase vehicle with bad motor, or where you driving this when motor went bad ?
