Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
zippo
That looks like a lot of work. Pull the head off that motor. I want to see what the insides look like!
If you see it, its for sale.
redneckcustoms13
You need to do something quick, she ain't going far with a broken leaf spring lol
01 double cab hunting truck
06 tacoma street truck
helipilot77
Thats why I'm switching to link suspension. The first time I powered her up and hit the throttle the massive torque of my brushless motor twisted the rear axle and snapped that rear leaf spring  :yikes:
That's when I realized I needed links.
redneckcustoms13
I got the axial ax10 whrn they came out in like 07-08 it now sets in my mom's attic. Expensive hobby them little tiny versions of real ones. Is yours a tamiya or rc4wd looks like rc4wd.
helipilot77
It's is all RC4wd but not a kit. Just a bunch of parts I put together.
helipilot77
#155
Got the head off. Looks like there was some pitting on the head in number 3 cylinder. I have heard that happens when water particles are compressed.
redneckcustoms13
Pardon my ignorance of the 1kz, but looking at the injection pump it appears to be a mechanical pump. Is it as simple a fuel shut off solenoid and it runs? I know a 1kz-t is manual, where a 1kz-te is electronic which is the one you have?
LittleSteve
Quote from: redneckcustoms13 on October 26, 2015, 07:27:57 AM
Its the electronic pump and is run by ecu. If you can find a kzt your doing well
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
Here is the link to a write up on Ih8mud on the conversion of a 1KZ-te to a mechanical pump, using a Mitsubishi 4M-40 mechanical injection pump made by Zexel.
http://forum.ih8mud.com/threads/1kz-t-no-longer-te-mitsu-4m40-pump-swap.536516/
LittleSteve
Quote from: helipilot77 on October 26, 2015, 05:49:05 PM
except the zexel pump has the wrong fuel plan for the kz, the injectors have different brake pressures etc etc etc. hence the having to wind the timing round.
The real answer would be to use a kz-t pump but there rare as hens teeth and then the kzte injectors wont match the plan for the kzt injectors...
and so on and so forth.....
redneckcustoms13
Not trying to hijack the thread, but sounds like making a 24v cummins a ppump engine. I was just wondering about the differences in the two engines. I'm thinking about puting one in a 1st gen if I can get one for a decent price.
helipilot77
Quote from: LittleSteve on October 27, 2015, 10:06:27 AM
It sounds like Bloc from the thread on mud got his running good with a little timing fiddling.
Quote from: redneckcustoms13 on October 27, 2015, 10:27:53 AM
I would think a 24v would be far too heavy for a first gen. I don't want to discourage you from doing something mad cool though. If you could pull it off it would be outrageous!! Maybe with a custom floorpan and heavy duty springs it could be done.
redneckcustoms13
Im not wasting a cummins in a toyota lol I was referring to making a kz-te a kz-t looks to be about the same process as a 12v pump swap on a 24v lol
helipilot77
Quote from: redneckcustoms13 on October 27, 2015, 12:42:36 PM
Oh! well I can tell you that those are cool. I think putting one in a first gen would be sick. They are  so light you would have trouble putting all the power down unless you fill the back with rocks.
Quote from: ovrarok on October 27, 2015, 12:49:46 PM
here is the kz-t mechanical pump, almost fell back in my chair http://oemparter.com/oem-parts/2210067060.html
It's worse than that because they actually aren't even available anymore. If you call those guys they will tell you that it is out of stock.
redneckcustoms13
Wow, you can completely build some diesel engines for that price.
Sorry for jacking your thread up with all this oil burner talk
helipilot77
redneckcustoms13
I've read a bit on the kz-te, it's got quite a bit of punch in a small glass. How well did it perform compared to say a 22rte or a 3rz 4runner?
I'm happy with the 3rz in the dd 1st gen, but really would rather it be a clacking diesel that gets better fuel economy.
ive had my eye on the 1kd-ftv, looks like a sweet motor
helipilot77
Quote from: ovrarok on October 28, 2015, 06:02:02 AM
It would be if it was reliable. Toyota has had a lot of trouble with. Major component failures.
LittleSteve
Quote from: helipilot77 on October 28, 2015, 06:11:12 AM
Go 2kd-ftv better motor all together...
helipilot77
#172
Today I tackled the task of removing the injection pump. So I started by making a puller. I have read that this thing can be a real PITA to remove. The TOYOTA SST uses two 6mmX1.0 bolts to go into the drive gear but I have seen others who made their own pullers and used 4 with much better success, so I used 4 10.9 grade 6mm bolts. And a fine thread 3/4" bolt in the center to push the pump shaft out.
It certainly took more pressure than I would have guessed for a mere half inch diameter tapered keyway shaft. But I got it to pop loose.
redneckcustoms13
Your almost there, go ahead and do that manual pump swap we were discussing earlier and let the little thing get some juice in it!
helipilot77
Steve reports that the manual pump and injectors are being reworked now.
so was steve able to source one out in his neck of the woods?
helipilot77
Quote from: ovrarok on November 02, 2015, 08:42:20 AM
He told me he had one on its way to his pump guy.  :clap:
helipilot77
#178
I tried to remove the crankshaft bolt with my impact but it is torqued to 265 ft.lbs. and is just turning the crank. So I made a couple tools to keep the crankshaft from turning. One for when the flywheel is off, and one for when the flywheel is on.
zippo
