:)bestgen4runner's build page.
Started by :)bestgen4runner, May 14, 2016, 03:56:24 PM
SqWADoosh
Quote from: :)bestgen4runner on April 14, 2018, 09:35:49 AM
Yes Sir, I gave My Girl SqWaDoosh the option to get TG or Marlin as it's part of a Bro deal and I wanted it to be up to Him.
He Said "I am getting You marlin, Period"
He is a salty b*std but also a very good friend with sidekick potential.  :yupyup:
Thank You Andrew.  :smooch:
Something on this truck has to be from Marlin instead of Trail-Garbage.  :slap:
:)bestgen4runner
#601
Quote from: SqWADoosh on April 14, 2018, 09:42:51 AM
My Marlin parts list-
Transmission rebuild kit
Billet High Steer Arms
25mm Steering Pin Upgrade, Kit
HD Transfer Case Rear Output Seal
Heavy Duty Shift Spring
Heavy Duty Shifter Seat, all 3
Clutch Fork Boot
Rock Sliders (they sent Me AllPro)
And soon 4.7s
front axle tube seals
I am 1/5th of Perfect Fit
Rockcrawlintoy
Quote from: OVRAROK on April 14, 2018, 09:14:31 AM
Please tell me the 4.7s are Marlin crawlers
I assume they will be if they are ever in stock
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
:)bestgen4runner
Quote from: Rockcrawlintoy on April 14, 2018, 09:54:23 AM
They are at SqWaDoosh's house waiting for Me. He knows people on the inside.   :shhh:
SqWADoosh
Quote from: :)bestgen4runner on April 14, 2018, 09:53:46 AM
Clutch Fork Boot
And soon 4.7s
Let's see the TG list  :moon:
:)bestgen4runner
Quote from: SqWADoosh on April 14, 2018, 10:09:57 AM
I should have seen that coming.
Rear diff triple drilled flange
rear u bolt flip kit plate
rear axle bearings
rear driveshaft
skid plate
Dual t-case adapter
frame tubes
front hanger
front axle gusset
front axle ball gusset
front diff armor
rear diff armor
front Longfield axles
steering arm studs, nuts, and washers
T case output flanges (both)
front diff triple drilled flange
front and rear brake line extentions
speedo cable extention
front and rear diff breathers
I am sure there is more.
300k
Regardless of price, or what country they manufacture their stuff, buying TG is a huge disservice to the offroad community.
SqWADoosh
I don't know if you deserve these after seeing that TG parts list.  :shake:
23 spline?, if he doesn't want them, I know a guy  :eyebrow:
:)bestgen4runner
Let's not forget that I bought My truck as someone else's unfinished project.  :qtip:
Most of that list came with the truck.  :dunno:
I will admit to buying some trail gear parts but only a few of the ones on that list.  :angel:
EASYRYDERDANGER
Those 4.7 marlin gears look just like my 4.7 trail gear version
Front hanger bolt center to center of frame tube 44.5"
Front hanger bolt center to bottom of frame 3.5"
front shackles center to center 4.5"
rear shackle center to center 6"
bottom of frame to flat ground (measurement taken at center of door) Right side 25-3/8" Left side 25-1/8"
:)bestgen4runner
#612
Well good news and bad. Ubolts came in, and  they fit perfect as far as length but won't fit threw My top plate. I had 5/8 Ubolts  for 4" blocks before and ordered 5/8 ubolt shorts but the new shorter length will not allow me to stretch the bolts open enough to fit through the top plate. Sucks!
Called Ruff stuff this morning and they added only the additional cost to match the price of their flip kit. Thank You ruff stuff. (Good People)
Back to waiting. I might hog out My originals just for mockup purposes. Frustrating.
mudmaster
I would have just made new plates....
Time to go wheelin!
Willard
I had the same issue and just reamed out the plate holes with a small carbide bit and fit like a glove.
EASYRYDERDANGER
Quote from: mudmaster on April 20, 2018, 08:23:24 AM
I told him the same thing
:)bestgen4runner
Quote from: EASYRYDERDANGER on April 21, 2018, 07:06:54 AM
Interesting because I recall your recommendations involving a big hammer and the vise.
:)bestgen4runner
#617
The new Ruff stuff top plates won't be here until Wednesday or Thursday. That wouldn't work since I have to protect SqWaDoosh's ride from the evil residents of Maple Valley soon. Spent a few hours drilling cutting and filing My old top plates to fit. What a pain in the ass. I definitely have moved drill press, plasma cutter, and torch up My tool list.
New picture is with everything the same except rear blocks removed.
New frame to ground measurement 24 3/4"
Rear wheel well to tire 5 1/2"
Front wheel well to tire 9 1/2"
Rear receiver to ground original  29 1/2 now 25
Front receiver to ground original  24 3/4 now 24 1/2
Options
Replace front hanger to Allpro lowpro will drop the front 1"
Reaplace rear springs with 4 Leaf 63's might bring Me up 1+ " in the rear
Add a 1" fancy block to the rear that Drew and Dave showed Me.
Have not decided but I'm interested in opinions.
Couple other notes
I have 6 1/2 in the front before bumper contact
I have no intention on any fender cutting
Building for 37'sbut all measurements have been taken with 35's on at street pressures.
Front springs have not settled yet
Changing the hanger could move my shock position to the point I have to move my shock hoops
Rockcrawlintoy
Looks good to me. How much lower is in really in the rear. The rear wheel openings arent the same as the front
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
:)bestgen4runner
#619
Maybe a better picture  of current stance
Rockcrawlintoy
needs about an inch in the rear, and some trimming
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
:)bestgen4runner
Rockcrawlintoy
It's a gimmick. I ran something similar and went to a regular shackle
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
joeyf
They are a bad idea. They will want to unload on you on steep decents, had a friend run the same kind of shackle and it was super sketchy watching him go down the rock wall at walker or old Reiter. If you want more flex out of your springs just inboard them.
:)bestgen4runner
Quote from: Rockcrawlintoy on April 21, 2018, 05:41:23 PM
Quote from: joeyf on April 21, 2018, 07:13:32 PM
Ok so that is official shot down.
Thank you
daniresch
Quote from: :)bestgen4runner on April 21, 2018, 07:44:04 PM
Thank you
To throw a little flavor in the mix: I run those shackles with great success. Uphill, downhill, street, or rock works everywhere.
Anyway, I agree the rear should come up some bit if you plan on running 37s. Why not just install an "add-a-leaf" under your 63s? They're like ~$70. It will gain you about ~1.5in, and a more stable rear-end.
300k
Quote from: 300k on April 22, 2018, 09:38:54 PM
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
thems should work with 63s in the rear. you have options bestgen :greengrin:
It used to be a "used car" and now they are "previously owned" to make them sound better.
It appears that what used to be a "block" is not a "Zero Rate Add a Leaf" that is now suddenly acceptable for use in the front?  I thought that was always a big no-no?
A 1 inch block in the rear of mine could shift my wheelbase a bit...I wonder if it would cause a major issue with my driveshaft length/angles...
daniresch
300k
Quote from: blackdiamond on April 22, 2018, 09:44:44 PM
Read the page. With lift blocks the U bolts come loose and then you die. this one bolts to the leaf and then the U bolts clamp the leaf down like normal.
