Maybe you should load the rear up to know how much it really needs to be lowered.
I'll bet is settles in perfect after a few trips.
How is your steering clearance? Also by the looks...if settles too much 37's will probably eat the firewall.
4runner's looking good Bestgen. I'm pretty confident those springs will settle at least an inch, maybe a little more. I'm really exited to see your running the Sky springs. Like others have said, they look intriguing but not a lot of info from people running them. I would like to know the measurement from the center of your front spring bolt to the upper shackle bolt.
Front spring mount bolt at the front hanger to the frame tube in the rear? You want to know the difference from the ground? I can do that tonight.
I want to know center of front spring mount bolt at the hanger to center of the frame tube bolt (eye to eye so to speak, not from ground). I want to compare that to the way I have set thing up with RUF. I'm assuming the sky springs are a bolt on swap for people running RUF?
hell ya, try those springs out if its no cost to you.
If they are going to let you try those rears at no cost you'd be a fool not to do it.
I don’t remember my Alcans settling much at all.
My alcans never really settled either, I'm on my second complete set too. But sounds like these 3f springs settle like an old mattress
Bolt in for Ruf is what they say.I will get You the measurement. My truck was not a Ruf setup prior to this, FYI. I will be interested to see If it matches the others You have done as well.Am I correct that the frame tubes are all installed in the same location no matter the setup?
If they never settled why are you on a second complete set? JW....Sent from my iPhone using Tapatalk
I understand everything you just said, but he said his didn't settle and I asked why he changed them. If they didn't settle, but instead sagged that doesn't sound like very great of a spring.
Started by RogueDogg Chit Chat Camp
Started by CruzrDave « 1 2 » Chit Chat Camp
Started by robinhood4x4 Chit Chat Camp
Started by MiniSimp Chit Chat Camp
Started by :)bestgen4runner Project Research and Build-Ups
